Venom-Racing GPV-1 motorcycle
#251
RE: Venom-Racing GPV-1 motorcycle
ORIGINAL: microDan
NO, I did not. It didn't seem to be an issue I was aware of. Reading the tip again reminded me of long ago when the tip was posted. But I really never even looked into it. My bikes are fine....
#252
ORIGINAL: gabolauren
Hi guys, Chris:
Just one question so far. May I use lipo batteries with the standard motor and ESC?
Thanks in advance.
Hi guys, Chris:
Thanks in advance.
#253
ORIGINAL: VENOMOUS Yes no problem use a 2S 7.4V pack and as soon as you detect it slowing down pull it off and change/charge the pack.
Oh, didn't forget sboti74, couldn't find a video showing me what I was trying to explain, then a certain Edi from Austria posted this today. It's a 1/5 bike but still applies, showing how much the forks of a bike move even when leaned over in a corner. http://www.youtube.com/watch?v=wOJWB_kILk0
#256
ORIGINAL: VENOMOUS
The GPV uses 0.5 Module metric pitch gears. We offer pinion gears for 2mm and 2.5mm motor shafts. You can also convert the gears over to 64 or 48 pitch if you can work out the spur gear mounting situation.
#258
ORIGINAL: macz
Anyone running dx3r and sr3100rx?
#259
I have a noob question for you guys. I bought the steering bearings and I can see where the flanged ones go, but what about the other 2 bearings that came with it? (0339)
#260
<span class="Apple-style-span" style="font-family: 'Times New Roman'; font-size: medium; "><span class="Apple-style-span" style="font-family: Arial, Verdana, sans-serif; font-size: 12px; "> Hey everyone,</span><div style="background-color: rgb(255, 255, 255); padding-top: 5px; padding-right: 5px; padding-bottom: 5px; padding-left: 5px; margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; font-family: Arial, Verdana, sans-serif; font-size: 12px; "> I have been following this thread for a few weeks and have done some of the basic mods recommended on my stock bike. If I order the Novak Mongoose 13.5t BL motor with esc will there be anything else I need to get other than better tires? I managed to really get a feel for this bike quite quickly coming from an all-around r.c. background and am ready to add some real power. As far as battery, I don't mind shorter run times so which lipo would deliver the most power to the Novak setup? Any suggestions would be greatly appreciated.</div></span>
#261
Venom GPV-1
Found two great bikes on FB marketplace. Should be here tomorrow.
I'll post more once I have them. I sold the three I had back in 09. Wanted one ever since then.
