Powerbox iGyro
RE: Powerbox iGyro
ORIGINAL: HarryC
That's correct Mark. It looks as if the rudder output has to be split by Y lead or electronic box to the steering servo so they both get the same gyro all the time.
H.
ORIGINAL: schroedm
George,
I THINK Harry was asking if you can have the rudder axis gyro working on the nose steering and rudder in a scenario where you 'disable' the nose steering when gear is retracted (i.e. with rudder/nose steering on separate channels)
Cheers,
Mark
George,
Cheers,
Mark
H.
All that technology and you still have to use a y lead? Could always use it in combo with our Electron landing gear ecu which does split off rudder/nws and also centres/disables nws on retraction command and visa versa.
Very nice piece of kit all the same, can it be used with non bus systems?
Rob.
RE: Powerbox iGyro
ORIGINAL: Fortune7
As with all Powerbox stuff I'm sure it'll be a winner, but I'm intrigued how the GPS/gyro gain will compensate in big vertical manoevers, where the GPS can't be expected to give an accurate groundspeed. Surely input from a pitot-static airspeed sensor would be a bit more robust or have I missed something?
Certainly not product bashing but having set-up a roll - gyro accurately (Weatronics Micro 12 / gyro III) the wing wobble comes in very quickly if gain is too high for the airspeed. In a vertical dive which with a jet can be a few seconds, just wondering how the 'smartness' can sort that out.
Cheers, Andy
Cheers, Andy
Andy
It has a 3-D GPS with multple satelites giving data...so vertical element is covered :-))
Dave
RE: Powerbox iGyro
I'd need to check...but guess the Germans expect pilots to be able to use the rudder stick to steer on the ground...I've flown several hundred jets and never felt the need for a nose wheel steering gyro...
RE: Powerbox iGyro
ORIGINAL: Dave Wilshere
Andy
Dave
ORIGINAL: Fortune7
Cheers, Andy
Cheers, Andy
Andy
Dave
Again, I'm not criticising the product (so no need for defensive responses!) but I'm just interested in how they (PowerBox) resolve the issue, which if we are to believe the marketing, they have.
Cheers, Andy
RE: Powerbox iGyro
Andy
I'm no techno wizz, I hate electricity, as it can hurt you and you don't see it coming I'm a mechanical engineer...but Powerbox...V V V clever people and I can assure you they have done their home work. The system works...
Anyway, the iGyro could have 6-8 sats to look at, minimum 3 to start up and the way the gain adjust works, I'm sure it will cope with the vertical element speed too....sleep well on that one!
Dave
Dave
#31
My Feedback: (10)
RE: Powerbox iGyro
Sorry if this is a double post, the functionality looks similar to the Gyrobot 900 (that uses a pitot sensor for speed/gain mapping), If PB can get this to work this is half the price of the gyrobot they have a winner.
http://www.lf-technik.de/shop/produc...-Wing-Jet.html
#32
RE: Powerbox iGyro
ORIGINAL: HarryC
H.
ORIGINAL: schroedm
George,
Cheers,
Mark
George,
Cheers,
Mark
H.
#33
RE: Powerbox iGyro
ORIGINAL: mr_matt
Dave W
#34
My Feedback: (23)
RE: Powerbox iGyro
ORIGINAL: schroedm
I'm with Dave on this. From stationary to take off you ought to be able to steer! I'd rather have the gyro damping out oscillations in milliseconds in flight than trying to steer on the ground. Having said that, Powerbox are an excellent company and listen to ideas and feedback so who knows what iGyro 2 will do
ORIGINAL: HarryC
H.
ORIGINAL: schroedm
George,
Cheers,
Mark
George,
Cheers,
Mark
H.
Even if you have master your steering input it takes only one sec to loose it and to damage your jet big time.This is why IMHO steering gyro is a must for this kind models.
There is no need for a Y lead to control steering and rudder in a PoweBox setup.
For example if the PowerBox Competition SRS is used you can assign your rudder channel to exit A that will come from the iGyro.
On exit A you will plug your rudder servo and finish program it from the radio.Then on the "gang up/maching" exit below that is also A output you can plug your steering servo.
Then you can use the servo programing future to set the center and end points you like.This saves you a channel .
For the ones looking your steering servo also to be disable when gear is retracted, you need to use another channel with no gyro help ,or extra gyro and make the mix of disable when gear is up,
..in some cases i use a normal on/push spring switch triggered by the gear it self , that cuts off the power of the steering servo when gear is retracted .
#35
RE: Powerbox iGyro
can someone sign me up for the masters program for setup and operation? Just from conversation on here I feel like my head wants to explode, just like after I ready Futaba gyro book
#38
My Feedback: (23)
RE: Powerbox iGyro
FenderBean and rest , i just got the manual of the iGyro too.But i can't upload it cause its too big for RCU.
