UMS Gas Radial Engine Enthusiasts Rabbit Hole
#376
My Feedback: (62)
5-100 owners, I have a concern. The Waco has now flown 5 times. A beautiful flier. Being a new plane, I pulled the cowl to inspect mounting bolts, rocker clearances etc. I was oiling the rockers and valve springs. No stuck exhaust valves, very free moving BUT! I found that the valve stems had significant side to side free play in the guides. The intake valves do not!! Would you guys check your engines to see if this is the same in your engines. Normal?? Remove the exhaust pushrod and put your finger on the valve tip and push the valve down a bit and then move your finger side to side to see if you have the same situation. Thanks in advance! -Tom
#377
#379
Hey Tom
I checked my 125 and another 125 that flys our field. The stems in these two engines have almost no shake between the stem and guided section when the valves are off the seat. Barely enough to detect.
These are also the two engines that displayed the "sticky" exhaust stems discovered and mentioned here in the thread after break in. Fuel conditioners with upper cylinder lubes seem to have solved that.
Aaron-
Aaron-
#380
Hi,
I broke in (2 gallons) my UMS 150 - she is running well. Just had her up in my CY Model FW190 (96" span) on its maiden flight. All worked perfectly. No 1 cylinder max temp was 237 degrees. Still running rich with lots of black gunk coming out. No pump and the engine ran quite smoothly. Love the sound. Plan to lean her out a bit next week.
Amsoil Dominator, 110 Octane Sunoco Racing Fuel
![](https://cimg1.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/img_7905_3cedd21cecf8ae0a21d18f9dfcf55540438f91ab.jpeg)
#381
Hi,
Does it run properly without a fuel pump?
no problems?
I also have a UMS150 and am struggling using it or not
carlo
#384
Carlo, my one flight went quite well, engine performed predictably, landed, taxied back and killed the engine with throttle cut. I plan to fly her again this week - will report back.
Hyjinx, factory carb. Will look for a number and let you know.
I have a temp sensor on cylinder 1, the highest temp in flight was 237 F.
Has anyone successfully operated these engines with a pump? Still way too early for me to claim victory.
#385
My Feedback: (62)
Congrats Sharam! Hyjinx, thank you for checking the valves. My valves are quite loose, but the engine runs well. I would have thanked you earlier but I have not been getting post notices. Get the pump, the pulse tubes will get gunked up and no longer give the carb the pressure waves needed to supply fuel.
#386
Hey Tom. All good dude. I don't get notifications and rcu's site is crashing Google. Sort of off topic but have you converted either your R325 or your Seidel (German ) to gas? I've put kits from CH on both of mine and am having the same trouble. Won't run reliablely without a pump. Then the pumps at lowest settings are flooding all three idle circuits. Walbro feels the pump pressure is forcing the reaction by overcoming the poppet valve (valve and seat) and flooding the circuits simultaneously. I am wondering if these smaller displacement radials are going to require a different carb design. Problem doesn't seem to be present on the larger displacement engines. Any sage wisdom to share Sir?
#387
My Feedback: (62)
Well rats Hyjink.....I do not have either engine presently. When I had my Saito 325, my conversion was changing the carb to the OS Pegasus 240 improving the engine greatly. You can try a stronger spring in the walbro. I had a lawn mower shop that had tons of walbro springs of different tensions but out of business now. Try stretching the spring???????
#388
#390
Thanks Tom. Yes I have been adjusting the actuator tab on the arm and have manipulated the spring by stretching but can't seem to get it. Working with two walbros and one Chi com carbs. All new. All reacting basically the same on either engine. The Walbro tech mentioned there were different spring sets available, and thought this may be the situation. Adrian felt adjustment on the controlling tab (arm) would help. Multiple different settings go from not much better to worse. I'm wondering if tracking down the available spring variations must be next rabbit trail. Or simply refitting the engines with glo carbs and sparking methanol, and getting back to flying instead of wrenching
#391
Thanks Aaron.
#392
Thanks Robert. I have been tinkering with regulation. Fixed reduction should solve the problem on the low speed circuits but may starve the engine during increases throttle. Haven't ruled it out but have been focusing on the carb. These carbs are a miss application according to walbro. So it's really a game to make this work. But I do know it's possible, Ive seen em running well on u tube.
#393
Ok, today I had no luck running the engine well. First it fired right up and after warming it up, I throttled up but the engine seemed starved for fuel. Richened a bit at a time but I ended up chasing needles for a couple of hours. Rich, lean factory reset, etc., no avail. Perhaps the pressure feedback lines are all gunked up as Maxam mentioned - thx!. I will buy the pump.
Which pump do you guys recommend?
#395
Hi,
It will run better on what it is designed for. 110 Octane rating will burn noticably slower, reducing performance.
#396
I bought and received the TCS pump. Shopping went well and was received stateside within two weeks. So far I am very pleased with it. One very nice initial option is running at very low voltage and can deadhead without damage based on its instructions. Hence constant minimal pressure at the carb without a plumbed in return line. I am using it on two smaller radial gas from glo conversions. Bottom line. Happy with the pump. May post more on "everything radial", as it is a bit off topic here. I am chasing trouble with the conversations, some to be learned yet, but progress is happening.
I have multiple APS units on several builds, but this pump is lighter, easier to use and fit, and outperforms the APS by being more regulatable with lower voltage battery technology.
More to come.
Aaron-
More to come.
Aaron-
