Skymaster F-16 1/8 build P-80
RE: Skymaster F-16 1/8 build P-80
ORIGINAL: Guillermo Ibanez
Congratulatios Pete.
Any pictures or video?
I am trying to get more inputs for taking my final decision where to let the C.G. at some place between 150 and 175mm
Guillermo
ORIGINAL: Pete737
Hey Guillermo,
I just completed 4 flights over the weekend, CG at 150mm. I noticed no tendency of the airplane to dive in turns.. It really flew wonderful!
I just removed my intake pipe today, I am going to try to get another fuel cell where it was. Anyone see any difference with or without the intake pipe?
Pete
Hey Guillermo,
Pete
Guillermo
No vid or in flight pics. Just one at the end of the day before we packed up.. That's mine with Jeff's Spiderjets 16.
Pete
ORIGINAL: Pete737
Thanks Guillermo,
Pete
Guillermo
ORIGINAL: Pete737
Hey Guillermo,
Pete
Hey Guillermo,
Pete
Guillermo
Pete
Hey Pete, are you flying with the wingtip missiles installed?
ORIGINAL: Pete737
Thanks Guillermo,
Pete
Guillermo
ORIGINAL: Pete737
Hey Guillermo,
Pete
Hey Guillermo,
Pete
Guillermo
Pete
ORIGINAL: [email protected]
Hey Pete
What are your flight times and how much fuel ?????? are you haveing the same problem with fuel left in the tanks.
Pat Martin
Hey Pete
Pat Martin
My timer is set for 3:30 When it goes off I make a pass and then land. I have the stock tank setup but I just removed my intake pipe and am going to try to fit another tank in the space left. I have not had any problems with uneven draining, Althoug I begin to pull from the header when the tanks are 1/8th full, I think my clunk lines are a bit too short.
Pete
#32
Pete,
That will give a lot of room for Fuel, I installed a 24oz. Header tank in my F-16 with the kevlar tanks 34oz. each total ful 92oz not includeing the UAT. Should be OK.
Skymaster F-16 1/8 scale larger fuel tank
Pat
Pete,
Pat
Does it fit?
Guillermo
#34
Yes see the post Skymaster f-16 lager tank for the photos of the tank installed
Send me the address please....
#37
Would you happen to have any larger pictures?
Pete
#40
OK Here are larger Photos I understand.
This is a 2"X3.5"X 6.25" FROM DREAMWAORKS I did have to cut a little opening so to fit but it is not a big deal to me.
I will be happy if it work having more fuel is good.
Pat Martin Wasilla Alaska
#41
This is a 2''X3.5''X 6.25'' FROM DREAMWAORKS I did have to cut a little opening so to fit but it is not a big deal to me.
Very nice installation
I will test mine with the 16 Oz extra fuel and according to the fuel remaining after 5 minutes (of course test on the ground), I will consider getting this 24 Oz. fuel tank from Dreamworks.
Guillermo
#42
My Feedback: (38)
OH
Looking to buy a Skymaster 1:8 F-16 and run a P-80.
Where did you end up settling on the CG?
How long are the flight times with the 24oz header tank vs 16oz?
Any issues running the stock exhaust pipe or having fuselage overheating problems with the P-80 stuffed in there?
Mike
Mike
#43
ORIGINAL: Molnar142
Mike
Mike
<span class="Apple-style-span" style="font-family: Verdana, Arial; font-size: 13px; -webkit-border-horizontal-spacing: 1px; -webkit-border-vertical-spacing: 1px; ">My C.G.? I will start with 170mm with gear down, UAT full and front tank full. Hope to land with not less than half front tank which will move the CG at landing, to 175 mm.....
I am relying my C.G. to Craigs and all his partners in Australia experience, under the fact that I experienced some serious nose tucking down in my lostF-16. Even, the day of crash, this tendency contributed definitely to the accident.
My conclusions after all the different C.G positioins I have read are:
1- If you have a tail mounted turbine (P-60, Super Bee, Wren 44, and similars) and your F-16 is around 17-18 lbs., let the C.G. were factory reccomend (135-145mm) I would set it in 145mm
2- If you have a center mounted turbine (P-70, Falcon or similar) and your F-16 is around 22 pounds, move C.G to 155-160mm
3-If as mine, you have a center mounted turbine (P-80 or similar, that is a heavier turbine) and your F-16 is around 22-24 pounds, move your C.G to 165-175 mm.
