OMP - Ohio Model Products Support Forum Discuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
47" Pro Yak Questions???
Old 12-04-2009, 09:27 AM
lomcevac540T
lomcevac540T's Avatar
Default RE: 47
I think you will be very pleased with this profile. Big fun in a small package that you can virtually fly anywhere.
Old 12-04-2009, 01:37 PM
ro347
My Feedback: (13)
Default RE: 47
Will the CA hinges be plenty, or would I be better off with Robart point hinges?
Old 12-04-2009, 02:14 PM
lomcevac540T
Default RE: 47
CA hinges are working fine for me.
Old 12-05-2009, 05:00 PM
ro347
My Feedback: (13)
Default RE: 47
There is a bag that contains the carbon wing tubes....along with 5 very thin carbon rods. What are the thin rods for? I dont see any mention in the manual.
Old 12-06-2009, 09:32 AM
AFSalmon
AFSalmon's Avatar
Default RE: 47
Nice pics Lom. The first one looks like you are kissing the rudder. Now you aren't touching that plane while it is flying now are you?
Old 12-06-2009, 09:34 AM
  #31
AFSalmon
AFSalmon's Avatar
Default RE: 47
ORIGINAL: ro347
Thos are not carbon but metal pushrods I believe you are referring to.
Old 12-06-2009, 11:26 AM
  #32
lomcevac540T
Default RE: 47
ORIGINAL: ro347
Those should be your control rods... elev, rudd, 2 ailerons, and throttle.
Old 12-06-2009, 11:27 AM
  #33
ro347
My Feedback: (13)
Default RE: 47
ORIGINAL: AFSalmon
ORIGINAL: ro347
Those are not carbon but metal pushrods I believe you are referring to.
Hmmm...I ll have to take another look. I know that I already have metal pushrods with the clevises which were taped to the box. These rods I speak of aren't threaded or anything. Well, I'll take another look.
Old 12-06-2009, 11:28 AM
  #34
lomcevac540T
Default RE: 47
ORIGINAL: AFSalmon
Thanks, but no kissing! lol
It's a little further away than it looks.
Old 12-06-2009, 11:30 AM
  #35
lomcevac540T
Default RE: 47
Mine had two sets also, don't know why.
Old 12-06-2009, 06:04 PM
  #36
ro347
My Feedback: (13)
Default RE: 47
My mistake, they werent carbon. Looked like it through the bag, actually another set of pushrods.
Old 12-30-2009, 09:55 PM
  #37
Wingspam
Default RE: 47
Hey guys
On this Pro Yak, I have an Os 61 fx its a little heavier than the Os 55. But it weighs the same as the Saito 82. Has anyone used this combo? If not what do you think of it?
Old 12-31-2009, 10:36 PM
  #38
Ernie Misner
Ernie Misner's Avatar
Default RE: 47
As I recall the .61fx wasn't too popular for this type of application because it weighed nearly as much as a .91 but wasn't a real powerhouse. Might be fun though if it's what you have available.
We know the 55 and 82 work well.
Ernie
Old 01-02-2010, 09:14 AM
  #39
AFSalmon
AFSalmon's Avatar
Default RE: 47
Ernie is right on the mark, don't use a 61 2 stroke as they are too heavy and you won't be happy with the results. Yes folks have put 60s on a 40 size slab but most 60 motors are the same size and weight as the 90 engines. The 61FX is the same case as the 91FX. Go with a 55AX.
Old 01-02-2010, 07:00 PM
  #40
Wingspam
Default RE: 47
THanks for the information guys...
I just called all 3 LHS and no one has the Saito 82 instock, all 3 stores said they have been out for a couple weeks or more...SO I guess I will be stealing a 55Ax off another plane. On the 55Ax what prop do you suggest for the best overall performance?
My new yak will be here on Tuesday, I can barely wait...LOL..
Old 01-02-2010, 07:46 PM
  #41
Ernie Misner
Default RE: 47
The APC 13x4W works well but lately I've been using the MA 13x6Scimitar S-2 series prop. Same pull and rpms but half the price!
Ernie
Old 01-02-2010, 09:20 PM
  #42
rcplanenut
My Feedback: (12)
Default RE: 47
I have good performance with a xoar 13x4
Old 01-03-2010, 12:48 AM
  #43
ro347
My Feedback: (13)
Default RE: 47
ORIGINAL: Wingspam
Many seem to go with the 13x4 on the 55ax. I will be using Xoar for fast spool up and pull. I was rather impressed myself when I received my proyak. Nice looking bird. I will be taking a week off of work next week and might have to set aside a few days to get this thing together.
If your LHS is out of the .82, have you thought of buying used? I recently just purchased my first used engine and was VERY please with what I got. I picked up a very slightly used 55AX for 99 on ebay. Runs great and was in excellent shape. It was practically brand new. Of course I made sure to ask the right questions, and look at the seller's feedback rating.
Here is a used 82:
http://cgi.ebay.com/Saito-FA-82-Four...item4cecd4b80e
Here is a new 82:
http://cgi.ebay.com/SAITO-FA-82a-4-S...item3358d7dba2
There are also others on there. If by chance you can find a NIB 82 for $200, I would call that a great deal. Might have to be patient though, and dont let the bidding get the best of you.
Old 01-04-2010, 06:26 PM
  #44
ro347
My Feedback: (13)
Default RE: 47
Have you guys added right thrust to the plane? Wondering if I will need to plan on using washers.
Old 01-04-2010, 08:51 PM
  #45
Wingspam
Default RE: 47
The manual say to add about 2 degrees of right thrust, I would think it would be needed since it is a straight plank, but that is a good question. Unless OMP states otherwise, I plan to when mine arrives tomorrow.
Old 01-04-2010, 08:54 PM
  #46
Wingspam
Default RE: 47
Ok guys I just read thru the manual and it keeps mentioning the use of CA instead of apoxy. Is there any specific reason for this? This is included where it mentions gluing on the tail surface's, vertical and so on..
Old 01-04-2010, 10:20 PM
  #47
ro347
My Feedback: (13)
Default RE: 47
ORIGINAL: Wingspam
Good question as I plan on starting mine next week.
Old 01-05-2010, 08:20 AM
  #48
AFSalmon
AFSalmon's Avatar
Default RE: 47
Since the construction is all wood you can use CA with no problems. Of course you can always use epoxy or your favorite adhesives. I like CA as I can set the stab in place, align perfectly, set the position with pins and tape and then wick some thin ca carefully into the joints and I'm done. Epoxy is too messy!
On the engine it is purely a personal thing if you want right thrust or not but you will need to compensate somehow for the spiralling slipstream effect which is why all prop planes have right thrust. About 2 degrees or so is a good compromise. Otherwise you can mix right rudder with throttle like some pattern flyers do.
Old 01-05-2010, 01:31 PM
  #49
flygilmore
flygilmore's Avatar
Default RE: 47
Make sure you use an OS F plug on your .55AX....makes a night and day difference!! The Xoar is awesome in a 13x4 with the APC sport 13x4 (not 13x4W) right on its heels. This will make for a perfect combo
Old 01-05-2010, 08:54 PM
  #50
Wingspam
Default RE: 47
I received my plane today by UPS and was greatly suprised that the outside box didnt have the normal wear and tear they usually arrive with. After opening the inner box everything was neatly packed, and in great shape. I started with the usual ironing of the entire plane and never encountered a single wrinkle. That was a pleasant suprise, so I mounted the gear and laid out my next days steps.
Thanks for the fast response to questions OMP and a great looking product.
Wingspam
Contact Us - Manage Preferences - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service -
