P-47 Thunderbolt Brotherhood (All P-47s Welcome)
Still working on my H9 P-47 It's the older non razorback version.
Converted it to electric power with the adapter from the later version.
Problems with the mechanical retracts and sorting them out are the current issue.
Next will be construction of a battery holder for the 6S 5000mah lipo.
I obtained a second "belly pan", and intend to mount speakers in it.
Still obsessing on how to mount the cowl. I'd like to use magnets and alignment pins.
The fake engine is ready to install when I get the cowl mounting scheme working.
I haven't decided to use the existing method of removing the wing to get to the battery (simpler),
Or do a major mod for top access. A side issue of reorganizing the shop to get rid of clutter, and add
carts to support models and add drawer storage space has slowed things down.
One of the carts is intended to become a battery storage and charge station.
I recently bought a "pistol storage" heavy metal box for lipo battery storage, and need to figure out where and how to mount it.
#33
![Wink](images/icons/icon12.gif)
Hi Guys! I'd like to join the Brotherhood... I built a Top Flite Razorback and put a commemorative covering scheme on it. I love this plane! Have four flights on her and still need to make a few adjustments to get it the way I want it.
Ben
Ben
#42
hi all, can you add me to the list,
I have a T/F Giant Scale Razor back version, G62 for power, beautiful to fly, also an ESM 72in version, 30cc DLE, also great to fly, then a little foamy version, also nice to fly, the 47's have to be one of the nicest models to fly, everyone that has one is happy with it.
Oldtimer.![](http://www.rcuniverse.com/forum/attachment.php?attachmentid=1950020)
Oldtimer.
#45
I need in too!
I have a Byron T-bolt and the Top Flight 60 size kit T-bolt. The Byron still flies with its PurrPowr Sachs 4.2 and Byron 4-blade prop, and we are still using the Byron retracts. It is not a rocket by any stretch of the imagination, but it flies well overall. The TF 60 size is motivated with an old Tower 75 and with Robarts and flaps it has been an a great trainer for stepping up to the bigger warbirds. A few planes down on my building list is to do a TF giant Jug, it will be a few more seasons till that gets built though.
#47
My Feedback: (49)
Just as a comparison from Wikiapedia
http://en.wikipedia.org/wiki/Hawker_Sea_Fury
http://en.wikipedia.org/wiki/Republic_P-47_Thunderbolt
Specifications (FB 11)
![](https://upload.wikimedia.org/wikipedia/commons/thumb/a/a4/Sea_Fury_FB11_Silh.jpg/300px-Sea_Fury_FB11_Silh.jpg)
Data from Hawker's Tempestuous Finale,[SUP][69][/SUP] Flight International[SUP][28][/SUP]
General characteristics
http://en.wikipedia.org/wiki/P-47_Thunderbolt
Specifications (P-47D Thunderbolt)
![](https://upload.wikimedia.org/wikipedia/commons/thumb/0/06/Republic_P-47N_3-side_drawings.PNG/250px-Republic_P-47N_3-side_drawings.PNG)
- Crew: One
- Length: 34 ft 8 in (10.56 m)
- Wingspan: 38 ft 4[SUP]3[/SUP]⁄[SUB]4[/SUB] in (11.69 m)
- Height: 15 ft 10[SUP]1[/SUP]⁄[SUB]2[/SUB] in (4.84 m)
- Wing area: 280 ft[SUP]2[/SUP] (26.01 m[SUP]2[/SUP])
- Empty weight: 9,240 lb (4,191 kg)
- Loaded weight: 12,350 lb (5,602 kg)
- Max. takeoff weight: 14,650 lb (6,645 kg)
- Powerplant: 1 × Bristol Centaurus 18 18-cylinder twin-row radial engine, 2,480 hp (1,850 kW) (take-off)
- Maximum speed: 460 mph (400 knots, 740 km/h) at 18,000 ft (5,500 m)
- Range: 700 mi (609 nmi, 1,126 km)with internal fuel; 1,040 mi (904 nmi, 1,674 km) with two drop tanks
- Service ceiling: 35,800 ft (10,910 m)
- Rate of climb: 4,320 ft/min (21.9 m/s)
- Guns: 4 × 20 mm (.79 in) Hispano Mk V cannon
- Rockets: 12× 3 in (76.2 mm) rockets or
- Bombs: 2,000 lb (907 kg) of bombs
- Crew: 1
- Length: 36 ft 1 in (11.00 m)
- Wingspan: 40 ft 9 in (12.42 m)
- Height: 14 ft 8 in (4.47 m)
- Wing area: 300 ft² (27.87 m²)
- Empty weight: 10,000 lb (4,535 kg)
- Loaded weight: 13,300 lb (6,032 kg)
- Max. takeoff weight: 17,500 lb (7,938 kg)
- Powerplant: 1 × Pratt & Whitney R-2800-59 twin-row radial engine, 2,535 hp (1,890 kW)
- Maximum speed: 433 mph at 30,000 ft (697 km/h at 9,145 m)
- Range: 800 mi combat, 1,800 mi ferry (1,290 km / 2,900 km)
- Service ceiling: 43,000 ft (13,100 m)
- Rate of climb: 3,120 ft/min (15.9 m/s)
- Wing loading: 44.33 lb/ft² ()
- Power/mass: 0.19 hp/lb (238 W/kg)
- 8 × .50 in (12.7 mm) M2 Browning machine guns (3400 rounds)
- Up to 2,500 lb (1,134 kg) of bombs
- 10 × 5 in (127 mm) unguided rockets
#49
My Feedback: (10)
The retracts are Pnuematic, I use Small Pnuematic Air Cylinders to operate the Inner Gear Doors, mounted in the bay that is normally used to mount the Retract Servo to operate mechanical retracts (see photo); the inner Gear Door hinges are offset hinges and the outer Gear Door hinges are the simple nylon piano hinges; the sequencer is an 'Ultra Precision Pnuematic Sequencer'
#50
My Feedback: (49)
Mine work perfectly with the JR 791 Retract Servo and a 4.8 volt regulator.
Been thinking of putting a longer arm and using a regular High Torque Servo and the
servo speed program on my HiTec RCD Aurora 9. Did have one weld break at the scissors
but a buddy with a TIG Welder fixed it for me. Other than that they work fine.
http://www.robart.com/air-models/p-4...erbolt-150-arf
P-47 Thunderbolt 1.50 ARF
Hangar 9 P-47 Thunderbolt 1.50 ARF (Version 1)
Main Gear Part #
![](http://www.robart.com/sites/default/files/imagecache/product_list/products/2575_0.jpg)
630 Series Electric Main Gear Conversion Kit
$199.95
Click Here For More Info
add to cart
Product Number: 630C1M
qty
![](http://www.robart.com/sites/default/files/imagecache/product_list/products/1579_0.jpg)
Hangar 9 P-47 Pneumatic Retracts
$276.95
add to cart
Product Number: 631HA9P47
qty
![](http://www.robart.com/sites/default/files/imagecache/product_list/products/2690_0.jpg)
Hangar 9 P-47 1.50 Electric Retracts
$405.95
add to cart
Product Number: 631HA9P47E
