Digitech new product need help
My Feedback: (10)
RE: Digitech new product need help
ORIGINAL: Geoff White
Sandor,
One thing I would like to see is a small strip of hard rubber on the mounts. I found one of my P160's was slipping in the mount despite being very tight and I found putting a thin(0.5mm) strip of hard rubber on the inside of the mount solves the issue. It also had the added benefit that the turbine case isn't scratched or marked.
Geoff.
Sandor,
Geoff.
ORIGINAL: petera38
Finally!!!!! [img][/img]
Have been waiting for this in a long time.
Last time I bought one from BVM....not very nice looking and with: Freight, VAT and custom,..... way too expensive!
Regards
/Pete
Regards
/Pete
#31
About time someone did this, the Ramtec compatable clamp is a real pain, Well done Sandor, as Jason said Weldnuts on the bottom of the clamp would be neat, with hex socket head bolts.
Can you just bend the right angle at the end to a small angle say 30deg to start the bend off and leave the rest flat? at least then we would have a starting point to bend from.
Mike
Mike
#32
ORIGINAL: digitech
also we got a request to make a special islandic version:
Just change "Islandic" to "Icelandic" and I wouldn't mind a pre bent version.
#33
Great Idea,
Would also be nice if there was a small slot where you could turn the Turbine 2-3 degrees left or right to adjust the angle to align easier with the thrust tube.
Would have to be in the top section as the welded nuts would be in the bottom half.
Stan
Stan
#34
My Feedback: (10)
ORIGINAL: Selleri
lol, Carsten and crew take good care of me!
Just change ''Islandic'' to ''Icelandic'' and I wouldn't mind a pre bent version.
ORIGINAL: digitech
forgive my knowledge about continents and country,s
i even mix up Cyprus with Malta
#35
My Feedback: (10)
ORIGINAL: Xairflyer
Problem is the colour once it is purple it triples in price
ORIGINAL: petera38
Regards
/Pete
Regards
/Pete
no that only will be applied if the engraving contains BVM.
#36
My Feedback: (10)
ORIGINAL: BaldEagel
Mike
Mike
small rubber strips
will see about the bending
#37
ORIGINAL: digitech
#38
Sandor.
By stronger, i mean maybe a little thicker than standard Jetcat mount, i have a new 120sx, my first Jetcat,
The mount is very soft and bends easy... My Behotec mount is thicker, and seems more strong...
I also like the idea of rubber strips between the clamps and turbine, and welded nuts like the new SX mount has...
Wonderfull to see new products, and what your doing....
Cheers Jeremy.
Cheers Jeremy.
#39
Prebend for me !
I think it still will be possible to ship in big envelope, with just the four 90° bends made.
Not necessary to do the shaping bend for the turbine.
If you have to do the bends yourself, i am afraid the bending radius will vary to much, causing the correct radius/grip around turbine to become to large/small.
/Anders
/Anders
#40
My Feedback: (10)
ORIGINAL: andersaa
Prebend for me !
/Anders
Prebend for me !
/Anders
if the envelope is thicker then 30mm is is considered a package and not regular mail.
about the bending.
no the bends will settle themselfes as soon you fasten them
#41
ORIGINAL: digitech
will see if i can find the stuff and add it to the total package , good idea btw
Sandor,
Geoff.
Sandor,
Geoff.
In the beginning of this turbine era, SimJet provided a double side sticky scotch tape with their mounts. I think it was blue , it coped very well with the moderate casing temps. It was of course wasted as soon as the clamps were opened, but easily removed by thinner and then you just applied a new strip to the inside of the two clamp halves. I'm sure this is the easiest way to keep the mount stay in place, it worked and it's a very cheap solution.
My 2cents
Regards Thomas
#42
ORIGINAL: digitech
Problem is and i am sure it is in all country,s
about the bending.
ORIGINAL: andersaa
Prebend for me !
/Anders
Prebend for me !
/Anders
about the bending.
A maximum letter i.e by Danish definitions is WxLxH <90cm and weight max 2.000g.
Such a letter which easily could hold as Anders suggests a complete mount with only pre-bent "lugs" and all the fancy engraving you could provide, from us in Denmark to you in Holland or ANY EU-country by priority mail for less than 4€.
My knowledge of the Dutch language is zero, but from the TNT page, is it correct your thickness limit by letters is 3,2cm? How about pre-bend the lugs to 70-80deg and keep the letter thickness to a minimum but still keep it simpler for the end user to adjust the last degrees.
Regards Thomas
