Breaking in a nitro question
MI
RE: Breaking in a nitro question
IT STARTED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! This is quite possibly on my top 2 greatest feelings of my life. Right up there with my daughter being born. I read elsewhere that I had to push down with the glow ignitor not the back of the car. The second I did this it fired right up. Now that I ran a full tank of fuel, what should I do with it maintenencewise. Do I clean it? There is little fuel droplets in the tank can I leave those in there? Thanks guys for all your help!
Did you finish the break-in procedure? And wow, your first nitro and you happen to buy one of the most expensive ones available.
MI
ORIGINAL: cooldriver385
You need not do any maintenance yet. Continue with breaking it in.
I clean and re-lube my air filters once every five tanks, or when they become clogged. A breakin tank is not going to clog a filter so you'll be fine till you're done with breakin and ready to tune it. As for the fuel droplets..don't sweat it. You'll never get 'em out anyways. I've got half a tank in my TC3 right now, been that way for three or four days. I'll burn that off either tomorrow or friday so I'm not gonna bother draining it. I do recommend you empty the tank if you aren't going to run it for more than a week, though, because the fuel will pull water out of the air. You can do that by simply running the car until it's out of fuel(Best to keep an eye on the level and make sure it's idling when it runs out just for longevity's sake), or you can put the carb line into your fuel squeezy bottle and blow into the pressure line until it stops flowing fuel.
Oh, and if you think this is one of your greatest moments, then just wait till you have it tuned and decide to jam the throttle all the way open with the wheels cranked all the way to one side.
#31
MI
I am wondering if I broke something. Before I started it if I turned one wheel all 4 wheels spun. Now if I turn one wheel only the opposite wheel spins. I didn't drive it and I never hit the throttle. Am I just reading too much into this?
#32
That is normal. Your car has fluid filled gear diffs, as do 99% of them, and I imagine during shipping the fluid in them settled. I'm sure when you started the engine they started spinning pretty quickly, which would redistribute this fluid and loosen them up a tad.
In short: It's nothing to worry about.
#33
MI
So all 4 wheels not spinning when I turn 1 is ok? I am definetly not doubting your knowledge on this, but one minute all four wheels spin when I hand turn one and then the next minute they don't seems pretty drastic.
#35
ORIGINAL: Sigma.40
ORIGINAL: Sigma.40
Can I go start it for another run again or should I wait 'til tomorrow?
#36
MI
ORIGINAL: 378
That's entirely up to you. As long as you can still get the temps up to the right range and you feel safe driving it around you can do it any time of day, any time of year. I usually decide based on whether or not I can see the car and what it's barreling towards.
#37
My Feedback: (14)
Had a few where the pinch was that tight on my aircraft motors. I simply warmed up the cylinder with a heat gun to about 170 or so. that will expand the liner and let you get it started. dont run it stupid sloppy rich either, it will cool the clyinder too much, contract, and possibly break a rod from the pinch getting to tight too fast again.
#38
ORIGINAL: Sigma.40
Ha, that's funny, I meant do I have to wait at all between break-in tanks? I guess my first question did sound kinda stupid
#39
MI
Ok, I am a worryer, but this will be my last post about the 4wd unless it is actually broken. So if I go out and turn it on and lightly pull the throttle, all 4 wheels will spin?
#41
MI
Ok, I ran it again. I flooded the engine once, but then I got it to start. The first time it was running at 230-245 f, but the second time it ran at 175f. I ended up putting my coat sleeve over the head to get it up to 220f. (Its about 36f degrees out now which is 15 degrees colder than earlier).
OK 378, You were completely right. I tapped the throttle a little and all four wheels spun. I am sorry I doubted you, my friend. You don't think I hurt it by tapping the throttle a little ( less than 1/8 throttle twice)?
#42
ORIGINAL: Sigma.40
Perhaps fitting the shell will cover enough fins?
#47
MI
I live in an apartment building with a HUGE usually empty parking lot right out front. Something like that would be a lot of fun.
#48
I'm running an OS .18 CV-RX. The car is nearly uncontrollable if you go over half throttle, and even then it will gladly hit second gear and top out the rev band. While wobbling all over the place from the power. Part of the waywardness is likely the tires I fitted and the lift. I'm running Tamiya's 1.9" rally block tires and I have it about half an inch off the ground. I did so because I don't have much smooth pavement to drive on but plenty of dirt.
Check 'em out here.
When I hit the dirt/snow/etc it's way more controllable but the engine still slings it around like a ragdoll if I'm not careful.
Check 'em out here.
