jet cat 300 pro or KT g4 320
I had a problem with the starter on my G2 turbine - (respectively with the starter stored in a plastic case and with the starter clutch.) I wonder if my colleague had the same problem or if it was something else. I want to buy a KT 320G4 turbine for my next jet. I want to know what awaits me. I would not like to solve the same problem. I know that the starters on G4 turbines are redesigned, but I don't know to what extent. Whether only a new brushless motor is used and its mounting in an aluminum housing, but the clutch mechanism has remained the same or is also improved. ***winter***
My Feedback: (53)
they been using that starter on the many of there’s for a while now I’m confident in mine...
My Feedback: (15)
Thanks everyone,
I have just bought a 220RXI for a 1/5 scale F16. If I like the generator function ; I may purchase the Jetcat 300 with the generator. The BMS (batt management system) seems in some ways to be great and even better backup but also perhaps a risk if there are smaller batteries that didnt charge. I like the "full scale" feel of starting up and powering up...I hope. I like the 220 rxi with bus for ECU batt and 2 RX batts. Could eliminate field charging.
Merry Christmas,
Dave
Merry Christmas,
Dave
My Feedback: (53)
Thanks everyone,
Merry Christmas,
Dave
Merry Christmas,
Dave
My Feedback: (15)
Yes, the turbine will charge the ECU battery. It seems then that the ECU battery will then provide power for charging the Receiver batteries through the separate BMS module. I will have 2 Rx packs with internal balancing capability. It can charge unbalanced packs but only up to about 90% "full".
Giving it a whirl.
Dave
Giving it a whirl.
Dave
#31
My Feedback: (53)
Giving it a whirl.
Dave
Giving it a whirl.
Dave
thank’s
#32
My Feedback: (15)
I hear you. Could be a problem but with telemetry Id think we would have plenty of warning. I usually like SIMPLE but am trying to embrace some technology as well.
Kind of cool though to take off and land at same batt voltage and capacity 😊
Reports from the field have been pretty positive with the BMS.
D
D
#33
The new starter are brushless now.....lesson, I had to wait 3.5 weeks before my 210 was shipped, so they are in high demand....and I don’t hear on FB that’s there’s a major design problem...some have problem but that go for all model and kind...not just G4
I am interested in whether this problem can also occur with the new G4 turbine series.
If anyone is interested in what the problem was and how I solved it so that it does not recur, I can write details. I'll be happy if it helps someone. ***winter***
#34
My Feedback: (53)
I had a mechanical problem with the starter on my G2 turbine.
#35
As I mentioned, I had a mechanical problem with the K-140G2 turbine starter. On the third takeoff with my new turbine, I made a normal flight over the airfield. I pulled the elevator lever. At the point when the plane began to climb (during a heavy overload) there was a different sound. Like a bumblebee flying through a turbine. Just for a fraction of a second.
After landing, I found out that the turbine cooling was not working. I tried manual operation of the starter, also nothing.
The starter was damaged because the starter clutch touched the turbine cone at full turbine power. This resulted in the destruction of the starter. Torn winding of the starter rotor caused by centrifugal force.
I analyzed why this might have happened and found the following.
- the starter was stored in a plastic case with a "large" mechanical radial clearance. This means that he could move a tenth of a millimeter during the aircraft's sharp maneuvers.
-the starter coupling has no fuse to keep it inserted. The video shows that the clutch moves to its starting position by its own weight.
Add to this the small gap between the starter clutch and the turbine cone (it should be 1-1.5 mm), it can happen that the starter clutch touches the turbine cone during the flight.
I have taken the following measures:
-I have eliminated any mechanical play of the starter in the starter housing.
-I have ensured that the brass ring of the starter clutch cannot move spontaneously. I achieved this by gluing miniature nagnets and a metal ring with Hysol 9462 glue (I attached a few pictures)
-I set the gap between the starter coupling and the starter cone to 1.5 mm.
After a few takeoffs and flying with a lot of overload, everything seems to be fine.
I know my English is not perfect. I believe you understand me. If anyone has had a similar problem, then I believe it will help them.
I also believe that with a number of G4 turbines, the manufacturer has improved the starting mechanism and something similar can no longer happen. ***winter***
Damaged starter
Metal ring and miniature magnets. They have the task of keeping the brass ring of the clutch in the starter off position.
Ready for installation.
Damaged starter
#36
My Feedback: (53)
I have a few KingTech G2 and I pull hard on lots of flight as well seen many do the same....never saw that problem before, I would have sent it to the factory for repair....we do pay for the service...
