Sirio 23 Air Leaks UNITE
Old 08-22-2006, 11:31 AM
1brent1
Default RE: Sirio 23 Air Leaks UNITE
the dimensions for the front bearing is 7x17x5 mm its the same size bearing that is in the traxxas 2.5r and possible many other engines.
Don't order from bocabearing. I recently ordered their best package (ceramic) for the sirio .23 to find out that their seals are crap. I installed their front bearing and it leaks terribly.
I found out that my stock revo 2.5r has the same size front bearing (same numbers on the side too) so I swapped it since I'm not using the 2.5 and now I'm back in business!
Save yourself the trouble and don't order from bocabearings, I probably wouldn't order from acr either, probably uses the same seals. You can use the front stock bearing from your traxxas 2.5r and I'm sure its the same as the 3.3 too. I would imagine your local hobby store stocks the traxxas bearing so you might not even have to order and wait.
Good Luck!
ScRacing.. I take it the 12x19x6 and 12x18x6 you earlier ordered didn't work?
ORIGINAL: ScRacing
ask them what the demensions are ? so we can get it from acr or boca
Old 08-22-2006, 04:07 PM
bennyblanco
bennyblanco's Avatar
ORIGINAL: 1brent1
Good Luck!
ORIGINAL: ScRacing
i just called boca and they said the bearing size is 7x18x5! im confused now!! but im going to my lhs to get that bearing from the trx .15! thanks for the info!!
Old 08-22-2006, 04:10 PM
ScRacing
ScRacing's Avatar
The trx barings are not the same size, i got my baring in yesterday, and 7x18x6 is the perfect size, so im sending my barings back to acer and having them send me one back.
Old 08-22-2006, 04:50 PM
savagelover
i had a sirio and hated it wouldnt tune right always leaked and the rab was a piece of ****
Old 08-22-2006, 04:55 PM
bennyblanco
ahhhhhhhhhhhhhhhh!!!
Old 08-23-2006, 01:35 AM
  #31
1brent1
7x18x6... thats strange? they must make different sirio monster .23's because my front bearing is a 7x17x5, same size bearing as my traxxas 25r
ORIGINAL: ScRacing
Old 08-23-2006, 03:58 PM
  #32
ScRacing
ScRacing's Avatar
well my trx baring didn't fit? The diamiter was to small? And the corect mesurement is 7x18x5, bit i would rater have th baring a bit wide 7x18x6
Old 08-23-2006, 04:17 PM
  #33
bennyblanco
my bearing from boca is on is way and yesterday i went to my lhs and they didnt have the 2.5r bearing so still waiting!!
Old 08-23-2006, 05:14 PM
  #34
408Revo
hi
i also need to get the front bearing for my sirio
but before i do that i need to pull my old one out first
the problem is the rubber that seals the bearing came of
so when i pulled the crankshaft out the center piece of the bearing just fell out
now im left with a hollow bearing and i cant think of a way to pull it out
any help would appreciated
thanks
Old 08-23-2006, 05:51 PM
  #35
ScRacing
ScRacing's Avatar
ummm ..... thats a hard one.... you could try using a really small hex rench and pull/push it out
Old 08-23-2006, 06:36 PM
  #36
bennyblanco
try a flathead from the other side like the part where the pullstart goes but be gentle!!!
Old 08-23-2006, 07:24 PM
  #37
408Revo
hi
did you guys heat up the block before removing the bearing or just at normal temps
thanks
Old 08-23-2006, 08:59 PM
  #38
bennyblanco
i didnt heat the engine just popped the bearing off with the bottom of a screwdriver. im talking about the old bearing whenever my new one get here i will heat the engine to put it back on.
Old 08-24-2006, 12:28 AM
  #39
1brent1
let us know what size your new bearing is and if it fit or not? wondering if they make different models? cause ScRacing outer diameter is 18 where mine is 17mm.
I would definitely suggest not ordering from boca cause the bearing they sent me leaked just as bad as my old one and they are way over priced. I would order directly from sirio's distributer kyosha. I left the detail for ordering in a earlier post. The bearing is only $9.
ORIGINAL: savage.27
Old 08-24-2006, 08:18 AM
  #40
bennyblanco
yeah i order one from boca and the other from kyosho ill let you know what happens when it get here.
ORIGINAL: 1brent1
ORIGINAL: savage.27
Old 08-24-2006, 03:14 PM
  #41
ScRacing
ScRacing's Avatar
k, keep us updated, althoe acer racings marings are sealed on both sides so ther is 0% chance of leak
Old 08-24-2006, 06:50 PM
  #42
bennyblanco
my bearing came in today and it fits havent played with the truck yet but ill let you know wasup!!!
Old 08-25-2006, 02:24 PM
  #43
ScRacing
ScRacing's Avatar
sweet, just take care of that baring !
Old 08-25-2006, 02:37 PM
  #44
Revo Eater
Revo Eater's Avatar
BEARING. duh
Old 08-27-2006, 03:25 AM
  #45
1brent1
yeah, so is the front bearing you'll receive front boca. but air leak through terribly, can't use them.
ORIGINAL: ScRacing
Old 08-27-2006, 03:28 AM
  #46
1brent1
cool, let us know what size and where you got it. Also do the air leak test to see if air leaks through it.
ORIGINAL: savage.27
Old 08-27-2006, 03:30 AM
  #47
1brent1
go back to your own forum!!! by the way, a revo will out bash or race a savage any day!!
ORIGINAL: Revo Eater
BEARING. duh
Old 09-12-2006, 10:30 PM
  #48
ScRacing
ScRacing's Avatar
so what happened, who got a new baring and wich one works? I need to know cause i want to bash some time befor next year...
Old 09-12-2006, 11:39 PM
  #49
bennyblanco
im sorry i got the one from bocabearings and its working fine i was driving the maxx 2day and it was running awsome!!!
Old 09-12-2006, 11:42 PM
  #50
ScRacing
ScRacing's Avatar
give me a link to the one i need please ?
