DIY zen mods??
DIY zen mods??
Old 09-29-2008, 03:18 PM
munro1656
Default RE: DIY zen mods??
Hi glenn
the timing I was aiming for is 180deg on exhaust maybe a touch lower
I was going to run a 0.02" cut at top of piston about 1/4" down thats on the out side then I was going to run a cut on the inside for lightening I think those ball cuts on the piston skirt maybe beificial as well I am assuming they would also help with lurication in the bore? , but the machining that I was reffering to I have seen was taken off the top of the piston and i couldn't figure out the benifit
cheers craig
Old 09-29-2008, 04:30 PM
MrMikeG
Looks good!
Old 09-29-2008, 06:01 PM
glennb2006
ORIGINAL: munro1656
Hi glenn
cheers craig
hi Craig,
if you look through the post that Larry put a link up to, it details on there the purpose of the piston indentation (Lubrication), also makes mention of the piston size reduction, as well as timing figures. It also shows some of the work that needs to be done to match ports to crankcase.
You are going to be quite extreme on your timing, but no point doing it for little gain (In my opinion).
I believe that weight is removed from the piston by relieving material from under the piston crown as well as the gudgeon pin (AKA Piston Pin) bosses. Not done one on a Zen yet so I don't know how much you can get away with, maybe someone will let the info slip.
I am interested to see your results as I've a Zen here that I am going to have a go at this Winter on the dark evenings. Want to see what I can get out of it.
Glenn
Old 09-29-2008, 09:46 PM
Scott Schneider
Scott Schneider's Avatar
Piston mods ... yea, here is a few picture to feed your need for speed [>:]
ID:	1043510   Click image for larger version
ID:	1043511   Click image for larger version
ID:	1043512   Click image for larger version
ID:	1043513   Click image for larger version
Old 09-29-2008, 10:13 PM
munro1656
Thats The mod I was talking about earlier in your fist pic you have machined top of piston and I thought that would reduce compression?
In your second pic you have tapered bottom of skirt what is the reason for that?
cheers craig
Old 09-29-2008, 10:50 PM
  #31
ryan_t888
ryan_t888's Avatar
ORIGINAL: Scott Schneider
Scott, those pictures are great, thanks for sharing. Do you have any different angle shots or photos of modified jugs?
Ryan
Old 09-29-2008, 11:24 PM
  #32
Scott Schneider
Again, SEE THIS SITE AND POST ***
http://www.modelgasboats.com/Magazin...e_Porting.html
Response to piston mods ..... First mod is too turn the OUTSIDE diameter down @ .002" (.004" total) about 1/4" down from dome and past ring groove. This allows a HOT piston to expand within a Cool cylinder without seizing.
Next while piston is in the lathe, clean up the squish area so it is no longer the casting profile but an even machined one.
* If you choose to "Flat Top" the piston ? do so next.
The "Flat Top" mod is used on HIGHLY MODIFIED Zenoahs that will run at VERY high RPM, It softens up the torque a tad, but allows engine to over rev better when staged on a rather short pipe.
As for more pictures
*** You asked: tapered bottom of skirt ?? ... tapered the piston pin boss area, as well as thinned the skirt area while lightening, but NO taper ?
ID:	1043569   Click image for larger version
ID:	1043570   Click image for larger version
ID:	1043571   Click image for larger version
ID:	1043572   Click image for larger version
Old 09-29-2008, 11:39 PM
  #33
Scott Schneider
Being you got me sharing here on RCU
I will share some Zenoah R&D tech of my own design that shows just how far outside the box you can go
Lower end fitted with a FULL circle crank from the RC series Zenoahs, cases also fitted with a 3rd main bearing on PTO side.
* Special adapter needed along with flywheel machining to do the FC crank conversion tho.
ID:	1043580   Click image for larger version
ID:	1043581   Click image for larger version
ID:	1043582   Click image for larger version
ID:	1043583   Click image for larger version
ID:	1043584   Click image for larger version
Old 09-30-2008, 03:03 AM
  #34
munro1656
Thanks everyone for your input every little bit of advice is valuable I must say there is more work that goes into a mod like this than you'd think[sm=spinnyeyes.gif]
I have done a little more work to zen today I have my fingers tightly crossed that I haven't stuffed anything up!
Old 09-30-2008, 04:59 AM
  #35
pedro2-5
[sm=tongue_smile.gif]hey craig if you are faster than me you will have to mod my motor for me
Old 09-30-2008, 05:02 AM
  #36
munro1656
Mod or sabatage your motor?
