CARF Mephisto Build thread
Old 12-24-2017, 04:07 AM
JP-1
That is a nice scheme D
Old 12-27-2017, 01:49 AM
Dave Wilshere
Few pictures of my installation, turbine weight will affect where things end up. What ever you will never need weight to make a Mephisto balance! I may swap to slightly smaller Rx packs, the 3350's I have allow 9-10 flights on a charge which would be a really good days flying.
ID:	2248884   Click image for larger version
ID:	2248885   Click image for larger version
ID:	2248886   Click image for larger version
ID:	2248887   Click image for larger version
Old 12-27-2017, 04:39 AM
skymaster68
Hey Dave, how does the 220 handle it?? as you have also seen it with the KT310, is it worth it to go with a 310?? would the new KT260 be more than enough??
Thxs
Cristian
Old 12-27-2017, 07:44 AM
Dave Wilshere
Cristian
Conditions were not the best for either test flight (low cloud base) so feeling the actual power available was not really possible, I guess it depends what you want to do with the model. For general flying, tumbles and Pin Wheel type things, the 220 is more than enough, the 310 fills the ducting and even CARF feel the turbine might be a little restricted without additional byepass air. If the KT 260 is smaller in OA dia then it would be a good choice. Lots of the videos of Marcus flying it has the Frank 250 turbine.
Dave
Old 12-27-2017, 08:40 AM
vquick
My Feedback: (71)
vquick's Avatar
I got a question is this plane can be build with out the trust vector? I'm not a 3d guy but i like this plane and will be a good F3S plane
Old 12-27-2017, 08:44 AM
  #31
RC_MAN
I noticed that you used a MAP UAT. Is this ok?
Old 12-27-2017, 11:39 AM
  #32
Dave Wilshere
Yes, the pipe is an option. Although I don’t think we have done a vector free pipe yet, its possible. CARF guys fly with the vector on all the time...
i test flew mine with it off, only switched it on to test the gyro setting. Flying around and pattern Aeros you hardly notice it.
Yes, MAP Hi Flow with twin inlets. It’s a new version for twin saddle tanks, works perfectly with no air and no noticeable necking at full power. We have run the std Hi flow MAP with 220Rxi and P-200Rx ( both 230N) and no issues
Im not a fan of the hard walled bubble traps that give you little info on the state of you fuel system, I only have to run this at full power periodically and i’ll see if there are any restrictions developing. I have Felt clunks in both Saddle tanks.
Dave
Old 12-27-2017, 02:41 PM
  #33
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
It looks like you power the Electron gear with it's own battery--what size are you using?
Old 12-27-2017, 06:02 PM
  #34
vquick
My Feedback: (71)
vquick's Avatar
Dave
Thanks for your response I was thinking the thrust vectoring was a option but in that case i can probably lock that so i don't have to add those servos do ch limitations
Old 12-28-2017, 12:45 AM
  #35
Dave Wilshere
I did in this case. Its a JetCat P-20 ECU pack I had spare, so 1000mAh 2s. I was going to take power out of the Royal Bus sockets which you can set as 5.9v or 7.4v output, but felt the full 8.4v might be better with the big legs and wheels. Current draw is tiny, so the 1000mAh pack will do more than a weekend flying. After 5 flights the pack is still sitting over 8v
Dave
Old 12-28-2017, 12:50 AM
  #36
Dave Wilshere
You could put the pushrods in and maybe even the servo mounts, lock the rods and use the adjustment to 'tune trim'
Done for get that as the pipe heats it expands so trim changes on the vector. It's a big pipe and it grows more that I expected, CARF say 2mm expansion. I adjusted the pushrods so the vector was square hot, when the model is cool you notice the vector is out slightly.
Old 12-28-2017, 12:53 AM
  #37
Dave Wilshere
Couple of more shots off my phone of the instal. Tanks from the wing opening (centre section will mostly stay attached) and the duct space around the P-220Rxi-B
ID:	2248977   Click image for larger version
Old 12-29-2017, 03:14 PM
  #38
JP-1
Dave was flying his today at Abingdon in less than ideal conditions, however it seemed to be totally locked in.
