spe 40
RE: spe 40
My spe 40 engine coughed during the flight with the 18x6 onboard. Did it mean engine was tuned too rich or the prop was undersized? I may try out my other prop which is a Master Airscrew 18x10 fibre filled.
UT
RE: spe 40
Its hard to say because that could be ignition, carb, spark plug or bad gas. I would put a big blade tune the carb in with a tac and see what happens. The engine makes the power if its tuned right.
RE: spe 40
Thanks for the advice.
I would go ahead and fix up the 18x10 first for another flight before tuning the carb and see how it performs. Anyway, I am still running in my engine (till now hardly 1 gallon of fuel had gone through) and leaning out the carb wouldnt be so soon, I guess.
#31
My Feedback: (40)
RE: spe 40
ORIGINAL: outahand
(Im not scared) Any way cant you just buy a prop hub that will bolt on the crank? I wonder if Scott will have one since he works on them.
No he probably wont have them on hand... he hasn't worked on them for awhile now... it's also more to it than that. He also balances the crank. It's a bit of a process... but I know he's backed up right now so it would take a bit of time.
#32
My Feedback: (40)
RE: spe 40
ORIGINAL: nowinkk
#34
My Feedback: (14)
RE: spe 40
ORIGINAL: sinergy
You should tune your carb from before the first flight... it's important to get your mixure right so you are not building up carbon or running lean. 18x10 is a better prop for this engine... 20x8 - 21x8 is more for a 46.
ORIGINAL: nowinkk
You cannot run a gasoline fueled/spark ignition equipped two-stroke engine too lean. It will just quit. Running rich is one glow habit that should remain with glow engines. It has no place in gas/spark two-stroke airplane engines.
Running lean in a glow engine advances the "spark", so to speak. This does not occur in a gas fueled/spark engine.
Running the spark too far advanced/too much compression will kill (hole a piston) in a gas/spark engine, but not running the mixture too lean. It just won't run.
Ed
#35
My Feedback: (40)
RE: spe 40
ORIGINAL: Babbert
Ed
ORIGINAL: sinergy
ORIGINAL: nowinkk
Ed
That is just plain wrong If an engine is set too lean it runs hot and hurts the engine.
A gas 2 stroke engine will run lean all day long so I don't know where you get this idea from. All you have to do is pull verticle and you can hear an engine that is too lean sag. That same engine can be flown all day long without a problem even though it's set lean. However it won't last long because it's burning up inside.
I also fail to see what the mixture has to do with timing.. but maybe I am not following your example.
#36
UT
RE: spe 40
Hey there I put that 540 wt walbro carb on my spe 40 and the rpm went up 100 I dont know I will have to play with it Do you think going from a 340 to 540 should make a big change like 500rpm? Also what kind of rpm range is all your 40 gas engines running at and what size prop? I tried to call Scott and I left a mesage but never got a call back like the customer service. I went out to my park out here and two guys came both crashed within 2 muinets lol it was a great show.
#38
RE: spe 40
After changing from a 18x6 to a 18x10 prop and leaning out 1/8 turn of the H needle, the spe 40 doesnt cough at high rpm, only occasionally at low rpm.
#39
RE: spe 40
outahand:
The wt-340 venturi is 7.94 mm. and the wt-540 venturi is 13.49 mm.
So with such a big difference in size you must expect a big change in rpm , maybe 1000 more
First check this link to make sure your black plastic piece between the carb and the engine is right:
http://www.rcuniverse.com/forum/m_34..._WT-540/tm.htm
Then try closing down slowly the hi needle using a tachometer and let us know what you got.
#40
My Feedback: (14)
RE: spe 40
ORIGINAL: sinergy
ORIGINAL: Babbert
Ed
ORIGINAL: sinergy
ORIGINAL: nowinkk
Ed
You are confusing glow engines with spark/gasoline engines. Completely different animals. The glow rules mostly do not apply to gasoline engines.
Mixture controls the timing (ignition point) in a glow engine. Running too lean in a glow engine advances the timing and causes preignition, eventually leading to detonation, which damages the engine.
Gasoline engines' timing is controlled by the ignition timing. If you deprive a gasoline engine of cooling air, you can damage it in a similar manner as a glow engine tuned too lean, which can also be damaged by a lack of cooling air.
You have come a long way in the short time you have been involved in model flying, but you need to bone up on the differences between glow and gas. I wish I could get a reprint of Gordon Jenning's "Two-Stroke Tuner's Handbook". They have been out of print for a while, but they can still be found. I stumbled upon that book in the Seventies and loaned my copy to a friend. Don't have the friend or the book anymore (he passed, sadly).
One more thing, when a gas engine sags in the vertical, it is because it is not up to the task at hand, not necessarily because it is lean. It does sound just like a glow engine going lean.
Don't feel bad. There are fellows like Ralph Cunningham and Dick Hanson that make me feel like a beginner in gas engines.
Ed Cregger
#41
RE: spe 40
ed :
If I undestood you correctly we should not worry to tune a gas engine "too lean" to get the maximum rpm, because the engine wont start and so we never can damage the engine or get a dead stick because the setup was "too lean".
Is that right ?
Is that right ?
#43
My Feedback: (14)
RE: spe 40
ORIGINAL: nowinkk
Finally, My Extra 260 (70" wing span) with its stock engine, SPE 40, had a successful maiden flight this afternoon. The AUW without fuel was only 4.7 kg, comparatively light.
Before the maiden flight, the engine was broken in on a stand with 2 full tank of gas a couple of days ago.
Upon starting up the engine and a few full throttles, before the maiden, one of the two 4mm dia. bolt holding the propeller snapped, and the propeller came loosen. The Master Airscrew 18" x 10" could be too heavy for this set up, so I changed to its stock prop which was a wooden 18" x 6". This wooden prop seemed to be a bit under pitch, as the plane could not fly fast even with full throttle.
After the 2nd flight, the aileron linkage was loosen due to vibration...other than that, everything seemed perfect...and a full tank could last for 15 min. flight, with throttle occasionally half and most times full...
How large is your fuel tank? TIA
Ed Cregger
#44
My Feedback: (14)
RE: spe 40
ORIGINAL: seagull extra
Ed you are incorrect with your statement that you can not hurt a gasoline ign. 2 stroke by running lean.
Well, it is okay to have differing opinions. I know I'm right on this one because of the excellent teachers I have had over the years. However, I'm still ready to listen to your explanation as to why I am wrong. I'm still capable of learning something new - even at age 60. <G>
Please proceed...
Ed Cregger
#45
My Feedback: (14)
RE: spe 40
ORIGINAL: gpar
ed :
Is that right ?
ed :
Is that right ?
I never said that it wouldn't start.
If you choke the engine sufficiently, the engine will start because of the fuel already in the engine. Carburetors do nothing until the engine is turning over and air is flowing through them. Starting has to do with sufficient prime in the engine to get it going. Needles can be removed and the engine will still start.
I can remove the carb from any engine (you can too) and get it to start. All I need is a squirt bottle with some fuel in it so I can inject the fuel into the engine. The engine will then start, if there is sufficient fuel and it isn't flooded.
Glow engines, because of the type of fuel they use and the characteristics (stoichimetric ratio) of the fuel necessary for a successful burn, will run under conditions that would shut down a gasoline engine. Gasoline is much more demanding of everything being "just right" in order for the engine to run. This is one of the reasons I say that you can't hurt a two-stroke, gasoline fueled, spark ignition engine of the type commonly used in model airplanes by running the mixture too lean. The engine simply will not run, whereas its glow counterpart is quite capable of destroying itself.
Ed Cregger
