advice on GPS in gasboat
Banned
RE: advice on GPS in gasboat
The etrex weights 0.33 pound and the 101 weights 2.6 oz, if you placed a etrex on the front of your boat, it would effect your boat's CG more then the lighter one.
true, but in my case it's just forward of the motor. still i'd like to see the speed difference between the 2. like i said i'd bet it's just a 1,or 2 mph difference, and if it were used in all the boats at the pond then they would be carrying the same weight, and give a equal speed rating on that day. hell run just a few oz of fuel to go faster also.
so my etrex is twice the weight. i used this converter:
http://www.onlineconversion.com/weight_common.htm
i'd still like to see the speed difference. i also think you can get a etrex cheaper on evil bay. only paid $45 shipped for mine used.
doubt it will make any difference at all,lighter isnt allways faster anyway so as far as added weight goes i wouldnt even worry about that little amount as in my opinion it wont make any difference at all.
Mart
Mart
Jerry theres loads of guys who instead of balancing the boat correctly in the first place add lbs of weght up front to keep the nose down and claim the boats faster now lol.My thinking to that has allways been sure it might be but think how much faster it would be without that 1 1/2lb of lead up front and balanced correctly in the first place .2.6oz wont make a blind bit of difference in my opinion especially if its close to the motor.
Mart
Mart
#31
Banned
ORIGINAL: doomracing
http://www.st-owners.com/forums/showthread.php?t=19411
#32
For an accuracy test sit the unit on a picnic table or similar near your water park. Reset the maximum speed and then check it again in about a half an hour. That number should be your +/- factor for any speed readings.
Without a correction signal within close proximity to the unit you are using the accuracy can vary with weather conditions.
#35
Banned
Then keep the fastest one and return the slowest one back..lol
http://gpsinformation.net/main/gpsspeed.htm
#36
NB, CANADA
keep the fastest
the reason I went with the forerunner 201 was not a weight issue, but a size issue.
when testing in the gas boats the Etrex series is fine, there's plenty of room but I also wanted to test the Nitro boats and some of them room is an issue.
the foretrex and forerunner series (101, 201, 301) are 3.2"x1.7"x0.7" and my friends Etrex Legend is 4.4"x2"x1.2" and that one doesn't fit in a 21 sport hydro or rigger (well not in the SSP).
all of those GPS are fine if you have the room and its cheap go with the Etrex series, no room, go with the smaller one.
Dan.
Dan.
#37
NB, CANADA
Eric,
I don't know how old the info you provided is but it as changed quite a few years back.
all of today's GPS are 3 Dimensional (well, maybe not the ones from the stone age).
here's some details between 2D and 3D:
The difference is primarily how many satellites are used to compute the position fix and how elevation is computed. In 2D (two-dimensional) only three satellites are needed for a position fix and elevation is not computed. Any elevation displayed during 2D operation is the elevation you entered. In 3D (three-dimensional), a minimum of four satellites are needed to compute the position and elevation at the same time. Elevation calculations are greatly affected by Selective Availability (SA), no longer being used to intentionally degrade GPS signals. If SA is ever reinitialized by the Department of Defense, your calculations of elevation may fluctuate.
Dan.
Dan.
#38
Banned
ORIGINAL: Dan S
keep the fastest
Dan.
keep the fastest
Dan.
#42
Banned
ORIGINAL: JakeDW
GOOD NEWS my 101 came back to life today .YES
Cat = weight placement is everything.
Jake
Jake
#43
ORIGINAL: rcboateric
You were lucky and should pull the slot machine and see if it can hit a small jackpot..LOL, BTW, what does your last word mean?
ORIGINAL: JakeDW
Jake
Jake
Jake
#46
if water got into you're gps unit then the rubber seals are toast send it back and for a small fee or maybe even free they will fix it. garmin has good costumer service
#47
did a error tes on my etrex yesterday. after 2 hours of no movement i had a max speed rating of .2 mph. being that low i'll call it dead nuts on :thumbup:
#48
Banned
ORIGINAL: cyclops1970
yes jake .. baggies are good for more then sandwiches
#49
Garmin Etrex and Garmin Geko are not waterproof even when new. Ask me how I know.[8D] They can be dried out though. To keep them dry I use an Aquapac sealed bag which is made specially for the GPS's.
#50
The Foretrex 201 is completely waterproof...something like down to 3 meters for half an hour is what I think I read. I just use Velcro and stick it to the top of my radio box cover.
