FF-320 Rebuild
Here is the Manual but there is not anything in there about setting the timing.
I remember it not being that difficult to time them. The marks are visible on the cam gear. With the rear case cover removed, you will notice a small hole in the large camshaft gear and a small dot on the crankshaft gear. These marks must be looking at each other to time the camshaft correctly.
http://www3.towerhobbies.com/cgi-bin...LXBY71&P=7
Manual ff-320-manual.pdf
I only see the hole in the camshaft .
don’t see any marks on the crankshaft…
