4-tec Won't Start???
no, sorry man i'm at work right now, i was just watching some rc videos and wishing that it wasn't raining here and that i could get my car started i will be going home shortly and trying all of these tips. thanks a lot every body for all of the advice, i will keep you posted :thumbup:
the needle settings for a trx.15 are 2.5 turns out on the high speed needle and the low speed needle should be flush with the end of the throttle arm also make sure the carb is open 1mm and set the idle stop screw so it won't close all the way next make sure the battery in the e-z start is fuuly charged my buddie has a t-max and after a couple of starts the glow plug would still light up but not enough to make it fire up. I would recamend getting a pullstart and a glow igniter instead of the e-z start
