KingTech Turbines International Barry is your host and will help you with all your Kingtech questions and concerns.
k45
Old 01-09-2018, 06:02 AM
lorenb
Red face
yes, but i dont know wich is the setting to adjust for that..
Old 01-09-2018, 06:26 AM
mauryr
RPM Fuel Ramp K
RPM 100% Starter
These are the 2 parameters that control RPM in the fuel ramp phase.
Looking at the online manual for the K-45 I see the 100% starter is very high, so I guess on this engine is never really reached (the starter turns off at 28k).
The fuel ramp rpm is set to 15k rpm in the manual, but looking at your video, on your engine it should be more like 20k.
You could try raising it from 15k to 17k and see if this additional bump is sufficient to get the RPM through this phase.
In the video the critical phase seems to end at 21k where the combustion alone seems sufficient to accelerate well.
Old 01-11-2018, 01:07 PM
lorenb
no luck with this, im done with this engine
Old 01-11-2018, 07:10 PM
mauryr
Raising starter motor rpm didn't help? Weird.
Did you manage to get a hold of Barry or Dirk?
Old 01-12-2018, 03:04 AM
lorenb
yes, didnt help the only answer o got was from Dirk by email, he told me that maybe is a starter and clutch issue, i took it out and all seems to be good, i dont know.
Old 01-12-2018, 03:09 AM
  #31
gunradd
My Feedback: (9)
gunradd's Avatar
Did the engine come this way out of the box? Never ran? Has this engine ever been crashed or damaged? A miss aligned starter bendix can cause the starter to not disengage and drag the engine causing hotter starts.has the starter ever been replaced?
Old 01-12-2018, 03:15 AM
  #32
lorenb
the engine was working fine from day one, but then installed a FOD screen and in a few days i notice that the starter was having to much vibes so i took it out and find that the shaft bushing was gone. I contact the dealer here in Argentina and he send me another starter motor, (without the clutch), installed the new motor and all this came up, its hang during the fuel ramp... the dealer here the only k45 that sell was the mine, maybe the starter motor is from another model on kingtech turbine and not have the right rpm, for example, when i make the manual cooling, the rpm reach 13k..
Old 01-12-2018, 10:32 AM
  #33
gunradd
My Feedback: (9)
gunradd's Avatar
ok. So you have a starter or clutch issue.
no setting on the ECU will help with this. At this point my advice would be to send it to an authorized service center. That way you know it will be fixed right.
shipping wise not sure if Taiwan or Cali is best but both will be able to get it done quick and have you back flying.
Old 01-13-2018, 10:03 PM
  #34
marquisvns
marquisvns's Avatar
Hi Lorenzo, I was forwarded your video from KingTech and it looked ok, some sputtery high velocity yellow flame is perfectly fine. My apologies for missing out on this thread and your email.
Regards,
Barry
Old 01-14-2018, 06:27 AM
  #35
lorenb
sorry but i think it is no ok, was starting fine and then destroyed the pipe from one day to another, is it a lot of flames and is evident there is a problem with starter clutch.
Old 01-14-2018, 10:30 PM
  #36
marquisvns
marquisvns's Avatar
Please get in touch with your local dealer, otherwise, send it to us here in the US for a service.
Regards,
Barry
Old 01-15-2018, 03:04 AM
  #37
lorenb
perfect, i had send you a pm Barry, Thank you.
Old 01-29-2018, 03:37 AM
  #38
lorenb
Barry, i send you pm, email, etc, still waiting for response, anyway i manage to try with kero and the engine starts fine and clean. i dont know whats wrong with it because was running fine with diesel ... maybe the #106 it is not properly setup for diesel.. who knows.. hope that you see the PM and Mail, there is a lot of information of my setup.
Old 01-29-2018, 01:52 PM
  #39
Dansy
My Feedback: (53)
Dansy's Avatar
He's away in Taiwan then China a the moment......got this from Dirk this morning......
Old 02-02-2018, 03:09 AM
  #40
lorenb
Default settings
Hello guys! can you share your detailed "Start" and "Run" menu? I manage to get some Kerosene and the start is better but still flames, just need that to compare settings.. thank you!
Old 02-02-2018, 03:48 PM
  #41
lorenb
Anybody???
Old 02-02-2018, 06:21 PM
  #42
Dansy
My Feedback: (53)
Dansy's Avatar
send it in, this is futile....
