Castle ice lite 75 fried
Got to the field today to finally maiden my angel. Must have had an angel on my shoulder - because right before I got her off the ground - the prop stopped abrubtly (bang) and smoke started coming from my esc. Coulda been worse.
Now i;m trying to figure the problem... bad esc? bad motor? bad combo? Everything was connected proper and seemed to be fine when I ran the meter against it befor flight. The esc is totally dead - but the motor seems fine ( but not sure if to trust it) Ihave nbeen running the castles on multiple other planes without issue.
here is my setup:
motor - hacker a50s-14turn (425kv/1250 peak watts)
Prop - 16x10 apc
battery - tp 5s 5000 30c
esc - castle ice lite 75 (stock length battery wires)
4 of the fets by the black wire just popped.
Any input is appreciated.
thx
rich
here is my setup:
Prop - 16x10 apc
thx
rich
RE: Castle ice lite 75 fried
Contact Castle.........ONLY ........First !!.......Do not listen to any do it yourself advice. Castle should know what caused it & work out a replacement if it is their fault.
Maybe.
Maybe.