Although I have not tested all those situations because I have only one F-16 and my set up is the same as No.3, with final weight around 25 pounds, I can not assure nothing. Is pure speculation based upon all I have read.
Keep in touch
</span><br type="_moz" />
#46
ORIGINAL: lear31A
mine was very nose heavy with the cg set at 155. it flew great, just nose heavy. I have SuperBee in tail
<br type="_moz" />
#47
My Feedback: (38)
OH
Hey Mike:
<span class=''Apple-style-span'' style=''font-family: Verdana, Arial; font-size: 13px; -webkit-border-horizontal-spacing: 1px; -webkit-border-vertical-spacing: 1px; ''>My C.G.? I will start with 170mm with gear down, UAT full and front tank full. Hope to land with not less than half front tank which will move the CG at landing, to 175 mm.....[img][/img]
I am relying my C.G. to Craigs and all his partners in Australia experience, under the fact that I experienced some serious nose tucking down in my lost F-16. Even, the day of crash, this tendency contributed definitely to the accident.
Keep in touch
</span><br type=''_moz'' />
ORIGINAL: Molnar142
Mike
Mike
Keep in touch
From reading the various build threads and Skymaster's instructions, the build appears to be fairly straight forward. Any other thoughts/ideas you could share on this build from your experience?
I'm interested in running a Flaperon and Elevon setup. Meaning for roll control, both the elevators and ailerons move. Hitting the flap switch, and the ailerons (flaperons) move in coordination as flaps. Do you see any issue with this? Has anyone run this type of setup?
The Skymaster instructions say...
"The F16 may be set up for 2 versions:
1. Elevon with only Flaps on wing or Elevon only.
2. Elevator and ailerons. NO FLAPERONS"
Which seems to suggest not to run it they way I would like.
Servos I plan to use:
Flaperon - DS8411
Elevons - HS7955TG
Rudder - DS368
Steering - HS5645MG ? Not sure.
Any suggestions are welcome.
Mike
#48
ORIGINAL: Molnar142
Thanks Guillermo. Being concerned of a too far aft CG I'll probably start with 160mm and work my way back if needed. Unless you think it's too risky to start there. It is somewhat strange that I read some people think that a CG location of 140mm is "perfect" while others write 140mm is way too nose heavy and the plane flies much better at a CG location of 170mm.
Flaperon - DS8411
Elevons - HS7955TG
Rudder - DS368
Mike
Hey Mike:
<span style="">My C.G.? I will start with 170mm with gear down, UAT full and front tank full. Hope to land with not less than half front tank which will move the CG at landing, to 175 mm.....[img][/img]
Keep in touch
</span><br type="" />
ORIGINAL: Molnar142
Mike
Mike
Keep in touch
Flaperon - DS8411
Elevons - HS7955TG
Rudder - DS368
Mike
Is OK to start at 160mm and try to adjust the C.G. as needed.
Regarding your set up, mine is:
Condition 1: In flight:: Ailerons, elevators, rudder in normal fashion.
Condition 2: Take Off/Landing: Ailerons down as flapperons 20°, elevators move as ailerons too.
I have flown this jet with flapperons in combination with elevons (This combination is called by Futaba as Ailvators) and at slow speeds, ailvators works fine. But I dont know if it was because my ailerons thorws were measured in the wrong position (manual calls for 25mm in the ailerons tip, and I measured it in the ailerons root. As a result, ailerons tip didn't get 25mm of throw and because of this I think that with flaps down, ailerons were sluggish. Then I used ailvators, to help ailerons in slow speed turning).
Now, I have the right throw but I have not tested this set up. I think is going to be very sensitive,
About your servos, I use Futaba, so I have no experience with JR.
BRG
<br type="_moz" />
#49
My Feedback: (38)
OH
Guillermo,
Thanks.
So with your new aileron throw setup, will your "Condition 1: In Flight" setup be the aileron and coordinated elevon setup, "Ailvator" or will you only use this Aileron/Elevator coordination for roll control for your "Condition 2: Take Off/Landing" program.
Mike
Thanks.
Mike
#50
ORIGINAL: Molnar142
Guillermo,
Thanks.
Mike
Guillermo,
Thanks.
Mike
Although you can program the Ailvators in Condition 1 for maneuvering if you want too.
<br type="_moz" />
