Powermax Problems..
RE: Powermax Problems..
ORIGINAL: bcovish
Just replaced my old P120 with a P120SX and it only comes with kero start.
ORIGINAL: FILE IFR
.... Untill you need another $200.00 Kero plug to replace.
I've been doing it KC's way for 2 years now, and I'm still on my first $1.00 bottle of propane and the original $10.00 Rossi plugs. Flawless starts on my P-70 & P-80 SE.
ORIGINAL: Vincent
you guys have no idea how good this starting system is now from jetcat. Propane...[:@]
V..
V..
Pete
ORIGINAL: bcovish
ORIGINAL: Edgar Perez
Work with Eric to get the right parameters.All my Jet Central light easily with Propane.
ORIGINAL: Pete737
Wish I could go to the green bottle but my Jet Central wont light on it. Tried it a handful of times, It wont pop []..
Pete
Pete
Pete
#31
My Feedback: (13)
ORIGINAL: Pete737
Edgar, I have a older version Falcon. I don't have the option to regulate gas flow, Only glow power, speaking of which I have tried every reasonable setting with no success. I have had a number of guys look at it as well, Puzzling..
Pete
ORIGINAL: Pete737
Pete
Pete
Pete
If the plane has long line for the gas (e.g. big plane like the Eurosport), then may need to make sure not too much wind get into plane, so align 90% to the wind.Good luck
#32
Pete, I also got the old ECU. I get Propane starts all the time using [link=http://www.dreamworksrc.com/catalog/product_info.php?products_id=774]this valve[/link]. Just used the lowest setting (one click only). This gives like 12-15 PSI. No restrictor needed.
ORIGINAL: Pete737
Pete
ORIGINAL: Pete737
Pete
Pete
Pete
I must say, Using the PM can offboard with the squeeze trigger it has started the first try since Ive been doing it that way, Maybe 5 or 6 starts now, Which is great for the Falcon but apparently the P-60 doesn't like it that much. Id like to find a happy medium.
Pete
