Skymaster F-100
My Feedback: (12)
IA
RE: Skymaster F-100
Anton. Since you posted the pic of the intake going in from the rear of the front section. Which is a no ****ter BUT now show us how you put the wing bolts in with ALL of it put together to include fuel tanks and inlet since the acces to this is behind the fuel tanks.
PUT ALL OF IT TOGETHER AND SHOW US A VIDIEO OF YOU DOING THIS. Don't just put half of it together. ALL OF IT!!!
I'm a very seasoned builder so your not going to make me look like it's my first day out of the house.
respectfully submitted,
My Feedback: (12)
IA
RE: Skymaster F-100
Future items will include pictures to show "THE PROOF" (IF YOU WILL) and a very detailed disciption of the problem since some are taken things out of perspective. These problem areas to include
The tail pipe original mounting issue
speed brake problem
cockpit wont work as from manufacturer (you could jam it in but my way is how it is to be.)
nose gear mont will more than likely break within the first few flights since the back of the mounting plate is only about 3/16 wide.
wing mounting issue.
and I haven't even gotten to the wings yet.
speed brake problem
My Feedback: (12)
IA
RE: Skymaster F-100
And for the record.
I have flew with BV standing directly next to me and have had good a friendship with him and his compnay.
Every thing that I have ever mentioned about Bob and BVM Jets has been 110% positive and I know that he knows that.
This will probably cause some greef, but this product has some very serious and possibly dangerous problems.
#31
My Feedback: (12)
IA
RE: Skymaster F-100
Invertmast made me think of another good point about "why dont you use green loc-tite instead of ca?". Myself as mentioned above am making something to fix the problem at hand.
BUT "WHAT IF" some averag joe decided that he got too much money for x-mas and decided to get one of these. Yea he probably shouldn't but he wants one and can.
One side of the bearing housing took the bearings pretty good and stayed in. the other side was too big and the bearing would just fall out. So I proceeded with the above to fix the problem including making the hole smaller.
BUT "what if" o'l average Joe's kit had the bearing housing that both sides just snapped in and stayed. and he did nothing further to keep them in. There would be a problem in the near future!!!
This is why a manual needs to be written to give exact details of how a full flying stab needs to be put together. These are extremely fast and potentially dangerous planes we're flying. A full flying stab has tremendous amounts of force put on it and needs to be engineered and written in the manual for assymbly
You cant sell these things to anyone with out the knowledge of the amount of force is put on a model jet. but you can!!!
I may seem like an ass hole but I'm also 110% correct on this matter Davids Reeds and guys like him have the capability to build great and structurally sound aircraft, but there are more guys in the jet comunity that don't make the right building decisions than there are who make the correct ones.
I've built numerous BVM jets and have learned what I'll call the correct way to build jets. Close tolerances and attention to detail is as important as putting in your wing bolts.
Unfortunately everyone can purchase a jet that does not have detailed instructions to keep things together.
#33
My Feedback: (37)
RE: Skymaster F-100
looking at the bearing blocks. if the bearing blocks faced each other where the bearing can not fall out, would that not be the proper way to mount them. they probably would require shimming to get them perfect, but they would never fall out, nor would they require a collar. as for wing bolts, i am not sure how skymaster holds them secure, but aviation design has them accesable through the inner gear doors. i would think that would be doable since the fuel tanks would not be in the way. just thinking, barry
#34
My Feedback: (12)
IA
RE: Skymaster F-100
Falcon wings. I had the kit for quit a while before I started it. But no I didn't try to return it.
U2fast I think you have a point there. I believe now that they were put in from the factory incorrectly. Shimming will not be a problem just a little time. This I will do, GREAT CALL!!!!!!
The stabs need to be held on with more than the control horn in my opinion. How are yours held in place? See these could still slip on the control horn.
I think I might look at adding a set screw drilled in a 1/16th or so. That would be better. ANY IDEAS??
My Feedback: (23)
RE: Skymaster F-100
ORIGINAL: DEVILDOG
My Feedback: (12)
IA
RE: Skymaster F-100
After looking at Antons picture that he attached on the first page. My bearing blocks are in wrong from the factory. They should be pointing at each other like u2fast mentioned.
Stone after stone this just keeps getting better.
