Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
1/3 Scale J3 Cub - Engine Recomendation
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 04-11-2009, 08:35 PM
airbornrc
My Feedback: (9)
Default RE: 1/3 Scale J3 Cub - Engine Recomendation
Mine was purchased new as a short block. It is a replacement engine for a back pack blower. It has quite a bit of time on it now and I am very happy with it. Even on floats at about 30 pounds it has plenty of power.
Old 04-05-2011, 04:35 PM
plowboy1966
Anyone still flying this plane? I am about to start a build and was wondering if there was anything I should watch out for? I'll be running a DLE55, I hope that enough to make her fun. She is actually for my 11 year old daughter!
Old 04-05-2011, 06:40 PM
Donairplane
Bob, WWW.toni-clark.com has a intake manifold to side mount your carb, no hole cutting.
carb stays inside cowl. Also has some good looking mufflers for cubs. Go to cataloque. Don.
Old 07-04-2011, 02:29 PM
captinjohn
ORIGINAL: huey-pilot
My 1/3 scale cub was the Hazel Sig clipped version with a 120 inch wing span. The plane weighed 27 pounds and flew very well with a Kavan 50.
Do you have any photos of your 1/3 scale cub? I have a Kavan 50 with not even a total run time of 1 hour. Thanks Very Much
Capt,n
Old 06-15-2012, 06:37 AM
labebe
Sirs, I am finishing my model tech 1/3 scale J3 Cub, planning to inbstall the OS MAX 4 cylinder pegasus engine, do you think it will fly underpower??? What shoul I do, going on or change the engine
Alex
Old 06-16-2012, 04:40 PM
  #31
LearnedInUk
My Feedback: (29)
LearnedInUk's Avatar
Anyone have any experiences with the World Models version? [link]http://ecsvr.com/abm/shopexd.asp?id=2254[/link]
Old 06-17-2012, 12:22 PM
  #32
STUKA BARRY
I've got a Proctor 1/3 scale with a BUSA Super Cub cowl that completely hides the GT-80. Its painted up in Luftwaffe colors (would you expect anything less from me). I'm still waiting on the spinner hub from True Turn. I'm having trouble finding a 1/3 scale German WWII pilot, any help would be appreciated. My prop is the Xoar 24X10 Lance style and it looks great, cant wait to get it in the air.
Old 04-24-2013, 12:45 AM
  #33
shakeelsid
shakeelsid's Avatar
Bought this Cub second hand from a club mate - what a kit - barnyard industrial engineering - it had lots of tinkering in the last few years of its life, but does not seem like it flew much, if any at all. I took out over 2 lbs of dead weight, installed a 75cc King engine, and made a set of carbon landing gear, both main and tail. Was way tail-heavy even with the big engine upfront, so I ended up adjusting the CG by installing a pull pull rudder and moving the servo in the cabin area. I also installed a new set of carbon pushrods all around.
After my first phase of modifications it weights in at 28 lbs with reserve fuel. It now hovers at little over half throttle on a 25-8.
Look at the picture, this carbon landing gear weighs 320 grams with axles, saves over 400 grams over the stock. I tested it to 4 G's at 13 kg, and my kids tested it by riding it like a push cart around the house.
One of the finest flying Cubs I have ever had - and I have had a few
Old 04-25-2013, 10:58 AM
  #34
hanko
If i were doing the 1/3 cub thing again, for scale I would go with that 57 cc saito gas 4 stroke, unless you were on floats then you should so something else
Old 04-27-2013, 07:48 AM
  #35
ross.felix
Here is a World Models Cub with a 106 3W ??
http://www.flickr.com/photos/rossfel...7623718322944/
Hanging from the prop
http://www.flickr.com/photos/rossfel...57626255321606
Old 04-30-2013, 03:37 PM
  #36
hanko
ORIGINAL: plowboy1966
you will have a CG problem with DLE 55. Not enough up front
Old 05-01-2013, 06:22 AM
  #37
MX240
MX240's Avatar
Super Cub with G-62. How I transport to my own flying field out behind the barn.
Old 05-06-2013, 01:48 PM
  #38
shakeelsid
shakeelsid's Avatar
yea sure it will sound fantastic with a Saito, but these days I like to mix my flying - so my current cub spends as much time in harrier, hover and flat spins as much in straight and level - so 57 four stroke is about half the power I would really like - as it is 75cc two stroke on a 28lbs model is on the low side for my comfort.
Old 06-04-2013, 05:54 AM
  #39
David DeWitt
My Feedback: (289)
David DeWitt's Avatar
I have a DLE 55 in my Sig Super Cub, at 34 lbs has plenty of power. Had to add 2 lbs of weight to the firewall to balance. Here is a video of the maiden flight.
http://youtu.be/P0Tj0zUp9P4
Old 06-23-2013, 12:27 AM
  #40
shakeelsid
shakeelsid's Avatar
Here is a video of mine, 4th flight after total crash and rebuild - in this video carb not set right so engine was running rough in knife-edge - my regular routine includes knife-edge stall turns, flat spins, hovers, harriers and a vertical climb-out. I also like to fly it NOE 2ft off the ground and trees around the field in figure 8s - Very easy plane to fly.
https://www.youtube.com/watch?NR=1&f...&v=dPdfwiUwQOk
ID:	1894220   Click image for larger version
ID:	1894221   Click image for larger version
Old 06-24-2013, 04:32 PM
  #41
hanko
wouldnt it be easier to taxi it to the runway, instead of holding the rudder?
Old 07-03-2013, 12:41 AM
  #42
shakeelsid
shakeelsid's Avatar
Yes, you are right - at most places, but not at that field. Very peculiar vine like grass at this location, would grab onto to the tail wheel and possibly damage the mounting - had to lift the tail up to taxi
Old 07-06-2013, 07:35 PM
  #43
labebe
Fellows, where can I buy from a Model Tech 1/3 scale Cub Cowling replacement??
I need to by a new one
Alex
Old 07-06-2013, 11:25 PM
  #44
cubcrasher
ORIGINAL: labebe
Alex
Try Hobby People they use to sell that plane.
Old 07-08-2013, 04:12 PM
  #45
dadragon
the 40 to 50 twins would be good choices,you dont need a gang of ponys because they like to float around.on a 10 mph head wind mine wanted to just sit out there and hover.
Old 07-08-2013, 04:16 PM
  #46
labebe
Hobby People, out of stock, any other ideas????
I need to replace the cowling (Model Tch 1/3 scale J3 Cub)
Old 07-14-2013, 12:29 AM
  #47
Pelle Gris
Pelle Gris's Avatar
I maidened my 1:3 scale BUSA Super Cub the other day. It´s perfectly powered by a Zenoah GT-80, swinging either a Fiala 26x10 or 27x8. Takeoff weight, including 33,8 oz fuel, is 46,2 lb.
At full power it will climb at about a 30 degree angle, and "Tundra Cub takeoffs" are almost vertical after a 60ft takeoff run. :-)
Old 09-04-2022, 05:37 AM
  #48
bigben
My Feedback: (24)
Default Cub Performance
Alex
hello Alex,
i am about to finish the same plane and engine OS FF 320, as yours, the plane I found needed lots of clean up but was sound.
i wonder how your engine ran, best prop you found to use and available power. Any comments you can add are appreciated.
Ben
Old 09-04-2022, 05:42 AM
  #49
bigben
My Feedback: (24)
Alex
while this post is old the best answer is Fiberglass Specialties for new cowls.
Old 12-03-2022, 09:09 AM
  #50
dhal22
I was about to say that. Or Don at Rcaiir.com
