New Wild Hare Edge 540
My Feedback: (506)
Originally posted by Mordib
With GAS, the WildHare would be lighter wingloading larger surface and ALOT more power to weight ratio...
Guess I'll have to sell it off and pick up a ZDZ-50. Or 60...
Since the mule is now complete, can we expect to see some flight reports here sometime soon?
MT
Apples and oranges........
All I was addressing was the wingloading..It was your quote...
If your saying that the wildhare is a better airframe for GAS then you are correct ..ITS BUILT FOR THAT.........
The DP edge id built for the larger glows..READ HIS RECOMMENDATIONS....
Next time stay to the subject..Your comparing apples and oranges..
Side note: Does the wildhare have any diheidral in the wing?
Scott
Scott
My Feedback: (51)
Re: Apples and oranges........
skelock, you crack me up...
YOU were the one who thought it would be a good idea to compare apples to oranges by comparing a snot spewing, $20 a gallon guzzlin', underpowered, overgrown glow plane to a perfectly positioned, entry level gas airplane.
The popularity of gas is growing bigtime.... evident in how many people have "pushed the limits" of that little DP by going gas...
All things EVEN... the Wild Hare Edge offers similar if not better wingloading, a bigger airframe, a lower cost AND allows someone whose on a tight budget purchase a used G62 for chump change and have a rockin' combo for ABOUT the cost of a YS-140 DZ (yuk)engine...
The Great Planes Patty Wagstaff 1/4 scale Extra and the Wild Hare RC Edge are the new breed of planes that make the DP Edge & Extra obsolete.
But hey... just drop the DP stuff... this is a thread about Wild Hare
Scott
Scott
My Feedback: (506)
w00t!
Just got back word from Tom - they should be shipping in mid-November. He also mentioned that they will have a few all-white ones in the first batch.
I'm on the list for one of those.
Got my coveringscheme all picked out already...
Dead-simple to implement. Scale schemes present SO well.
#32
My Feedback: (506)
RE: New Wild Hare Edge 540
ORIGINAL: Scar
...and somebody tell me if the wings are plugin.
[*] Two-piece wing with an aluminum tube.[*] one servo per wing half[*] detachable horizontal stab[*] wings and ailerons come pre-drilled to accept Robart hinge points[*] large hatch extends from behind the canopy to the back of the cowl, and is secured with two bolts through the side of the fuse[*] there will be a few solid-white ARFs. There may possibly some solid-yellow ones.[*] they are expected to begin shipping 15-November.
Just FYI.
#33
My Feedback: (51)
The Wild Hare Edge is a great alternative to the AW & Lanier Edges...
By being just a tad smaller, they fit well in the 50cc category allowing you to keep it light... As you get bigger, you need bigger engines 60-70cc...
Not only that but the price... WH at $399 vs. AW at $749 vs. Lanier at $599...
Bigger does fly better, BUT you have to take in transport issues as well... The Wild Hare should just fit under my taneau cover in the bed of my shortbed truck... I would have issues with the others...
I look at the WH Edge as the perfect "take to the field whenever I can" plane... Easy to transport, cost effective and quality made. Instead of taking a glow plane I can go a bit bigger, gas and no cleanup at the end of a day... If I only have 2 hours to spend at the field, I sure dont want to spend any of it cleaning up my plane...
#34
I like the colors of the Wild Hare more than the other two. They seem alittle drab for $6-700 planes. The advertised wing area of the Aeroworks and the Wild Hare are 1380 and 1390 square inches. And if the AW comes in a pound heavier, it looks like the WH has an advantage.
#35
My Feedback: (50)
I just got an engine for my Edge. I got a great deal on a basically new ZDZ80RV he he. It weighs less than a G62, so weight and balance should not be a problem. I can assure everybody that I do exercise throttle management, so much in fact, that I tend to fly my WH Giles G202/ZDZ80RV to slow. Yehaaa, 50+ lbs of thrust on a 17 lbs plane, now were talking exessive reserves ha ha.
DKjens
DKjens
#38
KY
ORIGINAL: Mordib
Wild Hare Edge
Wingspan: 84"
Length: 76"
Weight: 15-17 lbs. (exactly 17 lbs with G62)
Wing Area: 1390 sq. in.
Wing loading: 25-28 oz per sq. foot
Engine: G62, DA-50, BME 50, Brison 3.2, Moki 2.1 glow
The WildHare with a DA-50 would weigh in at 15.5 lbs with a wingloading of 25.8 oz. per sq. foot.
Wild Hare Edge
Wingspan: 84"
Length: 76"
#39
My Feedback: (51)
It may vary a bit, but if it flies great at 17 lbs with a G62...
The if it came in at 16.5 lbs with a DA-50 it would still rock. The other Wild Hare planes seemed to have comeout around the listed weights, so it should still be close to the 15.5 lbs with a DA-50...
