still having body roll problems sank it 4 times PLEASE MORE HELP
Get a straight length or rule place it on the underside of your hull if it sits flat and flush with your hull no hook if u can see gaps that could be your problem..if any one can expalin better please feel free to do so... some boats are designed with a bit off hook apparently
The pic below is a crap hull i got from nimriff/pip
Heres a video of my friend terrys OLD one
[sm=47_47.gif][link=http://www.youtube.com/watch?v=ku9aAAu9K0k]48v forabuck [/link][sm=47_47.gif]
ORIGINAL: wayneuk01
got more hook than Abu Hamza
he he he was it your old 48 thats a flower pot or was it no good for that in the end either?
![EEK!](images/smilies/eek.gif)
#31
i'm sure now that i mentioned his name ...martno,martno,martno,.....he'll pop in like beetlejuice.....lol......
#32
ORIGINAL: mopartybob
.....uhhhh......flower pot....??? LOL.....yea,it still is, I was going to send it to mart,but decided to keep him as a friend,rather an enemy....lol.....
Mart
#33
mart
#35
ORIGINAL: martno1fan
Bob
allways room for a new flower pot haha,i know Gary Pope managed to get his sorted by removing the tabs i believe,not sure what else he did but he said they ran ok in the end.Maybe he can share his secret with you guys so you can get yours running
Mart
Mart
Gary got his sorted alright..... He got rid of it and run the sigma from dave neeless to say he was the champion !! Get a feeling he would not of got the same results with his cobra or any cobra i seen one run well & thats garys old one that kurts got
#36
What pisses me off is i spent the last 2 years building this little parts here and there now over 1500 dollars later its crap
Maybe the right side is to sticky on the bottom what if i put sum butter on the bottom make it slide a little beter in the water??
IM JOKING
IM JOKING
#38
That sucks mate sorry you got duped into buying it,just goes to show looks are decieving
.Wayne i agree Gary wouldnt have had the same results but he did tell me the cobras were running well although nothing like the sigma but then again what does
Mart
Mart
#39
so even hook would make it want to turn over on its side??? Like i haev been saying its not pulling or anything but literally likeyour just holding the prop and its flipping over??
so if it has hook how do u fix it if no hook or very little then what.. There really has to be some way to make it stay right side up
#40
did you check the hull yet??? if it is hooked,still no need to....over-react...lol....pull the tabs off,plug those holes,lower that strut,and give it another try....if it don't work out,mart needs a flower pot...
,as for the wifey,wweeeelllll,just say you would like something faster and classier,that reminds you of her...or something to that effect......
, DON'T even think proboat,as you WILL find yourself doin ALOT more than you've done in the last two years.....lol.....[:@]
been there,done that,with my 55ss.......great sport boat after all the work,I've gps'd mine at 51.7 mph,[:-]but NO race boat.......
#41
try putting a small plastic bottled water,on the right side,and se if that helps,if your COG is way off,it will do also as you describe,hell,if it takes two bottles do it,just find what it takes from the listed possible solutions and report back......
don't give up the ship...just yet....
#42
ill do all that when i get home laer check everything
i aslo put it online to sell if i do im buying one from WHH
#43
ORIGINAL: jwblocal701
#45
ON, CANADA
JW, are you for real? Post #1 you said exh. side was going down. 43 replies of help later, you say the carb side is going down. Most of us know what's causing that, but I for one won't bother. Do some research.
#46
Try the things I sent you on the message I sent. And the things others have mentioned, there will be some work needed but it is most likely do-able.
Glenn
Glenn
#47
i meant the right side carb side goes down left exhaust side goes up
#48
ORIGINAL: Slow Motion
#49
sorry bout the confusion ill do that when i get home the trim tabe are mounted about 1/8 inch above the bottom of the boat
I had octura Y567 and now a Prather 270 no diffrence in either as far as shimming it i know what a strut is but mine is seprate pieces so shim the prop or the rudders?? Im using the WHH SPD setup so its not a 1 peice strut with rudders and prop mount all together . So shim the prop so its angled to the exhaust side
SORR for all the confusion im just getting so pisseed especially since i keep fishing for it every time it sinks
Ill do all this when i get home for sure
