Ace RC 1/3 Scale Weeks Special (Pitts)
Old 06-17-2005, 11:40 AM
brady_vv
Default RE: Ace RC 1/3 Scale Weeks Special (Pitts)
Ken,
I do not know of an aftermarket alternative for the cowl. Didi you check Fiberglass Specialties? You are right, that cowl is kind of a beast. Do you think that an aftermarket would be lighter? What else did you do to lighten this plane up during your build?
I am finishing up another project and then will dig into this plane. I've decided to do the kermit weeks scheme. That is most likely a ways off though. I am kind of slow, or just too busy. Probably a combination of both.
Brady
Old 06-17-2005, 12:25 PM
Big_Bird
Big_Bird's Avatar
Ken, here is a link to Fiberglass Specialties for the cowl:
http://www.fiberglassspecialtiesinc.com/catalog.htm
Ken
Old 06-18-2005, 10:12 AM
Ken-h
Ken-h's Avatar
Thanks guys for the cowl links. I guess I did not word the question correctly. I do know where to find the cowl, I was wondering about the difference. Big Bird, is that your cowl? Is there a big difference in weight between the two? The one that came with mine must weight 2lbs and is pretty bullet proof.
Brady,
Here are some pictures of the weight reduction I have done. The fuse has been lightened considerably. It was supposed to be solid sheet sides. All the formers have been hollowed and the triple laminated firewall lost about 40% of its weight. Difficult to explain, but each firewall section is completely different to save weight. Also the wing ribs have been hollowed and the wing tips (not completed) have been cut out for a big weight savings. Also have new landing gear on the way.
While not to save weight, the firewall, formers for the cabane, and landing gear block have all been pinned as well. I have also built in flying wire attachment points and plan on using a functional Kevlar wire setup.
I am not planning on this plane to be a 3D plane, just too much extra weight that’s unnecessary. With all the extra work I’ve done I would really hate to stick that cowl on the front of this thing.
Ken
ID:	286614   Click image for larger version
ID:	286615   Click image for larger version
Old 06-18-2005, 11:05 AM
Big_Bird
Big_Bird's Avatar
Ken, I don't know the weight difference. Just a suggestion but you might e-mail them and ask if they would mind weighing their cowl for you. The lightening looks really good.
Ken
Old 03-08-2010, 09:30 AM
mdgtmstng
My Feedback: (17)
mdgtmstng's Avatar
Hi,
Just picked up a 1/3 scale Ace Weeks Special "fixer-upper". The model is complete, with the exception of the interplane struts. No plans, either, so I was wondering if anyone out there had a set of plans that could scan/trace and scan the plan view of one of these struts and email it to me. Also, whereabouts is the CG supposed to be on this model? Finally, is incidence of the top and bottom wings the same?
Thanks for any help.
Ed
[email protected]
Old 02-22-2012, 05:53 AM
  #31
Dickkacz
Do you have pictures of the bottom of the Weeks Special?
Old 02-22-2012, 06:29 AM
  #32
Big_Bird
Big_Bird's Avatar
Sorry, no.
Old 02-22-2012, 06:33 AM
  #33
Dickkacz
Thank You anyway.
Old 10-30-2012, 09:52 AM
  #34
mooredj
My Feedback: (9)
Guys,
Found this pic. It is not a direct bottom picture but I think you can see from the pic that the top wing / tail scheme appears to be repeated on the bottom surfaces. I just picked up one of these planes covered in Coverite but not to the original scheme. I am thinking of recovering to the original scheme and lightening the airframe a bit at the same time.
Old 10-30-2012, 03:56 PM
  #35
gravityking
My Feedback: (19)
gravityking's Avatar
Awesome mooredj! Will be using that when I get to covering mine.
Really would appreciate you posting your lightnening process. I would like to incorperate it into my build.
Craig
Old 10-31-2012, 04:27 PM
  #36
mooredj
My Feedback: (9)
GravityKing Look about six posts up. I was going to start with some of the ideas by Ken-h and see what that led to. I might not get to this for a couple of months. I was also looking for a set of plans and instructions if anyone still has a set they would either sell or copy for me.
Old 10-31-2012, 07:03 PM
  #37
gravityking
My Feedback: (19)
You are in luck! I haven't started mine yet and it came with an extra set of instructions, which aren't much, you could have and for the expense of it all I would be glad to copy the plans for you.
I have no idea the cost or for sure where to get it done. We have a Staples here but other than that civilization is 30 miles away. I could check into it.
Have to finish the project I have going. Just been rounding up engine and parts and doing research.
Old 11-01-2012, 06:46 PM
  #38
mooredj
My Feedback: (9)
After I posted the request for plans above I was looking on Ebay and came up with this: http://www.ebay.com/itm/360502938646...84.m1423.l2649
These are the correct plans and instructions. The plans are made by Miles Reed, which the ACE kit was built off of. I also figured out that I have the instructions - not much there but I was thinking of scanning the 3-view at the back of the instructions and posting it here.
Thanks for the offer on making a copy for me. I appreciate it. I figure I might go the Ebay route as the templates are included and I have an extra Fiberglass Specialties cowl that came with the plane. If I ever get the itch to build another one it might come in handy to have the templates. Fiberglass Specialties also caries the canopy and wheel pants.
Old 11-02-2012, 06:58 AM
  #39
gravityking
My Feedback: (19)
Good for you. eBay is the greatest place to find off the wall stuff.
I will be buying a glass cowl for mine when I get to the build so if you decide to get rid of yours let me know.
Old 11-02-2012, 02:49 PM
  #40
Bobt2
just saw this thread, i started on e 18 years ago. all framed out and than lost interest. hmmmmmm. who knows
Old 11-02-2012, 03:49 PM
  #41
gravityking
My Feedback: (19)
18 years! Is the glue still holding?   Build season is here and it's a really awesome plane...............
Old 11-09-2012, 04:44 PM
  #42
Bobt2
funny, after all this time the airframe is fine, but i just lost the plans to a flood caused by sandy
Old 11-09-2012, 08:55 PM
  #43
gravityking
My Feedback: (19)
I hope that's all you lost.
I can make you the same offer as I did for mooredj or check with him when he gets the ones he ordered from eBay for authenticity.
Old 12-04-2012, 08:54 AM
  #44
mooredj
My Feedback: (9)
The plans off of eBay are the real deal. I got my copy and for what you are getting it is a good price. A copy of the original plans used to construct the ACE kit. The CG point is on the plans. I also can scan a copy of the instructions if needed and pass them on.
Dave
Old 12-26-2013, 07:59 PM
  #45
COBRA039
I know this is an old thread but I am in desperate need of the fuselage plans for this as my kit had two sets of wing plans and no fuse page. It is impossible to build it without them. Ace no longer exists and Thunder Tiger that purchased them has wing plans only. Cheers Garry.
Old 12-26-2013, 10:48 PM
  #46
foodstick
foodstick's Avatar
you better jump on this http://www.ebay.com/itm/ACE-R-C-WEEK...item19e6b79984
Old 04-26-2014, 06:34 AM
  #47
gordon_mcln
Does anyone have a set of plans for the weeks special or know where they are available?
Thanks-
Gordon
Old 11-24-2014, 06:46 PM
  #48
speedbuzzer
hi Bob I have one that I will be selling need's a littel work on the tail and one wing tip has a miller cutom 55 cc gas like to get 350.00 out of it I can send pic my email id [email protected]
Old 06-19-2024, 12:08 AM
  #49
Super Nel
Hi all
i know this is a old thread but your input would be appreciated
I just recently got hold of this kit and want to start with assembly
I have see that okes recommended 1 servo per aileron to eliminate aileron flutter. Any pictures available
Any building advice and recommendations would be appreciated
