Hybrid Edge
#226
RE: Hybrid Edge
That sheet is 100% correct and what I was trying to explain with relationship to the geometry. Both ends must match and rarely do folks cross the cables on giant scale planes. You get rubbing and other problems like messed up geometry due to the offset deviations. Example C is probably the more common these days due to the large and thick rudders. Having the horns offset behind the hinge line makes installing easier but of course you need a matching offset servo horn. Thanks for posting that sheet!
#227
RE: Hybrid Edge
i thought i had to cross the cables? on my normal fuse i don't but with the hybrid if i don't cross them, then i would have to make a slit along the hole side of the fuse..... has anyone done a straight pull pull setup on the hybrid?
#228
OH
RE: Hybrid Edge
I haven't walked through this whole thread. Just curious. Is the Hybrid Edge legal for IMAC competition? I know it's sort of a profile, but is it true to scale enough?
Tom
Tom
#229
RE: Hybrid Edge
ORIGINAL: Trisquire
Tom
Tom
#231
My Feedback: (17)
RE: Hybrid Edge
Constrictor. You would love it.
Tiktock. I have my cables crossed. My pivot point is right on the hinge line and my servo arm is slightly offset. My gemetry is perfect. I have the same tension on my cables all the way through the motion. I mounted one cable to the top of the servo arm and the other to the bottom. I am using a SWB servo arm which is about 1/4" thick. Tthis keeps my cables far enough apart that I don't have any problems with cables rubbing.
#232
OH
RE: Hybrid Edge
ORIGINAL: alpapilot
I think you need a pilot and an instrument panel for IMAC. Unless you fabricated a clear canopy that rules it out. However, I do wonder if you where to put a picture of a pilot on the side if that would count .
Tom
#234
RE: Hybrid Edge
To fly IMAC though you have to be a scale plane. You could fly the Hybrid in Novice class though as this rule does not apply. In the Sportsman and up class though it has to be a scale plane. I was surprised how well the Hybrid does fly pretty good IMAC circuits.
#235
My Feedback: (23)
RE: Hybrid Edge
Has anyone been able to get the hybrid to do an inverted flat spin???... I have used up all my tricks and still can't get even close. Hybrid just starts flipping over on itself. if you try using less elevator, the plane just goes willy-nilly all over the place. I have got a decent up-right flat spin although it's not locked in as well as i'd like. I have a feeling that the extreme taper of the wing is not condusive to flat-spins.
#237
OH
RE: Hybrid Edge
ORIGINAL: AFSalmon
Tom
#238
RE: Hybrid Edge
ORIGINAL: rcplanenut
Yes, I can do inverted flat spins all day long with my hybrid. start with a blender into the flatspin. It will also do upright flat spins
#239
RE: Hybrid Edge
ORIGINAL: alpapilot
Hee Yah, It's DONE! (except for the number "55" on the right wing. I'll do that tomorrow.)
DA-50 w/ Slimline pitts
HS-5595's on ailerons
HS-5645's on rudder and elevator
Fromeco Wolverine switch
Dual A123 two cell packs on RX
Common Sense RC 2000mAh 2s lipo on ignition
42 Percent Products Opti ignition kill switch
AUW = 16.5 pounds! Kick *****!
How many rolls of covering did you use for that scheme?
#240
RE: Hybrid Edge
ORIGINAL: 3D_Junkie
alpha,
ORIGINAL: alpapilot
A-L-P-A (no "h" in there)
#241
RE: Hybrid Edge
ORIGINAL: alpapilot
Two 50' rolls.
ORIGINAL: 3D_Junkie
alpha,
ORIGINAL: alpapilot
I only allocated two 25' rolls. Should I think about ordering some more?
#243
RE: Hybrid Edge
ORIGINAL: 3D_Junkie
Sorry about that.
ORIGINAL: alpapilot
Two 50' rolls.
ORIGINAL: 3D_Junkie
alpha,
ORIGINAL: alpapilot
#244
RE: Hybrid Edge
ORIGINAL: alpapilot
That's what I meant, sorry. Two 25' rolls for a total of 50'. [sm=spinnyeyes.gif]
Glad to hear I've ordered enough.
I am thinking of doing a scheme similar to yours. I have always liked that scheme on the full size plane and seeing yours, I love the simplicity of it. Do you mind?
IT would be cool to show up at Nash with two almost identical planes coming from places 1500 miles apart.
#245
RE: Hybrid Edge
ORIGINAL: 3D_Junkie
I was about to say "Holy Handgrenade, that's alot of covering!". The covering would cost almost as much as the kit.
ORIGINAL: alpapilot
#246
My Feedback: (24)
TN
RE: Hybrid Edge
Just to let you guys know I have just finished up on building a new fuse for my second hybrid, and on this one i moved the stab up 3 inches closer to the wing and so far the only change i can see is it allowed me to install the rudder servo in the tail where the elevator servo would normally go and i moved it down to the bottom of the fuse.
After i get a few more good flights on her i will let you guys know more. I have another Hybrid kit and a friend is going to build this one for me. I just finished building another MOJO and I am about over building for a while. I wanted to have a spare hybrid for when we go to Joe nall.
Here are a couple pictures of my Hybrid and the MOJO.
#247
My Feedback: (24)
TN
RE: Hybrid Edge
Ok guys finally got a video of my hybrid. I got it this time before anything happened to it.
http://www.youtube.com/watch?v=-XGiNxy3d70
