Who makes the best smoke pump?
My Feedback: (20)
RE: Who makes the best smoke pump?
Are you sure it doesn't pull the oil from the smoke tank and push it into the muffler. A pump has a low pressure (suction) and a high pressure (discharge) end. In effect, pull, push.
CO
One pump or two
I have a DA 150 MTW cans with flex headers. Will one pump supply both cans or do I need two pumps? Where should I inject the smoke in the headers or the cans? cans didn't come with nipple instaled is a coil neccesary? What size tank should I use? IS it ok to use two small tanks rather than one large one?
Thanks for the help Chris