This manual has wiring examples and will take headaches away
Joe no you need a receiver with a serial signal interface port.Like the new R6203SB http://www3.towerhobbies.com/cgi-bin...&I=LXARPB&P=ML
A PowerBox Competition SRS will pump out of this receiver 14ch for you anyway.
The new iGyro is design to be used with Futaba S-Bus , Spektrum DSM2 , DSM X, , Multiplex , HoTT , Jeti ,Weatronic and in some weeks JR DSSM.
This serial interface receivers are the future and PowerBox does not make electronics that have no future.The iGyro is a big step towards the future and a big step in the modeling
Its like making a product now days that is not 2.4 compatible!...maybe 5 years ago would work for a while.
At Joe Nall , Mr.Emmerich Deutsch its self ,the managing director of PowerBox,will present the iGyro.
#41
RE: Powerbox iGyro
H.
#42
My Feedback: (10)
RE: Powerbox iGyro
I have a friend using the Gyrobot and he's looking at trying this alongside...so we should know after :-)
Well from what I have seen the gyrobot is the gold standard. If Powerbox can duplicate gyrobot performance at that lower price point, they will set a boatload of these. And no hassle of installing and maintaining a pitot static tube!
I am no GPS expert, but GPS solutions require a group of satellites to be tracked. If the satellite grouping is well distributed over the visible sky then I don't know why Z axis (altitude, vertical speed, etc) cannot be calculated with some precision. I do know that if you track a pack of satellites all in the same region of the sky (like when city driving and the rest of the constellation is shielded by buildings) you can get a crappy solution even in the X-Y plane.
And there are fairly inex*****ve high update rate GPS receivers now (10Hz).....even better for highly dynamic applications. I think the high power rocket guys use these with some success, and they are certainly going straight up for at least part of the flight (hopefully!) at 10 G plus.
The power box guys are clever, can't wait to see how it works!
#43
RE: Powerbox iGyro
ORIGINAL: mr_matt
"GPS accuracy
Although GPS receivers give you exact positions—for example, 34° 28' 18.8765"N, 122° 15' 34.0832"W, 302.56 meters elevation—it is important to understand that there is some amount of uncertainty, or error, inherent in these positions. A number of factors contribute to this error including satellite clock drift, atmospheric conditions, measurement noise, and multipath. In addition, due to the satellite geometry, vertical accuracy (elevation) is generally one and a half to three times worse than horizontal accuracy. You should consider each GPS position as a box, and you are somewhere within that box. The size of that box depends on the overall accuracy of your GPS receiver".
So with lower vertical GPS accuracy and a high rate-of-change of airspeed e.g. in the downline of a big loop, I'm still intrigued as to how the wonder box can alter gain sufficiently quickly to prevent over control of a surface leading to control oscillation, on GPS sensing alone. I guess I'll have to learn technical German to find out!
Andy
#44
My Feedback: (10)
RE: Powerbox iGyro
Exactly, if the satellite geometry is bad (all 4 satellites are in a 20 degree cone in the sky) all of the calculations are degraded, X and Y axis included. If they are distributed well in the sky, then verticle might not be so bad. The point is, with decent satellite geometry teh Z solution might be "good enough" for what they are doing. Need the pudding at this point.
#45
RE: Powerbox iGyro
Luckily...we don't need to know how the maths work...it just does When I questioned again these points I had a short sharp email saying you really think we would have missed this?? My answer, no. These guys are very special and have thought outside the box so many times...I'm 100% sure its going to be great.
Its not like the speed thing is totally controlling the gain, its just stopping over gain the way I read it...
Dave
Dave
#46
RE: Powerbox iGyro
Remember it is only for absolute positions (X,Y,Z) that you see most of the problems in GPS, here we are using the "second to second" changes, so the speed would be relatively ok (but if the constallation is _very_ bad, problems might occur, but fortunately the constallation is not often so, and the GPS receiver knows the constallation all the time, AZ/EL of all satelittes so could take that into account )
I'm really looking forward to this product.
I had been looking at the GyroBot for some time, but according to a friend it is a PITA to setup and adjust (and on top of that it is not exactly cheap...), so the the PowerBox unit looks interesting !
#47
RE: Powerbox iGyro
ORIGINAL: mr_matt
Exactly, if the satellite geometry is bad (all 4 satellites are in a 20 degree cone in the sky) all of the calculations are degraded, X and Y axis included. If they are distributed well in the sky, then verticle might not be so bad. The point is, with decent satellite geometry teh Z solution might be ''good enough'' for what they are doing. Need the pudding at this point.
A good filter should be able to coast through this issue. A bad filter will tell you that you broke the speed of sound, been there, seen that, setting still on a bench.
Looks like a very neat unit.
#48
My Feedback: (10)
RE: Powerbox iGyro
ORIGINAL: S_Ellzey
When determining you Latitude and Longitude you most likely have satellites on all sides of your position,
ORIGINAL: S_Ellzey
ORIGINAL: S_Ellzey
Does anyone that has the manual know if the required GPS sensor add on uses a standard interface or it is a Powerbox proprietary device?
