Redwings Leonardo 3 meter build
Old 06-13-2017, 12:06 PM
Desert Fox 1
Hello All,
RBardin at the controls with no gyro!
Cheers!
Desert Fox 1
Old 06-14-2017, 03:42 PM
RBardin
My Feedback: (27)
RBardin's Avatar
Thanks for doing all the flight vids, Rommel. You do good work! Enjoyed a good weekend of fun & flying!
Rusty
Old 02-24-2018, 05:54 AM
rcpete347
My Feedback: (251)
rcpete347's Avatar
Default Leonardo
Hi all, is their a link to the factory settings for the throws.
Thanks Rcpete
Old 07-12-2018, 01:12 AM
HStv
Hi Thomas.... Can you tell me how to long are push rods , aileron, , flaps, elevators and rudder ...????...thanks in advance...... ( because I´m waiting kit and prefer to buy before all accessories)....
Old 12-30-2018, 12:32 PM
makis
makis's Avatar
Hi guys,
What's the fuel tank capacity? I couldn' t find it anywhere, and nobody mentioned it....
Old 12-30-2018, 05:00 PM
  #31
sewbusy
I'm not sure if Thomas still has his Leonardo. I bought mine used and it is a really great flying aerobatic jet (which is what I wanted to get).
Here are the dimensions (Length) of the pushrods that are on my Leo. These are center to center of the bolts:
Ailerons: 5 7/8 inches.
Elevator: 3 7/8 inches.
Rudder: 5 3/8 inches.
Hope that helps.
Wayne
Old 12-30-2018, 05:08 PM
  #32
sewbusy
Originally Posted by makis
Hi guys,
As far as I know, the tank holds 5 liters of fuel.
Wayne
Old 08-27-2019, 09:26 PM
  #33
yuyuxxx
Default is the www.redwings.it the oficial paga of the leonardo?
is the www.redwings.it the oficial paga of the leonardo? can i buy it from there?
Old 08-28-2019, 05:07 AM
  #34
AngusMc
Be careful, in the past very miss managed and some very unhappy people.
AM
Old 10-27-2020, 01:28 AM
  #35
Cinghiale84
Hi, I'm setting up a Leonardo for a friend but I don't have any manual,Can someone please directing me to a manual or give me the suggested throws please?
Old 10-27-2020, 03:14 AM
  #36
sewbusy
When I was setting up my second Leonardo, I was able to get the Factory throws which are listed below:
Ailerons......20mm
Elevators....20mm
Flaps T/Off 40mm
Flaps Landing 85mm
On my second Leonardo, my settings are quite different and I measured them in degrees:
Left Aileron: 25 degrees up, 19 degrees down
Right Aileron 25 degrees up 17 degrees down
Elevator 14 degrees up 19 degrees down
Flaps T/Off. 14 degrees
Flaps Landing 45 degrees.
Rudder....To your liking.
Here is a link to my Forum Thread on my Jet Aerobatics experience.
https://www.flyinggiants.com/forums/...91#post3036009
Hope this helps
Wayne
Old 10-29-2020, 05:52 AM
  #37
Desert Fox 1
Cheers!
Desert Fox 1
sewbusy (10-29-2020)
Old 10-29-2020, 10:30 AM
  #38
AngusMc
Ailerons......20mm
Elevators....20mm
Flaps T/Off 40mm
Flaps Landing 85mm
Hope this helps
Wayne
Hi Wayne, beautiful jet, I’ve have one and often challenged with landing, which is crazy it’s such an easy jet to fly, I don’t think my landing flaps are down as much, I have the perfect approach and I have had it snap on me at 3 feet ( obviously too slow) and lots of ugly bouncing and certainly a floater. What CG are you set at.
thank you
Angus
Old 10-29-2020, 04:46 PM
  #39
bluelevel
My Feedback: (39)
bluelevel's Avatar
In case someone needs it, I still have a nice CM-Jets kevlar fuel & smoke tank combo that fits a 3m Leonardo. It holds 6l of fuel and 1.5l of smoke oil. I also have a set of custom Revoc wing bags for this plane. Shoot me a PN in case anyone is interested.
Thomas
Old 10-29-2020, 07:21 PM
  #40
sewbusy
thank you
Angus
Hey there Angus, I started off at 30.5cm from the leading edge at the root. Right after the first flight, I realized that it was really nose heavy as To balance it, I had to add 1.5lbs of dead weight, even though I had 4 batteries up front. I also had to push a lot when I was I was inverted. I eventually ended up taking out 1.25 lbs out and she flies very well and stable. You definitely need the 45 degrees of flaps to land her. My technique now is the deploy the gear & first flap to start slowing her down. On the downwind leg, I go to full flaps and keep in a little throttle with a 180 degree nose down turn onto final. That way, she will keep flying and when I make the threshold I cut back to idle. You have to wait for the ground effect & grass or asphalt will happen differently.
I think because you don’t have as much flaps, she will keep floating and when it stalls, she is going to drop. Keep in touch! 👍 BTW.....As Thomas indicated earlier in his thread, the flaps will squeal....I like to hear it as I know it’s deployed, so it doesn’t bother me.
Wayne
Wayne
Old 10-29-2020, 07:36 PM
  #41
sewbusy
Originally Posted by Desert Fox 1
https://youtu.be/w5wtVU07pZA
Cheers!
Desert Fox 1
Thank you very much for the video, Rommel. Hope to be flying with you guys next year at GA Jets!
Old 10-29-2020, 11:08 PM
  #42
Zeeb
My Feedback: (41)
Zeeb's Avatar
Takeoff was a bit iffy trying to get on the centerline but worked.
Flight was quite nice with not many errors, you've been practising and it shows....👍
The landing which is IMHO, the most difficult part of learning to fly jets, was OUt STANDING with that crosswind.
Congrats, looked great overall,
Zeeb
sewbusy (10-30-2020)
Old 10-30-2020, 05:09 AM
  #43
sewbusy
Zeeb
THANKS very much! Yep.... I fly from a grass runway and it is not as apparent (take-off) as it is on an asphalt runway. On my steering (GS200 controller) I used the steering gyro setting that was suggested in another thread here. I actually never experimented with that setting, but found that the crosswind, steering gyro & I were all doing different things on the take-off. I'll try to do better next time.
Wayne
Old 10-31-2020, 12:49 PM
  #44
bluelevel
My Feedback: (39)
bluelevel's Avatar
I have for sale a set of custom wing, rudder & stab bags for the 3.0m Leonardo. These are listed here in the Classifieds section.
Please shoot me a PM in case you're interested.
Old 03-19-2021, 07:50 AM
  #45
Desert Fox 1
Cheers!
Desert Fox 1
Old 03-23-2021, 10:36 AM
  #46
Desert Fox 1
Cheers!
Desert Fox 1
Old 04-04-2021, 10:03 AM
  #47
Desert Fox 1
Cheers!
Desert Fox 1
Old 04-26-2021, 08:46 AM
  #48
Desert Fox 1
Cheers!
Desert Fox 1
Old 05-18-2021, 11:51 AM
  #49
Desert Fox 1
Cheers!
Desert Fox 1
Old 05-23-2021, 09:00 AM
  #50
Desert Fox 1
Cheers!
Desert Fox 1
