Vintage Tamiya Porsche 956 and Associated RC12L brought back to life
NJ
LOL, will do my best! I cant post pics apparently since I dont have 10 points yet? Not sure how to even get them...
But, ya the tires are shot. Pretty sure they will disintegrate on the first run. I read that I can replace the 2-hole hubs with the 3-hole ones from the RC12L3 which seem to have more tires available. Have to look into it.
I am sure the batteries are toast and I dont even have a charger for them anymore anyway. Probably have to swap them out as well. What kind are you running? I assume I can switch to NiMH?
I remember this was a fun car so hopefully it will work out. I need to get a new body and do a proper paint job - didnt have a clue how to paint back then!
Ernie
Ernie
Ernie
Ernie
NJ
Bummer. I was just going to do 8 single word replies!
I would be happy to keep the original wheels if I could find replacement tires. Either foam or even rubber since I will probably run it on the street. Any idea what they might be?
#31
NJ
I looked too. Pretty slim pickings.
I just ordered a modern day charger. Figure I should start there before investing too much. Maybe I will get lucky and the batteries will come back to life. I also found my old yokomo yz-10 which looks complete and can give that a try at the same time.
Thanks again!
Ernie
Thanks again!
Ernie
#32
Thanks again!
Ernie
Thanks again!
Ernie
#33
NJ
Got the charger and did a quick tests. Everything seems to work! I still need to do a few charge cycles but it looks pretty promising. As soon as I get enough points, I will post some pictures. Also found my old Turbo Ultima, LOL! But I might just sell that. The Yokomo was the best one. I clocked it on the street I remember with a friends help - it did 37 mph. I image the newer buggies today can do better but for back then it was pretty fast.
Ernie
Ernie
#34
NJ
BTW, do they still do "matching" on battery cells? I remember you had to pay big money back then you had to pay alot for packs where they did that because you got maximum capacity. If I have to replace the cells, I need individual ones so I can solider them together so the slip into the chassis slots.
#35
Ernie
Ernie
#36
NJ
One of the battery packs I found had the matching parameters written on each cell - thats what reminded me of it. I remember people paying big money for them. LOL, I was a kid so I couldnt afford it but I actually found this pack on the floor of the hobby shop race track after everyone had left - score! (as an adult I would turn it in of course)
You mentioned LiPo. I suppose those are not compatible with the older setups like these, right? It would require swapping out all of the electronics?
#37
Score for sure! LiPO should be fine for the older stuff, but i would keep to a 2s lipo for the 1/10 buggies. The RC12L i would try a 1s Lipo and see how it goes. The LiPOs put out insane wattage in comparison to the older battery technology. Electrical energy in watts is Volts x Amps. I used to get pretty focused on voltage. I learned that total output wattage is the ticket these days. If you decide to go lipo, dont throw like a 100C rated 2s at the buggies, nor a 100C 1s at the RC12L. Try something in the 20C to 30C range. That shouldnt cause too much trouble. Watch your ball diffs too...The extra power of the Lipo will make em slip alot. You may need to tighten them up. Hope any of this helps...
#38
#39
Check these out Ernie...
https://www.ebay.com/itm/274289661235
Front Associated donuts... Maybe?
Freddy
Freddy
#40
NJ
And yes, very important, you need a LiPO voltage low voltage cutoff / warning buzzer. The Lipos cannot be discharged past a set amount. Damage to the battery will occur. So yes, you do need to add something in with your electronics. Sorry i missed that, i just woke up lol!
Thanks for the info.
Ernie
#41
NJ
Thanks for spotting it Freddy! What I am struggling with now is where I can actually run the rc12l. There are no tracks by mean and running it on the street like it is now would tear it apart. I am wondering if I could maybe get rubber tires and try to get more clearance. Still looking...
#44
NJ
NOW...here are my pics. Still trying to figure out exactly the model number. I believe the RC-12L is the one with fiberglass but the RC-12LW was carbon fiber (we called it graphite back then). But cross-brace above the motor does not match any of the manuals I have found. I dont remember buying it aftermarket but I suppose it is possible.
#45
Thats a nice ride... Yellow Sanyos with red lettering are an excellent example of vintage RC surely. My front tires were similar to yours before i replaced them, and yes they just shredded themselves. The rear motor brace looks stock to me...I didnt know that the T-Bar plate was the white color fiberglass one, like my car, included with the RC12LW, graphite kit...I thought the whole chassis was graphite? Btw, i am not an expert, just observing🙂 I see that its setup with 4 cells and the Tekin ESC. Both the Tamiya Porsche 956 and my RC12L were assembled with 6 cells, and looking back at that, they almost seemed way too powerful. It was / is very easy to loop out with a careless pull of the throttle trigger. I recently installed a new mechanical ESC resistor on the Porsche 956. Set the height of the contacts etc...The action is very linear to full throttle and the brake works nicely as well. Again i have to be careful with the throttle trigger, too much brake and WAZOO! Full throttle reverse action kicks in and totally upsets the car, haha! That RC12L of yours should become an awesome vintage ride for you. Hope you have a great time doing it....freddy
#47
NJ
https://www.associatedelectrics.com/...anuals_setups/
As for the cells, IIRC back then 4 was a popular option of indoor carpet. Even with only 4 cells it still spins if you hammer the throttle off the line.
Manual ESC? You mean kind with a heat resistor and external heat sink? I remember they were pretty inefficient, no?
#48
Ya, I am pretty sure it is all stock. Yep, I always thought it was weird that they did change the T brace to graphite as well. It does match the manual:
