DA-100 performance problems
RE: DA-100 performance problems
My flying buddy and I have identical scratch built Edges - same 24 # weight - same DA-100 engines. Outside of mine looking better than his, I run a 27x10 prop, he runs a 26x10. Both engines run flawless, but I will admit to you guys that I like the way his DA performs better than mine. I won't admit it to him, but next time out, I am changing to a 26x10 Mejzlik.
you can have your cake and eat it too! this weekend I went to a fun fly in jackson wyoming 6000' flying my 27lb comp arf yak w da100 on escomposites gas tuned mufflers with mezlic 26x10. 7480rpm - I was excellerating on the way up at just above 1/2 throttle. the big test was a standing verticle 8 from the bottom - I push the stick all the way forward - was afraid my da100 would blow the wings off pulling hard over the top. there were two other da100 airplanes both with standard deflectors - one had 27x10 the other 28x10. at full throttle they were stalling out on verticle climbs. when you go up in elevation I generally lean the engine about a 1/4 but with only 30 flights still on break in I just left it rich - It was pouring out smoke like a ys140. a lean setting would have given another 300rpm or so. everyone commented how quiet - there is no noise comming from pipes. throttle response is smooth and linear - engine is running cool and there is no heat buildup inside fuse.
This proves what you have been saying for a long time. I have a question, I just bought a ZDZ Super 80 (On sale now on Troy Built models for $675 ) and was wondering if a 25x10 was a better choice than the 26x10 (or maybe the new mejzlik 26x8) to get the best power out of the engine?. The reason for asking is that if a 26x10 is the right choice for a DA100 maybe a little less prop is better on the 80. Has anybody else tried a 25x10 on a ZDZ 80 (I don´t know if Mejzlik has a 25x10 size).
Andres
The non piped ZDZ80J using -say a in cowl muffler - will give best performance if you avoid overloading it - buy a 26x12 wood whtever -- cut it to 25" and smooth and sweep the tips - a good quiet setup
buy Mejzlic 26x10/8 -any prop that lets it easily run 6500 on the ground a tad rich
NEVER prop it for screamin in level flight - that is too lean -on any prop
fwiw - the 26x10 mejzlic is only about 25.5" long
I use the ZM 26x12 -and a header and JMB can - quiet great running setup - for super snortin --the Skorepa 26x10 or Mejzlic 26x10
On full pipe the reves go up to 7300 on the ground -set right for full power on up lines - this gives me 74--7500 in level flight -- with a well broken in engine
don't force it!
let it rev at least for a few gallons and by all means baffle it and keep it cool
don't force it!
In fact i was thinking about baffling the DA. At the moment the cowl is just open in the normal places at the front (inlets either side of the prop driver). And most of the bottom of the cowl is scooped open (about 5:1 ratio outlet to inlet for air through). However im not sure where i should put the baffles. Just behind the cylinder heads, and underneath? I would welcome and ideas. Ive been told extra cooling could get another 300rpm or so out of it.
you are on the right track-
but rather than look for 300 rpm improvement --think of it as NOT loosing 300 rpm
anyone who has run a bunch of engines can tell you taht a cool engine vs a hot engine - can loose up to darn near 1000rpm (failure mode) and 300 loss is common .
so
A :forget the big props that is all BULL S HIT if you want more power
B: rework the back edge of the cowl with a lip or lips to create spoilers
C: try to direcet every last bit of inlet air thru th fins --including wrapping the flow around the backside of the fins
Having done this - it is worth it - that is the hot spot on any twin
Some will state that "their DA don't need none of that there stuff"
BULL-again
all engines benifit from it and the work needed to induce suction thru the cowl is well worth it
remember - you can not blow air thru the cowl -it has to be a flow of high to low pressure .
so
BULL-again
If anyone has tried baffling a twin i would be very interested in install photos. Im going to give this one a try! Thx
#33
That setup is good in many cases but does not maximize baffling.
Ideally - the air is held close to the cylinder and is pulled thru due to low pressure outlet(s) in aft section of cowl
The wood is 1/64 ply - the lip on the bottm of cowl creates a turbulance to make low pressure area in cowl
the large top sheet blocks air from flowingover top inside cowl - ALL air has to go thru fins
the lower baffle is attached to cowl and sets just at lower cyl barrel level- and surrounds the end of the head
The low pressure area (the opening with the lip at the bottom) now must pul thru the fins - no other source of air
This is how full scale really works
On the latest YAK 55 by CF- there are large working louvers all around rear of cowl - using these plus a good shield up front and a couple of plates -- you should be able to work the crap out of your engine with no significant temp rise
temp rise = serious power LOSS
#35
One thing missing here is to move the air inlets out away from the spinner and the center of the prop. The air flow there is stagnant at best and often reversed and flowing OUT of the cowl opening. The way to do it is like the Lancair cowls, they have an inlet well spaced out from the center and they cool very well (200+hp from two very small openings). This tip came from John Roncz at the EAA Oskosh fly-in in '95, not my own observation. Air also seems to like sharp edged protruding nozzle like openings for recovering pressure from velocity, as done on many F1 cars and MotoGP race bikes. The Lancair's also do this part well.
Mark
Mark
#36
ORIGINAL: mmattockx
Mark
Mark
Many modelers do the YAK with the spinner right up against the cowl because they think it looks better
- bad idea-
#37
Having looked at my cap inside the cowl the trick here is to manage to get the baffles in the very tight space and still be able to remove and replace the cowl without difficulty or breaking anything. I can see this is getting closer and closer to full size practice and actually it would be better if the cowl was split in half and the top was removable seperately rather than removable with the screws around the rear into the fuz. The commercial kit and arf manufacturers should take note and either build in some baffling or at least the provision to easily install baffling. After all, my jet turbine aircraft arf's come with bypasses and fittings for tail pipes ready installed which is almost the same thing.
#38
ORIGINAL: amjflyer
Mark
#40
That should be a hot setup from what i have heard. 7k rpm +. HOwever i have also heard that the KS canisters have a tendency to 'burn out', but that was on a 200cc setup not a DA100. Could also be becuase the guy was running them too lean without sufficent pipe cooling.
#41
Ok, posting a follow up to this issue as i have learned some things and made some progress and it may be useful to anyone else out there.
When I started the thread static rpm was about 4650 on a MZ 28x10, in air performance seemed only slightly better im guessing 4800 or so, very poor. The ignition was foud to be faulty and this also exhibited problems with one cylinder running only on initial start.
New ignition installed (engine also a little more run in by 3 gallons) - new static rpm check 5000rpm, so a 350rpm improvement straight off.
Changed prop to Mejlik 27x10 - new static rpm check 5500rpm, ok so reduce prop dia. you would expect some improvement, but also throttling seemed to improve as well.
Added engine baffling (as per Dick Hanson recommendations etc) - static rpm on the 27x10 still 5500, hmmm, ok so maybe baffling only makes a difference in the air after all it is about oncoming airflow. So fly it and see...Wow!!! in the air it seems like its gained 300-500rpm alot better, really, alot.
Finally, changed fuel to high octane petrol (super unleaded Shell Optimax in the UK) and added high octane additive (Millers Oil lead replacement and octane booster) - wow again, static rpm 5800, in the air better still.
So after all this I now have a model that I can do some really challenging aerobatics with at last! Ive concluded that i can only better this by changing the well baffled custom silencer ive got, but that would mess up a nice model so i willl live with it where it is. I might try to open up the baffles inside the custom muffler but that may not be possible, it certainly wont be easy.
#43
My Feedback: (37)
NC
Have you ever checked or played with the timing? Maybe it's too far advanced? A significant RPM increase just from raising the octane level is normally (in my experience) almost contradictory.
#44
Change timing by just moving the sensor up and down?
If i have the theory right Octane level should increase rpm since it increases energy in the detonation but does not affect the timing as this is electronically controlled. ie more bang more torque + rpm on same prop. Its not the same as increasing nitro in glow engines which on two strokes invariably does nothing or kills rpm as it changes the timing (since there is no timed ignition on a glow). However on glow four strokes it does invariably increase power but not necessarily rpm (more likely torque, so swings bigger prop). But again engines have to be designed for it as it advances timing, hence why YS / Saito run so well with high nitro.
Actually both the fuel and additive manufacturers claim it also keeps the plugs clean, we shall see...
#45
Actually higher octane gas contains less BTU's (energy) then lower octane gas. To take advantage and see an increase in power with high test you need to increase compression and/or adjust timing.
Terry at CH ignition ran some tests and found no improvement with it and the engines ran a little hotter with a stock set-up.
I could see using it if you are running a tuned exhaust, but that would be the only time.
#47
My Feedback: (25)
AR
Interesting, well im definitely getting a 300rpm boost with it. Must be something about my setup.
Regardless... you should be getting mid 6k with that prop.
#48
TN
Straight out of the box without touching the needles mine was spinning a PT Models 27x10 at 5993. Haven't tach'd it yet since I leaned it up a little on the low end but I am positive its over 6k now. If you're not getting even 5900 I agree, retard the spark and go back to lower octane gas.
#49
Im trying to do this scientifically one thing at a time. So next thing will be to either a) try a different exhaust sys (if i can loan one from somewhere) or b) send exhaust to specialists to be 'opened up a bit', as DA think the muffler might be over baffled. After doing that if rpm is still too low i will twiddle with timing...thanks for the feedback.
#50
My Feedback: (25)
AR
Geez... I think I'd do the cheaper option first (timing).
Actually, I'd send it in to DA for a free check-up.
Anyone else?
(BTW... I'm getting 6,500 RPM on stock exhuast with a BollyWood 27x10, 13 gallons through motor... tached after flight. It's not tuned lean at all... nice plug color, no sagging, pulls like stink!)
Anyone else?
