Xicoy - LG15 Gyro Controlled Brakes
Old 02-16-2023, 04:49 AM
  #526
VK96
Default ER-40 Amp Cut-off?
Upgrading my gear to Electron and plan to use my LG-15...Combed through the thread hoping to find the ER-40 settings, but didn't see any. If anyone knows the specs I'd appreciate it!
Old 02-16-2023, 05:35 AM
  #527
Len Todd
I have had several of these LGCs on JP and Electron gear. All you would need to change is the motor current limits. I assume you have an LGC that allows you to change the current limits (i.e. not locked to a particular set of gear.)
Electron's manual gear operator has three settings, one each for the 30s, 40s and 50s. That being said, one would assume that 40's current limit setting is definitely higher than the 30's, etc. The motors are different. I have one set of gear that will not work on the 30 setting but does work on the 40 setting. So, you are right to assume the current limits are different.
Noone every told me what the any of my gears' current limits should be. So, on the bench, I just started increasing the LGC's current limit settings until the gear worked reliably, and then I added two more units to the LGC's current limit setting. Never had a gear on these controllers fail to go up or come down. But I do disassemble & clean the gear annually even though I never fly off of grass, anymore.
Old 02-16-2023, 05:42 AM
  #528
VK96
Thanks Len…I shot an email to electron as well so I’ll see if they can set me up
Old 02-16-2023, 05:46 AM
  #529
jvaliensi
This is what I have for the ER-40.The 1.3 amp motors are EVO and the 2.2amp motors are Classic
Old 05-31-2023, 09:51 AM
  #530
Catmanrc
I'll start by repeating some others, GREAT THREAD!
I'm the new owner of a slightly used T-One Mini.
Came with JP Retracts and Brakes and the JP controller installed.
Also came with a Xicoy LG15.
I was a bit stumped until reading this and Tip22v was very helpful in the order of operations.
I have it all working now.
A few things left me scratching my head so I did some further testing.
They were the difference in retract voltage between the JP and the Xicoy.
And the current vs voltage relationship.
Let's start with the Voltage.
I disassembled the JP unit and did not find any voltage regulators.
Then I set it up for some measurements.
Here's the input voltages vs output voltages (using a bench supply).
INPUT,OUTPUT
8.4, 7.75
8.3, 7.67
8.2, 7.57
7.6, 7.02
So the output tracks with the input and always about 0.6v less
Time for the O-Scope.
Ah-Hah!
The JP output is pulsed not constant.
Therefore when you measure it with a DVM out get the average DC voltage!
(Picture a really nice shot of the scope screen here that the forum won't let me post!)
(Pulse on = 18ms)
(Pulse off = 2ms)
The peak is at the "+" input voltage, and it pulses down to near the "-" input.
And therefore the motor experiences the average POWER that this delivers too.
I suspect the pluses may also help the motor start or overcome the stall from the previous direction.
So what is happening on the Xicoy?
The Xicoy does not pulse and is just constant and at the input voltage.
However, at the end of the movement it does a reverse pulse to back off the motor a "tad".
That's the 0.10s setting called Unload Time.
If you change that to say 0.2s or more, you'll see the motor reverse and move some distance back the direction it came from.
As for Motor Current going up as the Motor Voltage goes down, that is not the case.
It would be if it was like the AC adapter used on your laptop, what's called a smart switching supply or similar.
In this case the JP motor is just a motor, no smarts in there.
So the Current and Voltage are directly proportional.
As for current draw on the JP retract,
Running I saw about 0.6amps to 0.7amps on the retract I was playing with.
And stalled out at 8.4v in I saw about 1amp.
I did order some CC 10A BECs
Old 05-31-2023, 01:40 PM
  #531
Tip22v
INPUT,OUTPUT
8.4, 7.75
8.3, 7.67
8.2, 7.57
7.6, 7.02
Ah-Hah!
(Pulse on = 18ms)
(Pulse off = 2ms)
Thanks for this analysis, I finally understand why the output voltage (on my DVM) is less than the input voltage with no regulator. -Tom
Old 06-05-2023, 01:56 AM
  #532
Catmanrc
It's interesting too that the ratio of 18ms ON to 2ms OFF is a 90% ON duty cycle.
