Off Topic Forum - Cars, Trucks, Buggies and more Get to know your fellow RCU member modelers in here and discuss off topic non-rc stuff. Only two topics OFF LIMITS are religion and politics. This forum for car & truck members. Plane & Heli members have their own in clubhouse section.
View Poll Results: A poll
10
8.70%
9
0
0%
8
4.35%
7
4.35%
6
26.09%
5
4.35%
4
30.43%
3
8.70%
2
8.70%
1
4.35%
Voters: 23. You may not vote on this poll
Whats my pc rate for gaming? Free upgrade?
Old 11-08-2007, 05:48 PM
Eman77
Eman77's Avatar
Default RE: Whats my pc rate for gaming?
General tip - if anyone's wondering how their system is performing, you can always set up Windows perfmon counters to log continuously to a CSV file (once/minute or more). If you choose the correct metrics to grab, you can get good insight into what your bottleneck might be. Make sure you're logging, fire up a game, play a while, then stop the game and look at the CSV file in Excel, for the time period you were gaming.
Mind you, I don't play the latest stuff, but in my case, my CPU was maxxed out during my games - Athlon 2700+. I have 2 GB of RAM, but the games I play never hit that threshold (or come close). Once you do though, look out - getting info from the HD instead of memory kills performance, as someone said here earlier.
One thing I don't know, is how to gain insight into how the Gfx card is performing during a gaming session - perfmon won't tell you that (I'm sure other tools will).
Old 11-08-2007, 06:20 PM
Nathan9492
Nathan9492's Avatar
ORIGINAL: pythonfan
ok guys will this make a good combo?
Intel Celeron D 360 Processor - 3.46GHz
http://www.tigerdirect.com/applicati...?EdpNo=2526011
XFX GeForce 8600 GTS Video Card
http://www.tigerdirect.com/applicati...543&CatId=1558
PQI 1024MB PC2700 DDR 333MHz CL2.5 Memory
http://www.tigerdirect.com/applicati...0722&CatId=147
Seagate Barracuda 7200.10 320GB Hard Drive
http://www.tigerdirect.com/applicati...8595&CatId=139
ok with the hard drive, do i need to put windows xp on the new hard drive if i take the old one out and put the new one in? and if so, my disk i have is made for dell only i tried using it in my grandpa's pc cause he needed an xp refresh, and it would not work, but for me it does cause i have the dell, so how would i go about putting xp into the new hd?
Horrible dude,
I reccomend getting a Core 2 duo, somewhere in the 4000
the COre 2 Duo 4000's are cheap and can be overclocked to 3.8Ghz.
Celerons are ancient, dont get it
Everything else looks ok
Oh and Foxy, Dont Run SLI 8800GTX's, waste of money, ur spending heaps more money on a new card that will only boost ur fps a tiny bit.
Trust me it aint worth it
10K Raptor harddrives aint worth it either, Your better off getting a 16MB Sata 2 Hard drive.
IF you need anymore help, Just Pm me
Old 11-08-2007, 08:04 PM
boltech
boltech's Avatar
We don't know if his mobo or bios will support 800Mhz FSB C2D CPU's. He is working with an existing system rather than buying another. Python what's your budget?
ORIGINAL: Nathan9492
Horrible dude,
Old 11-08-2007, 08:37 PM
Nathan9492
Nathan9492's Avatar
ORIGINAL: boltech
Horrible dude,
If hes going to get a Celeron, hes better off just keeping the Pentium 4 and not buy the Celeron then.
Old 11-08-2007, 08:49 PM
boltech
boltech's Avatar
Python I just noticed the CPU you chose is 533FSB, you should be looking for 800FSB CPU.
This would be a better choice, IF your mobo supports it.. if not just stick to the P4 3Ghz CPU you have.
http://www.tigerdirect.com/applicati...999&CatId=2219
I'll see what I can dig up on your system mobo
Old 11-08-2007, 09:04 PM
  #31
boltech
boltech's Avatar
Python before you buy anything can you post more detailed specs on your system... maybe run SiSoftware Sandra or PC Doctor... and post the specs. I've been doing a little digging on your Dell 8400 and from what I found so far you *may* be running a Pentium 4 530 CPU. The Celeron CPU you chose is faster because it's a 3.46GHz CPU but it would be a very marginal upgrade due its slower 533FSB and Smaller L2 cache.
