Tuning JP Brakes?
My Feedback: (53)
Hi
I am using JP wheels and brakes on a plane that has Electron retracts and uses an RB45 Electron controller for the retracts plus the JP brake controller for the brakes.
I currently have it set up using the JP brake controller on a separate channel but would like to plug the brakes into the RB45 and get rid of the JP controller ( and save a channel ) - has anyone done this ? does it work ?
but if you must...the JP are similar....to the electron, in fact electron doesn’t have specific number for their brakes, neither does JP (unlike the motor which has amps and times)
I have run both in multiple jets too.....and I have to agree with myself .....ok....granted Electron are a bit better and are more progressive but they are heavier and dont make the size I needed ...but JP have rubbish controllers........hence the query
#32
Hi Folks,
I've installed the Xicoy LG15 in my Viperjet using JP ER-120 retracts. Everything works fine but I'm wondering whether I should remove the magnets for better proportionnal braking?
#33
My Feedback: (53)
‘Well if it work fine I wouldn’t touch it, if it’s not proportional then to me it’s not fine and I would removed those magnet, I did on mine when I had them...and frankly it wasn’t a big improvement.
klaasgesk (02-11-2021)