Alistair Powers
Name:	5J5A4206 (1280x719).jpg
ID:	2249127   Click image for larger version
Name:	5J5A4216 (1280x720).jpg
ID:	2249128   Click image for larger version
Name:	5J5A4217 (1280x720).jpg
ID:	2249129   Click image for larger version
Name:	5J5A4218 (1280x722).jpg
ID:	2249130   Click image for larger version
Name:	5J5A4225 (1280x725).jpg
ID:	2249131   Click image for larger version
Name:	5J5A4237 (1280x724).jpg
ID:	2249132   Click image for larger version
Name:	5J5A4239 (1280x722).jpg
ID:	2249133   Click image for larger version
Name:	5J5A4243 (1280x722).jpg
Old 12-29-2017, 03:18 PM
  #39
JP-1
And a few more
Alistair Powers
Name:	5J5A4259 (1280x723).jpg
ID:	2249135   Click image for larger version
Name:	P1060145 (1280x960).jpg
ID:	2249136   Click image for larger version
Name:	P1060147 (1280x960).jpg
ID:	2249137   Click image for larger version
Name:	P1060150 (1280x960).jpg
ID:	2249138   Click image for larger version
Name:	P1060151 (1280x960).jpg
ID:	2249139   Click image for larger version
Name:	P1060156 (1280x960).jpg
ID:	2249140   Click image for larger version
Name:	P1060161 (1280x960).jpg
ID:	2249141   Click image for larger version
Name:	P1060164 (1280x960).jpg
Name:	P1060168 (1280x960).jpg
ID:	2249143   Click image for larger version
Name:	P1060170 (1280x960).jpg
ID:	2249144   Click image for larger version
Name:	P1060171 (1280x960).jpg
ID:	2249145   Click image for larger version
Name:	P1060177 (1280x960).jpg
ID:	2249146   Click image for larger version
Name:	P1060179 (1280x960).jpg
ID:	2249147   Click image for larger version
Name:	P1060180 (1280x960).jpg
Old 01-05-2018, 02:44 AM
  #40
Dave Wilshere
Couple of people asked about storage. This is the model gear up (still roll on wheels onto the shelf) rear fuse and outer wings off.
The canopy is full length so removing it reduces the height considerably. The Canalizer also unbolts with 2 x M4 cap screws.
ID:	2249977   Click image for larger version
Old 01-07-2018, 08:56 AM
  #41
Dave Wilshere
Another couple of flights today on the Mephisto, too cold to really enjoy-but more valuable set up knowledge. It was quite bumpy in the 15-20mph wind we had. Landing on our 120m grass strip is so easy, its so slow there is little roll out.
Pictures of it in my short wheelbase van which is 2.5m long. Canopy protects the tail cone.
Should have some flying shots in the next couple of days-Pistol Pete had his camera there.
ID:	2250216   Click image for larger version
Old 01-07-2018, 09:25 AM
  #42
Andrew Bird
Andrew Bird's Avatar
Just for anyone ordering - Revoc have worked with CARF to make wing and fuselage covers which take in to account how things like flaps come off and the fus comes apart. I've got a set on the way for mine when it comes and some for Dave to help with moving and storage. They should be pretty helpful to protect from transport and storage rash.
Name:	carf wing bags mefisto  (1 of 2).jpg
ID:	2250220   Click image for larger version
Name:	carf wing bags mefisto  (2 of 2).jpg
Old 01-12-2018, 06:56 AM
  #43
Dave Wilshere
Few pictures from last weekend taken by Pete
Name:	KE2 Meph (Small).JPG
ID:	2250762   Click image for larger version
Name:	KE1 Meph (Small).JPG
ID:	2250763   Click image for larger version
Name:	KE Meph (Small).JPG
ID:	2250764   Click image for larger version
Name:	Low Pass (Small).JPG
Old 01-12-2018, 07:35 AM
  #44
Dave Wilshere
Early flight video at Xmas in horrible conditions
Old 01-12-2018, 02:21 PM
  #45
Dave Wilshere
Few more
ID:	2250849   Click image for larger version
Old 02-12-2018, 02:33 AM
  #46
Dave Wilshere
The first of three customers Mephisto's is here after a shipping mess up. Satin finish looks cool, but will need careful handling.
220 going in this one initially, may add a 300 later for hovering!
ID:	2254374   Click image for larger version
ID:	2254375   Click image for larger version
ID:	2254376   Click image for larger version
ID:	2254377   Click image for larger version
Old 02-12-2018, 07:22 AM
  #47
dubd
dubd's Avatar
Dave, really enjoying seeing your posts about this plane. Can the Cayman scheme be ordered in gloss instead of satin finish?
Old 02-12-2018, 07:52 AM
  #48
Dave Wilshere
Yes. Same as the UF Neon range.
Old 02-12-2018, 07:53 AM
  #49
Dave Wilshere
https://www.youtube.com/watch?v=xGOF...ature=youtu.be
Old 02-13-2018, 03:48 AM
  #50
JP-1
Looks very good D
A. P.
