View Poll Results: A poll
Voters: 141. You may not vote on this poll
The Official - Tamiya F103 - Racing Thread
#35
RE: The Official - Tamiya F103GT - Racing Thread
Here is the setup I am currently running. I will update it as I change my set up.
Front Tires - #4495 HPI X-Pattern Radial Belted Tire (Standard 26mm) (Pro Compound)
Rear Tires - #4495 HPI X-Pattern Radial Belted Tire (Standard 26mm) (Pro Compound)
Shock - Tamiya TRF
ESC - Mamba Max
Motor - Nemesis 540 13S
Shell - Opel Astra
Front Springs - Gold
Kawada 98T Spur 64 pitch
HPI 22T pinion 64 pitch
3 Racing Motor Mount
ABC Diffuser
1 degree toe out
Orion 3200 Lipo 2S1P
Shock - Tamiya TRF
ESC - Mamba Max
Shell - Opel Astra
ABC Diffuser
1 degree toe out
#36
I have been thinking of modding the servo saver to run ball studs on it.
I also thought about running 31mm tires in the rear, expect I havent found a tread pattern I like yet. I can't seem to find the X pattern in 31mm from HPI.
Can anyone tell me what I need to connect the wire on my cooling fan too? Should I be connecting them to the channel 3 in my receiver, or the batter slot or what?
#38
ORIGINAL: rc monkey
Connect the fan to the battery slot. All those F103GT's look amazing!
#39
wow! them Ferrari and 7UP bodies are among the best ive seen, no offence, but are they all yours? or are you just posting them as they are F103 GT bodies?
#40
I am just posting them. Mine is the first F103GT, the red and white Opel Astra (Touring Car Body). The first two pictures is my car.
#41
ORIGINAL: lee172
Also notice in thouse paint job, they are a pretty simple scheme. The have really good sticker layout and lots of thought went into it. They all look great though.
#42
nice courages there, i'll post some pix of my GT with its shells when i have a chance, and find my digi-cam,
i race my GT, and i have-to say AMAZING chassis,
although i noticed something, With my Toyota GT-one shell, it was staying planted to the floor through turns,
then on saturday when i put my courage shell on, the back end was bouncing about all over the place, and as a result i came 3rd, 3rd, 3rd, 3rd, 2nd
hey guys, is there any way to make a quick release battery holder for the F103GT?
#43
ORIGINAL: rcluke
I would love to seem some pix of your F103GT.
I was thinking the same thing about the battery holder, because I actually broke one of the "d" parts (the part you clip the battery in) and had to order new parts. Since my old parts are broken I'll see what I can rig with those.
#44
ORIGINAL: thaphillips
Thats because the Toyota GT one shell has a lot of downforce. People where I race look down on wedge shells and ask that I not race them. My solution was to add a ABC Diffuser and a big rear wing to help generate more down force! HAH!
ORIGINAL: rcluke
thanks , keep us posted on the battery holder
there are some pix of my gt here
ill get some of the painted courage shell soon[link=http://www.rcuniverse.com/forum/m_4921491/mpage_29/key_/tm.htm]click for pix, then scroll to the bottom of the page[/link]
#45
What post location are you using? The courage standard F103GT or the post relocation kit?
Personally I don't like the post relocation kit, because it doesn't allow you to run a heatsink on your motor, or allow you to change your motor easily.
#46
and with the gt-one shell, I'm using the standard F103GT posts, just with the large black bit cut down
#48
I have the relo kit and heatsink... you just need a low profile heatsink..
Like this
#50
i have this heatsink on mine, only black, seems to keep the motor cooler
http://www.rcmart.com/catalog/produc...ducts_id=15819