Old 11-09-2007, 02:18 AM
  #32
Foxy
Foxy's Avatar
ORIGINAL: pythonfan
Horrible dude,
Thanks anyway man... I used to be a very serious gamer and I'm an IT consultant for 15 years, so don't worry, I know what I want. At this point I'm getting the best of everything I can that's available from my local store (although I'm skimping on the RAM, cos I just got two gas RCs). The Raptor will make a big difference to boot up times. I know the second GTX doesn't do much YET, but in the future it may (depending on developers), and as for Pythonfan's PC, like I said, if that's max budget, then it's fine, of course there are better choices. By the way, I decided to go for the Gigabyte X38 DQ6 mobo in the end, even though it's a lot more expensive than the EVGA. Heard good things.
There's a 2Ghz core duo that will go up to 3.4Ghz on the stock cooler, and at that speed is almost up with the 6850 in performance, but I can't remember the chip code, 2160 or somthing like that?? Anyway, it's the $89 core duo with a nominal clock of 2ghz, apparently it's a budget rocket.
Old 11-09-2007, 03:28 PM
  #33
pythonfan
pythonfan's Avatar
OK, guys i downloaded that software here are the results, i also did a bench mark test to show the cpu i think on how it is.
Cpu
video Card
Bus
system
Benchmark
sorry for all the pics, i'm not 100% sure at what i'm looking at, i'm better with programing, and hands on stuff.
Old 11-09-2007, 04:04 PM
  #34
pythonfan
pythonfan's Avatar
ok guys new list, hows this sound?
XFX GeForce 8600 GTS Video Card 149.99
OCZ SLI-Ready Edition Dual Channel 2048MB PC6400 DDR2 800MHz Memory (2 x 1024MB) 54.99
http://www.tigerdirect.com/applicati...?EdpNo=3079597
Intel Pentium D 925 Processor - 3.0GHz 59.99
http://www.tigerdirect.com/applicati...?EdpNo=2525999
Seagate Barracuda 7200.10 320GB Hard Drive 89.99
Grand total: 354.96??? better then before setup?
Old 11-09-2007, 04:27 PM
  #35
Wisconsin Nitro
Wisconsin Nitro's Avatar
gameing comp for Christmas maybe?
Old 11-09-2007, 05:59 PM
  #36
Nathan9492
Nathan9492's Avatar
ORIGINAL: pythonfan
Thas better my friend
Old 11-09-2007, 06:20 PM
  #37
pythonfan
pythonfan's Avatar
ok guys i found this last night but i trimmed a lot out, but at the beginning they were saying, that this will speed your PC up A LOT for gaming!!!
And i wanted to see what you guys thought on it before i tried it.
Old 11-09-2007, 07:53 PM
  #38
boltech
boltech's Avatar
With those screen shots we can now really help you. Good work with those.
Now for the bad news. Due to the fact your chipset is 925X you will NOT be able to run any sort of multi-core CPU. So no Pentium D.
supposedly a BIOS upgrade is all that is needed to support those CPUs, but I don't know if this is true. Maybe Foxy might be able to answer that
You can still find CPU upgrades in the Prescott line. Though there may not be many companies with Prescott CPUs still in stock.
These are the CPU’s that you will be looking for if found. I didn’t list any extreme edition CPU’s due to their price.
Pentium4 3.2 GHz 800FSB 1MB Socket 775
Pentium4 3.4 GHz 800FSB 1MB Socket 775
Pentium4 3.6 GHz 800FSB 1MB Socket 775
Pentium4 3.8 GHz 800FSB 1MB Socket 775
Your chipset also limits you to SATA 1.5 Gb/s. Which is not a bad thing you can still use the HDD in you list but you won't get full speed out of it. Consider adding this card to your list and plugging the HDD into it. http://www.tigerdirect.ca/applicatio...825&CatId=1455
Other than that everything else is good
Old 11-09-2007, 08:01 PM
  #39
pythonfan
pythonfan's Avatar
out of these which should i look into they are all 775
http://www.newegg.com/Product/Produc...2&name=LGA+775
Old 11-09-2007, 08:02 PM
  #40
pythonfan
pythonfan's Avatar
my price rang is up to 300, i can do 400-450 at max, but plz keep the 300 in mind
Old 11-09-2007, 09:49 PM
  #41
boltech
boltech's Avatar
These CPU's Should work in your system
http://www.newegg.com/Product/Produc...82E16819116196
http://www.ewiz.com/detail.php?name=P4-670&src=Deal
Old 11-09-2007, 09:55 PM
  #42
boltech
boltech's Avatar
looking at the prices you may be better off not upgrading the CPU and just putting the cash to ram, video and hdd.
your 3ghz processor should still be able to hold it's own when paired with a better video card. Later on when you get a new system the HDD and video card can be moved over to it.
