Sheri's Saturn V.
07-25-2018, 04:44 PM
Now with the retainer cap screwed on.
07-25-2018, 06:47 PM
Next came the wrap for the upper first stage, interstage and lower second stage area. This is simply applied as one piece.
07-25-2018, 07:28 PM
The beginning of scratch building the aft interstage using 0.030 sheet styrene for the base.
07-25-2018, 07:31 PM
And now starting to lay down the 1 mm x 1 mm stringers.
07-25-2018, 07:34 PM
Almost done.
07-26-2018, 07:25 AM
The stringers are all layed down.
07-26-2018, 08:30 PM
Access panel has been made and installed.
07-26-2018, 08:33 PM
These are found on the lower section of the fin shrouds. I believe they act as diversionary air damns. Two on each shroud.
07-27-2018, 08:05 AM
Love your attention to detail with this build
07-27-2018, 03:00 PM
Originally Posted by
dkaniel
Thank you, and there's plenty more coming.
07-27-2018, 03:03 PM
Umbilical connector, vent drain valves and access panel made from sheet and tubular styrene.
07-27-2018, 03:47 PM
These connectors and fill and drain valves go down at the bottom of the first stage.
07-28-2018, 11:38 AM
Vents were penciled in then drilled out on the aft interstage.
07-28-2018, 11:41 AM
Now details are being added to the rocket. This is the top of the second stage.
07-28-2018, 03:46 PM
07-28-2018, 03:51 PM
The lower half at my 'work space' in Starbucks.
07-29-2018, 05:34 PM
Detail for the lower wrap on the third stage.
07-29-2018, 09:19 PM
I'm using Flite Metal on the two APS units. I'll see how this works before determining whether or not I'll switch to paint instead.
07-30-2018, 03:25 PM
Four hold down posts found at the bottom of the first stage.
07-30-2018, 03:27 PM
Umbilical connector and fill valve at the bottom of the second stage.
07-31-2018, 09:42 AM
I used metal etched and resin parts from Oz Mods and Shapeways. Shapeways did the lower radiator panels, everything else is from Oz Mods.
07-31-2018, 09:50 AM
The resin piece that came with the kit was undersized so I created my own from balsa.
07-31-2018, 09:53 AM
This was undersized by 40%. Not happy with the quality from the manufacturer, especially when you've shelled out $450.00 for this. I expect better.
08-03-2018, 07:19 AM
Two portholes drilled out and inserts glued in.
08-04-2018, 10:11 AM
Holes drilled for vents.
Vents installed ready for sanding.
