Center Diff Problems Need Help
RE: Center Diff Problems Need Help
yes they offer a lid for them...but in all honesty I would just get a new tank...getting the old lid off and the new one on without breaking the mounts can be a pain...also you will want to make sure the screw on the bottom side of the lid is tight so it holds the o-ring right...and sometimes u may need to make sure the o-ring is good and dry so it seals better...never had a issue with a torpeda fuel tank though
i guess i put a tank on the list to... iam already up to like 150 in parts and thats not with tthe raido i still need to get good thing i am gettin 40% of the motor with the exchange program...
ok i fixed the center diff.... it was a missing washer/seal/spacer... used a pice of cardbord that came on a part i order from dinball from himoto in hong kong.. took a wile to get it cut and sealed so it whould brake down under use but it works like a charm cant wait to get it on the road now.
#31
If you install a Fatter O-Ring in the Gas Tank lid,,,,it will Close up a Lot tighter and stay sealed better.
You can get O-ring kits from Harbor Freight for Cheap......
If you need a Gasket for the Diff,,,,,,you might try buying Gasket material from the local Auto Parts store and making one yourself.....
#32
the gas tank seals nice when you close the lid its just the lid come back up when you drive it
yea i was goin to get some gasket maker but i had some cvt gasket stuff and just coverd that little pice of cardbord with it and let it dry it should work but i might need to get some any ways because i need to do a few motors soon an the other diffs on the car didnt have seals on anyof the other diffs but thay dont seem to bind up..