#40
KY
ORIGINAL: Mordib
#41
My Feedback: (51)
I think we get locked into that "Gimme more" or in this case "Gimme Less" conundrum.
Because 17 was obtainable, we wanted 16, then 15, etc...
The Paty Wagstaff doesn't ahve NEAR the wing area and comes in around 16 lbs...
Yet it is VERY popular and has sold by the boatloads, and I've not heard to many people complain about it being too heavy...
This Edge will rock the house at 16-17 lbs, and with some careful building you may very well see 15 lbs...
Use a carbon fiber tailwheel, lithium batteries, a light engine, carbon fiber prop, spinner and landing gear and you may shave almost a lb off the weight...
This IS the first "ultra light wingloading" 50cc plane out there... believe it.
I can't wait! The only problem is that I'll get mine when the snow is just starting to threaten the field...
#42
KY
ORIGINAL: Mordib
#43
OH
[8D]
I not only like my Texas Hurricane, I love flying it!!! This is one of the snappiest airplanes I've seen(flown). Before anyone questions it's abilities, they should grab a tx and fly one. They're great!!!!
#44
KY
ORIGINAL: jbflier
[8D]
[8D]
#45
My Feedback: (51)
BBriBro,
I too am excited about the YAK... NOT because it'll be any lighter but because it's a new and exciting design that appears to perform. you can bet I'll have me one.
If you want a funfly, look at the 3W Xtra Fun with a 3W24... 79" and 10 lbs... It'll fly lighter than that Midwest CAP.
My point was that as a whole, the RC community seems to constantly want MORE performance and durability at LESS weight and cost. People who bought the GP Patty Wagstaff really like it. Most tell of it landing slowly with very good slow flying characteristics. Many guys are using it for 3D while others like the IMAC sequences.
At 78.5" at 16 lbs is 31 oz. per sq. ft.! Some would say that was a pig... YET so many people who own one loves it... enough to buy another after they lost one to a crash!
I happen to own an AeroWorks 33% Edge at 26.75 lbs... and you are right it flies AWESOME. It slows down so slow that people cannot believe it's still flying, looking at times like it's quit forward movement. Yet it's wingloading is 33 oz. per sq. ft.!
Chip Hyde's AW 42% Ultimate offers about 28 oz. per sq. ft.
Carden's 40% Extra comes in at around 32 oz. per sq. ft.
The Wild Hare Edge's should offer a wingloading MUCH better than any of these planes at a quality level I'm excited about.
YET... people seem to want 25 oz. per sq. ft. so they'll fly good.... What's up with that? I suppose we'll need to tell all those guys their planes fly horribly...
My take is that any well designed plane coming in under 30 oz. per sq. ft. will be quite the performer... Lighter is better (to some degree) and again as I mentioned previously... you can opt to get teh Edge even lighter with the use of lightening techniques.
SOOOOO... I don't know what to tell you other than let's just wait. When people start getting their Wild Hare Edges you'll be able to tell what they are coming in at. As I mentioned before Tom has a couple designs out there and they've come in where they were quoted as. I suspect these will too.
I have one of his 35% Extra's here waiting to be assembled... I can't tell you how impressed I am with the quality of construction.
#46
KY
ORIGINAL: BBriBro
The specs are all wonderful, But am I the only one that is concerned that the production models will weigh more than the prototype?? Many ARFs suffer from this, as the wood densities VARY greatly. You still get a well built, well engineered, nice looking model, but made from heavy wood, on an airplane this size, it adds up. I sure hope it really will be 15.5 lbs with a light 50cc engine.
Unfortunately my speculation was correct, I just read this on their website. "Our builder, when selecting aluminum materials for the landing gear and wing tube, had a limited selection compared to what we can get in this country, so to get adequate strength the parts come out slightly heavier "
"We are making available an upgrade package that will lighten the plane somewhat. This package includes a thin wall wing tube made of 6061-t6 seamless certified aircraft grade aluminum tube, and a landing gear made from 2024-t3 aircraft aluminum. The wing tube saves approximately 4 ounces over the standard tube, and the landing gear saves about 6-7 ounces over the standard gear." That must be some mighty beefy stuff they used in the kit. If you can save nearly 3/4 pound and not even use carbon fiber, just a lighter aluminum, I can't weight (pun intended) to feel the gear thats going to be in the box.
#47
OH
According to Joe Hunt at www.downonthedeck.com he already has theWH 540, and will give a review in the near future. At least that's what he claims..........[8D]
#48
OH
Actually, to see the boxed WH Edge 540, go to www.joeycomputers.com and that links to the above web site from Joe Hunt. Sorry about any confusion..........
#49
KY
ORIGINAL: jbflier
