Ripmax Xcalibur Sports jet
Old 12-17-2023, 11:53 AM
  #2626
CARS II
My Feedback: (7)
CARS II's Avatar
Are you going to cut the wheel wells, servos and ailerons?
Old 06-30-2024, 12:38 PM
  #2627
pc1972
Default Xcalibur - Dutch roll / oscillation
Hi,
I've recently maidened my mid-sized Xcalibur. The model was bought partially built and unflown and I've completed it with Hitec high torque servos and a Wren 80 powering it. I'm getting a problem with Dutch roll / oscillation noticeable at all speeds but maybe worst at mid throttle speeds. I've given the model another good check over again and can't see anything obviously wrong with it other than the right aileron outer hinge point is offset by 1.5mm due to it being incorrectly drilled during manufacture. The trailing edge of the said aileron is aligned with the trailing edge of the wing though. The main wing to tailplane alignment / dimensions are within 2mm and everything looks nice and square. C of G is at 170mm with the bubble trap full and the main tank 1/4 full. Has anyone else experienced Dutch roll with their Xcalibur and managed to cure it. Your help / advice would be gratefully received.
Cheers, Pete
Old 06-30-2024, 01:20 PM
  #2628
Dansy
My Feedback: (53)
Dansy's Avatar
Originally Posted by pc1972
Hi,
Cheers, Pete
All boom plane have that to a certain degree something like the dual PowerBox little one work for that
Old 06-30-2024, 09:09 PM
  #2629
Dave Wilshere
Dutch roll…no, not normal. Fish tail (wag) is normal and a gyro sorts that.
Old 07-01-2024, 01:08 AM
  #2630
pc1972
Hi, Thanks for the advice. Looks like using a gyro is the way to go.
Old 07-01-2024, 01:26 AM
  #2631
pc1972
Hi Dave, Thanks for the advice. Yes, it's fish tail (wag). Dutch roll was described by another flier at my club and maybe a bit over dramatic! Can you suggest a gyro unit and set-up? I'm using a Spektrum DX8 Tx and an AR9110 receiver and have not used a gyro before on my other models. Would you suggest a single channel gyro on the rudders for instance, or a three channel gyro? I have the ailerons and rudders on single channels with Y leads, as the spare channels are used up with lights and smoke. Cheers, Pete
Old 07-01-2024, 02:31 AM
  #2632
BaldEagel
BaldEagel's Avatar
Dutch roll or fish tail wag are not normal by any chance of imagination, if you need a gyro to sort out the geometry of you jet there is something wrong with the set up, check the alignement of each control surface, set the trims to neutral and fly the thing setting the trims accordingly in the air, once back on the ground check the trims and thrust line to determine where the problem/s lies. I will stress again it is not normal for any airframe to have either of these traits especially one as sorted and popular as a Boomerang.
Old 09-27-2024, 07:39 AM
  #2633
Jannica
I´m thinking about reinforcing my Xcalibur+ tailbooms with a layer of carbon and glas and then paint them. Maybe also a layer of glas for the wings. Just to make them stand the tear and wear a little better. Has anyone done something like it before?
Are the twin boom trainers dead or ar e they coming back in the future?
Jannica in Sweden.
Old 09-27-2024, 03:41 PM
  #2634
Boomerang1
Boomerang1's Avatar
Jannica in Sweden.
Did they ever go away? Saw in a recent fly-in report on this forum an original Boomerang Intro on a stand in the background.
I have a Boomerang Intro, was given to me. All the film has been stripped off & the previous owner has been covering it with
brown wrapping paper applied with thinned PVA glue, eventually to be primed & painted. Much more strength added than film
plus a more stable finish in the sun.
Jannica (09-27-2024)
Old 09-28-2024, 03:27 AM
  #2635
Twin-star
Default Electric Retracts
Has anyone successfully used any of the JP electric Retracts on a mid sized Xcalabur? If so what ones and were they a drop in or was a lot of fitting needed. Thanks. Ian
