GJC Aerojet F15C Eagle Build
Old 01-07-2023, 04:15 PM
Agrav8ed
Originally Posted by tp777fo
Well it flew. t/o roll about 300' (no flap) Kinda jumped off the ground but very controllable. cg 7.5 behind le of wing and only required 1-2 clicks of elev trim. Required a bit of aileron trim but didnt investigate why. Was a little nose heavy at first but was expected. Flew about 6 min and landed with one saddle almost full. I landed a little long and hot, and ran off end of runway, Bent main struts and broke one mount, both easily fixed. Will order parts, repair and continue test flight program. Overall it flys well and looks good in the air. Im happy.
Congrats on the maiden. Any idea why you landed long and hot?
Tone
Old 01-07-2023, 04:20 PM
tp777fo
My Feedback: (28)
tp777fo's Avatar
yep, mainly old and stupid. was worried about fuel but didnt need to be. oh yeh, SF16 (fist time with one) worked great. Jet was solid before gyro turned on then super with gyro.
Old 01-11-2023, 05:32 AM
tp777fo
My Feedback: (28)
tp777fo's Avatar
Well, it's tougher than I thought. Minor damage to mounts that wont require remove/replace. I am going to put a backer of G10 on top of mount and replace wood screws with blind nuts and screws. When new struts arrive I will be good to go again.
Old 01-11-2023, 03:03 PM
funflyerf4
Are you moving the cg. back to 7 3/4? Frank.
Old 04-14-2023, 11:03 AM
BarracudaHockey
BarracudaHockey's Avatar
Checking in, thinking of ordering one of these, probably a Jet Cat 160, Powerbox Mercury/isat gyro, and my Core radio.
Old 04-14-2023, 02:10 PM
  #31
Agrav8ed
It's a really nice kit. I think that the 160 may be a bit much for this kit though.
Tone
Old 04-16-2023, 04:38 PM
  #32
dragnova
[QUOTE=Agrav8ed;12769077]It's a really nice kit. I think that the 160 may be a bit much for this kit though.
Tone[/QUOTE
is there a specific a reason why you think a 160 maybe too much?
Old 04-16-2023, 04:48 PM
  #33
dragnova
i know GJC do have some in stock
Old 04-17-2023, 06:20 AM
  #34
Agrav8ed
It can take a 160n but it will be a tight fit and not sure if the additional weight would be worth it.
Tone
Old 04-18-2023, 03:26 AM
  #35
tp777fo
My Feedback: (28)
tp777fo's Avatar
I had a Cheeta 160SE in mine. It fit fine and was not too much power.
Old 04-18-2023, 03:57 AM
  #36
BarracudaHockey
Glad to hear. I prefer putting a Jet Cat in because they are local so I dont have to wait for service if I need it. I just put a P100 in a Pilot Viper and other than the old GSU design I rather like it.
Old 05-14-2023, 06:30 PM
  #37
emart
would like to verify CG the global web site has 150-160 mm ,,Tom I see you stated 7.5" which is about 190mm is this measurement correct ?
Ed
Old 05-15-2023, 07:03 AM
  #38
tp777fo
My Feedback: (28)
tp777fo's Avatar
I have 7.5" and it can go back more. It's hard to get it balanced as everything is in the nose.
Old 05-15-2023, 11:10 AM
  #39
emart
Old 06-05-2023, 07:22 AM
  #40
BarracudaHockey
Out for delivery!!
I feel like a little kid waiting to get up for Christmas morning!
Old 06-05-2023, 10:22 AM
  #41
Agrav8ed
Out for delivery!!
Its a great jet. You will love it. You may have to add a little weight into the nose so build accordingly.
Tone
Old 06-12-2023, 05:44 AM
  #42
tp777fo
My Feedback: (28)
tp777fo's Avatar
Tone,
what is your cg? thanks
Tom
Old 06-12-2023, 07:29 AM
  #43
Agrav8ed
Tone,
Tom
I used the factory CG of 160mm from the leading edge of the wing. Considered moving it back eventually but since it has been flying well, I never got around to experimenting with it. I did experiment with ailerons. I did not like the way it felt and went back to a traditional set up.
Tone
Old 06-12-2023, 07:31 AM
  #44
emart
what do you mean by traditional set up ?
Old 06-12-2023, 07:36 AM
  #45
tp777fo
My Feedback: (28)
tp777fo's Avatar
Old 06-12-2023, 08:30 AM
  #46
Agrav8ed
By traditional set up I mean elevators, ailerons and flaps. Not the tailerons, ailerons and flaps that I tried.
Tone
Old 06-12-2023, 09:51 AM
  #47
emart
thanks I have mine set up the same way did the maiden yesterday and it felt wierd on the ailerons Jet had a starnge wing rock I did have CG at 7.5 " I rebalanced at 160 MM and will try flying again to see if it made a difference
Old 06-12-2023, 10:04 AM
  #48
Agrav8ed
7.5" is a190mm back and seems like it would be a bit tail heavy. But I have never tried it. Please let me know how you like 160mm.
Tone
Old 08-01-2023, 04:01 AM
  #49
funflyerf4
Have you flown it at the 160 mm cg yet? And how was it? Thanks Frank.
Old 08-01-2023, 04:30 PM
  #50
emart
planning on flying it tomorrow will report back how it went
