Clutch?
Thanks Mistycreek. I spoke with the folks at Bonzi today and they had me going in the same direction. I got the water out of the motor, hooked the pump up correctly and it fired on the second try. Now I just have to cut the flea cable and test drive it. Pretty excited now after the doom and gloom I felt the other day!
Thanks for all the advice everyone. I spoke with the folks at Bonzi yesterday and they were very helpful. Ended up ordering the clutch kit, mount for the Rio and even a new Bonzi prop. Spent a lot more than I wanted but it should be a good project and work out real well. That said I'd love any advice anyone has on the install. It seems like I'm going to have to move the motor up a bit and modify several parts. Thanks!
Best of luck when you take it out for a run.
I doubt the clutch was the only reason they lost. Never seen that but if I ever do I am sure the person running one will be dead last unless all the rest don't make it. Race boats just do not run clutches. Not saying you couldn't run a clutch if you really wanted but people racing usually know it is a waste of horsepower and will add a lot of weight. Two things a racer doesn't want for sure.
The other problem with a clutch is you might as well have the flywheel in the back as the big ole' clutch hanging off the back of a engine doesn't allow it to be mounted down low like it needs to be especially if you were putting one in a hydro even if there was room.
