Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
Another Ziroli DC 3 to be built...
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 11-03-2012, 04:58 PM
Fili
Fili's Avatar
Default RE: Another Ziroli DC 3 to be built...
Are flaps needed, and how are the wings secured?
Old 11-03-2012, 08:43 PM
SIMCO
My Feedback: (33)
SIMCO's Avatar
Depends where you fly . If you fly in a no approach tree ring like me they will help. Long approach cornfield style I don't think it would make that much difference. Looks nice. Wing is bolted on in the 4 corners of the the fusalage.
Old 11-04-2012, 05:04 AM
Fili
Fili's Avatar
SIMCO you"re the best, thanks for your replies. My wing question is about after sliding the wing ends in the center section, is there any way that secures them to the center section? Set screw? hook? velcro? (Lol) or are then snug enough so that they stay on...?
Old 11-04-2012, 07:15 AM
SIMCO
My Feedback: (33)
SIMCO's Avatar
Generally a set screw will hold it. The Ziroli version has an internal hardwood block that is glued to the wing tube socket. It's threaded and the wing tube itself from the panel. If yours doesn't have it. i would suggest a strap arrangement across the 2 halves. IN HARDWOOD. Not some crappy balsa. Mininum hackjob. Might want to pin search the wing socket area at the 2 halves to look for a hardwood block. Maybe an inch or 2 at the most from the root. Also eyeball the socket, might have been done all ready.
Old 11-05-2012, 01:25 PM
Fili
Fili's Avatar
Wheels and fuel tanks in today!
ID:	1817874   Click image for larger version
Old 11-10-2012, 07:33 AM
  #31
Fili
Fili's Avatar
SIMCO, how much run time did you get on the 15oz tanks with the G38s?
Old 11-10-2012, 09:42 PM
  #32
SIMCO
My Feedback: (33)
SIMCO's Avatar
Half power flying about 20 minutes. More than plenty. Also figure in about 2-3 oz just in the fuel line.
Old 11-20-2012, 02:23 PM
  #33
Fili
Fili's Avatar
Center section mounted... Holy Moly she's big!
Old 12-10-2012, 07:18 PM
  #34
2engsout
Hi Guys, I have 42 great flights on my Ziroli DC-3. I was the beta tester for the twinsync for gas engine applications from 2006- 2009. There are certain things that need to be done to it for reliable flight that are not in the book. You can see my DC-3 if you search Youtube videos " DC-3 by Rick Simmons FLt 2". The modifications outlined in the info is quite long so I did'nt post it, but it is a must read for anyone who is building or owns one. Send me a PM with your email and I will send it to you. It includes pics of what I did to the tail wheel. 2engsout
Old 12-10-2012, 08:58 PM
  #35
Props4ever
Its great to see the thread is still going on and more guys are building these awesome ZDc 3 models but you guys need to stop teasing me...I have pushed DC 3 in favor of 1:12 Boeing B747SP right from scratch ground up. Don't take me wrong I still very much enjoy these builds and will build my model eventually......almost lost 2 great deals on all built up ones due to logistic issue between US and Canada....
Old 01-03-2013, 04:44 PM
  #36
Fili
Fili's Avatar
Beginning to glass...
Old 01-03-2013, 06:01 PM
  #37
SIMCO
My Feedback: (33)
SIMCO's Avatar
You will need a wallpaper spreader when you get to the wings. Just grind off the teeth. HA
Old 01-03-2013, 06:25 PM
  #38
Fili
Fili's Avatar
ORIGINAL: SIMCO
Ha! I always used a credit card (expired of course...Lol)
Old 01-19-2013, 09:43 AM
  #39
Fili
Fili's Avatar
Slow but sure.... Progress is progress. I got my pilots fromhttp://www.bestpilots.typepad.com/ awesome, Thanks Lyle! More glassing and sanding...
ID:	1842151   Click image for larger version
Old 01-19-2013, 10:31 AM
  #40
ivves
Hi there.
Here is a video of my Ziroli DC-3. http://www.youtube.com/watch?v=mLGP9JcAPVk Still flying great.
And here is my photoalbum building the DC-3 https://picasaweb.google.com/1141471...C3ZiroliAlbum#
Ivan
Old 01-20-2013, 11:14 AM
  #41
PLANEINSANE1
will resize...file too big he sez...shheeshh
Old 01-20-2013, 11:19 AM
  #42
PLANEINSANE1
My nearly finished dc3....in the Philippines
Old 02-02-2013, 10:20 AM
  #43
Fili
Fili's Avatar
thanks ivves, I've seen your flight on youtube before..Nice!
Cockpit done, nose attached, filling and sanding now. Does anyone have a pick of their engine mounted, I'm going with the G38, but did you guys use the mount?
http://www.bennettbuilt.com/shop/Eng..._BG38_CID.html
ID:	1847141   Click image for larger version
Old 02-03-2013, 07:41 AM
  #44
SIMCO
My Feedback: (33)
SIMCO's Avatar
I used the flat steel plate with the G38. Worked good. You will however need to make aa balsa ring on your firewall for the cowl to fit. Also used the factory exhaust.
ID:	1847501   Click image for larger version
Old 02-06-2013, 05:37 PM
  #45
Fili
Fili's Avatar
Thanks Simco. Looks like that factory exhaust wont stick out as far as the BB muffler..... Moving along with the glassing. Should be able to start panel lines this weekend. Here's my color scheme!
ID:	1848996   Click image for larger version
Old 02-18-2013, 05:10 AM
  #46
Fili
Fili's Avatar
Moving along. I have today off and every second of it is dedicated to thew workshop!
Question! on the wing set screws, plans show they're on the top, what did you guys do? a "headless screw? did you drill a hole thru the wing tube for the screw to pass into? any pics? thanks in advance!
Also, any pics on your throttle linkage?
ID:	1853506   Click image for larger version
Old 02-18-2013, 08:00 AM
  #47
SIMCO
My Feedback: (33)
SIMCO's Avatar
On Ziroli's plans, there was a wing block between the bottom of wing and wing tube out of hardwood. Drill and tap threw the block and tube. I used a socket head screw. If you are going top down, small drill the hole for the screw, CA the area and enlarge the head area so the socket head fits flush. 6/32 is more than enough. Screw is not load bearing. Just keeps the panel from sliding off. Sorry no pic.
Old 02-18-2013, 09:23 AM
  #48
Fili
Fili's Avatar
ORIGINAL: SIMCO
Thanks SIMCO, I would've preferred to go from the bottom, but the builder mounted the hardwood block on the top....
ID:	1853620   Click image for larger version
Old 03-03-2013, 06:31 PM
  #49
Fili
Fili's Avatar
Panel lines started on the fuse. Both engines in, almost completely done with filling.. THEN, A stink bug came out to say hello to my vacuum cleaner today.....
Old 03-03-2013, 06:32 PM
  #50
Fili
Fili's Avatar
is it only me having trouble uploading pics?