Old 09-30-2008, 01:32 PM
  #37
ryan_t888
ryan_t888's Avatar
I believe these are the stock timing figures.
Exhaust Duration: - - - - - - - -162 degrees
Transfer Duration: - - - - - - - -125 degrees
Piston Intake Port Duration: - -142 degrees
What do most of you guys mod your engines to?
I don't increase the transfer timing.
My intake timing is increased to about 145-150 degrees. I've noticed some people choose to skirt the piston while others prefer to open the intake port on the lower edge.
I have always preferred exhaust timing in the 172-178 degree range.
The stock Piston is about 29 grams. My piston is about 23 grams currently. If you can get in to the low 20's, there should be a decent enough improvement.
Ryan
Old 09-30-2008, 03:09 PM
  #38
munro1656
Thanks ryan
do you have any pics of your work to post the next step for me is piston i'd llike to see what you've done to achieve 23gr
chers craig
Old 09-30-2008, 03:33 PM
  #39
ryan_t888
ryan_t888's Avatar
Sorry Craig, I would love to post pictures but I will not have a camera for a few weeks. I will definitely post pics if I can get a hold of cam.
Ryan
Old 10-01-2008, 02:35 AM
  #40
munro1656
Hi all
I did some work on piston today so I think all mods are done and I think i'm ready for reassembly. Would there be any benefit in leaving off the jug gasket?
here's todays pics
cheers craig
ID:	1044227   Click image for larger version
Old 10-01-2008, 03:16 AM
  #41
glennb2006
Looking good, what weight did you get the piston down to?
Glenn
Old 10-01-2008, 03:35 AM
  #42
munro1656
Hi glenn
I managed to get it down to 24.59gr (checked with my old mans digital scales for measuring powder for amunition) maybe I could have gone a bit more but wasn't sure of thickneses
cheers craig
Old 10-01-2008, 04:04 AM
  #43
MistralK
MistralK's Avatar
Nobody runs the full shoulder crankshaft like the G230 one? It can increase high RPM..
Old 10-01-2008, 05:43 AM
  #44
munro1656
??? please explain I have never seen a 230 crankshaft so give it to me simple! what are you trying to say?
Old 10-01-2008, 05:55 AM
  #45
MistralK
MistralK's Avatar
I mean this one..combineted with lighter piston it takes more revs..
Old 10-01-2008, 08:18 AM
  #46
ryan_t888
ryan_t888's Avatar
Craig
Did you take material off from inside the piston? When you are looking inside the piston there are knobs from the casting process, these can come off. Make sure you leave the center indent alone though. I also took a tiny layer off the top of the piston to smooth out the finish, and I tapered the cut out section near the piston pin.
As for the jug, do you know any of your new timing marks? I would also place a gasket in there as there must be some material to fill the voids in between the machined surfaces. You can get thin gaskets from americanrcboats. This will increase compression, increase piston port timing and decrease exhaust port timing compared to a thicker gasket.
How are going to get the piston and ring back in the cylinder? What is the method you will use?
Ryan
Old 10-01-2008, 04:16 PM
  #47
munro1656
Ryan
As far as new timing marks are concerned I can only go by what I have read and heard cause I'm not exactly a pro at this I have used measurement to acheive what I believe to be correct Lets hope I'm rite As for as the piston goes I put it the lathe to start with and took a cut from the inside skirt area then with die grinder took some further material out from inside I removed a couple of nobs but had left others then just removed casting marks and smoothed over the rest and I didn't remove the centre nob only smoothed over it. As far as getting the piston back in I have a piece of shim here that I will lube up and hose clamp to piston then install basically the same as ring compressor that is used in automotive assembly
The pics are from just after I finished with course bur they haven't been cleaned up yet if you could see any area where I could go further let me Know It's not together yet!
cheers craig
ID:	1044460   Click image for larger version
Old 10-01-2008, 07:27 PM
  #48
glennb2006
Another couple of grams to go there and you will be in region, under the crown and around the bosses should find it for you.
Glenn
Old 10-02-2008, 05:17 AM
  #49
munro1656
I managed to scrap off 1 more gram today maybe if I had a cross sectional diagram of a piston I could find were I could get more with out jepardising strength my hat really goes off to you guys that make it sound so easy to get your piston in the low 20's grams. I think that's it for motor so it'll go back together this weekend then i'll work on intake manifold
Old 10-02-2008, 05:37 AM
  #50
MrMikeG
You can measure the outside down to the ring groove, then measure the inside and you can see how far you can go. Just watch out for the piston pin.
20 gram piston