#37
My Feedback: (12)
IA
RE: Skymaster F-100
I have turned my blocks around. That was fun!!!! they were put on the bulk head at the factory then the bulk head glued in.
here is a picture with both horns forward to the bulk head (look Hard) now look at the stabs. This is how far they are off.
Anton showed me pictures so I'm going to be as detailed to prove my point and to rebutal.
#38
My Feedback: (37)
RE: Skymaster F-100
bummer, i thought it looked like the flat spots were not symetrical in an earlier pic. i am sure anton will take care of this. my experience with skymaster in the past has been a positive one. i am drooling over that t33 too. also, the inlet clearly goes in when the fuse is broke down. sounds like the issue with the inlet and tanks is really the wing bolts. you may try the wheel well or the tab sticking outside the fuse and the bolts come in from the underside of the wing. i hate to see all the mods to get her where she needs to be, but it looks like it will be a hit when you get her there. barry
#40
RE: Skymaster F-100
ORIGINAL: DEVILDOG
About bearing mount. We find out one side is wrongly installed by a worker.We’ll reinforce quality control specially on bearing mount for all future deliveries. We also apologize for inconvenience caused by shortness of manual contents.
If you are not satisfied with the quality, we are willing to replace the kit with new one. If you can fix it, we will send the parts for replacement as your need, and we’ll send you a EV5U to make up your time in fixing issues. We’ll sort out where points are at the shortest time and make your F-100 take off soonest.
I apologise for these problems,
Best regards
Anton
#41
My Feedback: (46)
RE: Skymaster F-100
I think if I ever buy another Skymaster Jet I will deal with Anton direct. I had a lot of design problems with a 1/6.5 F-86 and Jeff was no help, He would not answer e-mails on the though questions. So it left a bad taste in my mouth towards Skymaster Jets. George
#42
RE: Skymaster F-100
Cheers, Alex
#43
My Feedback: (60)
RE: Skymaster F-100
ORIGINAL: pilot tw
Dear SIr,
Best regards
Anton
ORIGINAL: DEVILDOG
Best regards
Anton
Nice gesture Anton!!
Spence
#44
My Feedback: (12)
IA
RE: Skymaster F-100
Anton. Yes, what a nice gesture. I have evry problem pretty much figured out how I'm going to fix them.
I will however take you up on the UP5. Could you send the teflon bushings for the stab assymbly also?
I would like another canopy( the clear part ) if possible. Mine was installed in the canopy frame and there is red marker on them that I can't get off. The frame will be painted but the clear part was installed at the factory which I don't think was supposed to happen on the white version.
WHO DA MAN (Dave) Thanks for posting that AWFUL picture of me !!!!!!
#45
My Feedback: (12)
IA
RE: Skymaster F-100
Aquaskiman.
I agree. When I purchased the aircraft Jeff was happy to take my calls, but now I have called him and E-mailed him. He has not answered me back.
I'll just move onto a company that I have less problems with.
#46
RE: Skymaster F-100
<p class="MsoNormal" style="MARGIN: 0in 0in 10pt"><span style="LINE-HEIGHT: 115%; FONT-FAMILY: "Arial","sans-serif"; FONT-SIZE: 9pt">Scott.
I sent you an email yesterday when you asked about getting a clear canopy and Teflon bushings.
I contacted Skymaster to have them send the parts to you ASAP
Did you not receive my email?
</p></span></p>
</p></span></p>
#47
My Feedback: (164)
RE: Skymaster F-100
ORIGINAL: DEVILDOG
#48
My Feedback: (12)
IA
RE: Skymaster F-100
Jeff. No I did not get an e-mail from you which is suprising since you have always took care of things in the past.
Who Da Man (Dave) Yea you got that hangin on your wall!!!!! Probably in the DART BOARD room!!!!
#49
My Feedback: (164)
RE: Skymaster F-100
ORIGINAL: DEVILDOG
#50
My Feedback: (12)
IA
RE: Skymaster F-100
Anton ( and smaze17) The geture is nice but what will giveing me another F-100 kit do for me? The wing bolts would still be accessed behind the fuel tanks etc etc.
The only thing that I might need if I can't get them to throw the same because of the geometry would be a new set of stabs that have the horn spots in the same locations.
That's why I'll just keep mine. I don't see where I''ll have anything different.
Respectfully submitted.