Old 11-09-2007, 11:56 PM
  #43
pythonfan
pythonfan's Avatar
hey are any of you guys it guys that know what there doing???
I need some help, with setting up my server, I'm a little stuck with port forwarding?
Old 11-10-2007, 04:46 AM
  #44
Foxy
Foxy's Avatar
lol, yes, what's the problem (and thanks for the vote of confidence boltech, but I'm not sure about that bios upgrade allowing the 2 cores, I doubt it, but maybe, like I said I have lost touch a bit with hardware since the early core duos)...
...python what are you trying to do with port forwarding, I can probably help with that...
Old 11-10-2007, 12:15 PM
  #45
boltech
boltech's Avatar
Yes I am.. What questions do you have?
Old 11-14-2007, 08:35 PM
  #46
-SomeGuy-
-SomeGuy-'s Avatar
ORIGINAL: foxy42
Your PC rates a low 2 in my opinion. Sorry if that sounds harsh, but your video card is crap, you have almost no RAM and an ancient CPU. Bear in mind that I am in the tech business, so my standards are pretty high. I would venture that you are not even able to play the Crysis demo. To call yourself a gaming PC, in my opinoin the minimum requirement is that it can at least 'run' the Crysis demo at lowest settings. Consider that my spec listed below, in my opinion, needs a SERIOUS upgrade urgently.
Athlon64+ 3000+ (running at 3003mhz, 800mhz overclocked)
4GB DDR400 RAM
Audigy 2 sound
NV80 (nvidia 8800GTX 756MB) graphics.
I'm looking at a serious motherboard, processor and RAM upgrade. I might even get another GTX
With the current spec I can play Crysis demo at 1600x1200 on Directx9 (XP) with most things on high and get around 30-40fps. That's just not good enough if you ask me, and it's my CPU that's letting me down. My graphics card spends more than half it's time twiddling it's thumbs waiting for the CPU to catch up.
Re-reading this thread and i just realised that you have one of the best vid cards out at the moment. I saw it on the shelf at the store and at almost 600$... WOW. And you want a second one? Wont that be overkill? Or is there no such thing lol.
Old 11-14-2007, 08:46 PM
  #47
d3d5
ORIGINAL: -Inverted-
As far as I know you cant run Mac on a Windows PC, just the inverse?
You can run MAC on a Windows Pc, its just not legal
it's not legal? i hope the police don't check my windows i hacked it to run mac
Old 11-14-2007, 08:54 PM
  #48
pythonfan
pythonfan's Avatar
ORIGINAL: d3d5
how could u do that to a mac????
Old 11-16-2007, 02:05 PM
  #49
pythonfan
pythonfan's Avatar
well i know my dell is bad but here are some much clearer results
Old 11-16-2007, 03:31 PM
  #50
Foxy
Foxy's Avatar
ORIGINAL: -SomeGuy-
ORIGINAL: foxy42
4GB DDR400 RAM
Audigy 2 sound
Haha! No, there is no such thing as overkill, now that Crysis is out... BUT! Parts are here and I have a new spec to post...I'm pretty pleased with it, it runs like absolute lightning, seriously unbelievable.
PSU: OCZ StealthXtream 600W
Case: Cheiftec full tower
Mobo: Gigabyte GA-x38-DQ6 (new overclocking king and widely hailed as the best intel board on the market at the moment)
CPU: Intel Core 2 6850 (3GHz nominal, currently running at 3.6GHz on a HUGE Zalman copper air cooler)
RAM: 2GB DDR2 800Mhz (currently running 966Mhz)
HDD: Western Digital Raptor 150GB 10,000rpm 16MB cache (Just for Vista really, storage is on a secondary 250GB regular 7200rpm drive)
GFX: Still the NV80 with 768MB, no current plans for another, but you never know.
OK, with that super ninja beast, I can run Bioshock with absolutely EVERY optino set to max at 1600x1200 and get OVER 110FPS!!!!!!!! [X(][X(][X(][X(][>:][>:][>:][8D][8D][8D]
Haven't got Crysis yet, came out today in Greece, will get it soon. Gears of War (PC version) runs like an african sprinter at FULL detail at 1600x1200 too, and looks utterly mental.
Overclocking so far...FSB is a nominal 333Mhz x 9 for this chip, I've ramped up the FSB to 400Mhz and it's totally stable, will see how it goes for a few days and maybe ramp it up some more. I'm hoping to find a nice range of settings to get the CPU to run at 4Ghz on the air cooler. I don't want water, too much hassle.
EDIT: Will post 3dmark06 results shortly.