90% of 8.4V is 7.56V
Basically what the DVM showed.
Old 06-05-2023, 05:53 AM
  #533
Tip22v
isn’t cycling ON/OFF how switching regulators work? The difference here is the the average output voltage is not stabilized at a particular voltage but instead varies based on the input voltage.
Old 06-05-2023, 06:11 AM
  #534
Catmanrc
Yes, switching regulators work in a similar manner.
Input voltage is switched on/off and then filtered through a circuit to produce true DC at the desired level.
They can step up the voltage or step it down.
Called Buck or Boost modes.
The main differences here being that a switching supply switches at much higher frequencies.
Like 20,000 up to 2,000,000 cycles per second, or Hertz.
The JP unit is switching at 50 Hertz (1 / 0.020s)
And it is is not filtered to be true DC.
But goes directly to the motor.
And on the JP, the peak of the ON pulses are at the input voltage.
So if your JP input is at say 7.8V then the average voltage to the motor is
7.8 times 0.90 and roughly 7V
I like your solution for the Xicoy using the regulator.
I plan to do the same.
Once I get enough posts on the forum I'll share some Scope pics!
Chris
Old 06-05-2023, 07:26 AM
  #535
Tip22v
Chris
Thanks for the explanation, very helpful!
Old 06-06-2023, 11:54 AM
  #536
Catmanrc
Tom, need some guidance.
This is a T-One Mini so just a nose door.
If I have the door say closed on Step 1 and Open on Steps 2-8
Then when putting the gear down it opens during step 2, or starting with step 2
But on gear up it closes during step 1
From the earlier posts is the best practice to spread out the overall Up/Down over most or all the steps?
Old 06-06-2023, 03:15 PM
  #537
Tip22v
let me check my T1 mini settings and I’ll share those with you. Should be able to get the settings posted in a couple of hours.
if I understand your question correct, yes you should spread open/close across many steps.
Old 06-06-2023, 06:11 PM
  #538
Tip22v
here are my programming steps for the T1 mini:
start at Gear Up, doors closed
step 1 - doors open, step time 1.5s
step 2 - step time .4s
step 3 - step time .1s
step 4 - step time .1s
step 5 - Gear Down, step time .1s
step 6 - step time .1s
step 7 - step time .1s
step 8 - step time 1.0s
end at Gear Down, step time 1.5 s
Old 06-07-2023, 02:20 AM
  #539
Catmanrc
Thank you.
Old 06-13-2024, 05:00 PM
  #540
helijj
I know this is an old thread, but I recently installed a new Aerofoam L39 Pro turbine and replaced all the stock parts with the Xicoy LGC 15. I'm encountering an issue where the retract activates immediately and retracts whenever it wants to. I keep getting a "check switch" message, even though I don't have that option activated. Additionally, the nose servo doesn't move when directly connected to the unit, although it works when connected directly to the receiver. Also, if I manually open the retract, it works, so the issue seems to be with the switch. Any help will be much apreciated!
Old 06-14-2024, 01:56 AM
  #541
Dansy
My Feedback: (53)
Dansy's Avatar
I have to assume you setup the steering channel? You need to setup the throw in the controller..
Are you using it with normal channels or digitally….I have these and the GS200, they are a little different to setup but normally work extremely well…
Old 06-14-2024, 05:01 AM
  #542
Len Todd
You have two different things going on.
To isolate the intermittent gear operation, I would start by checking the Rxer output ppm on the Rxer channel used for gear input to the LGC. If the Rxer output is consistent with the expected switch operation, then I would check the wiring from the Rxer to the LGC. I would be looking at the ppm at the LGC end of the wire harness. If all this checks out, I would ensure the JR plug is in correctly in the correct input port on the LGC. Then, if all this is correct, I would be replacing the LGC with my spare.
To address the steering issue, assuming the nose gear channel shows 100% travel on the Txer's monitor and the output ppm from the Rxer's steering channel to the LGC checks OK, for initial LGC programming I would set the nose wheel travel initially at 100% in the LGC for testing. I would leave the Txer's steering channel travel at 100% travel and after Rxer's steering channel output tests ok at the LGC end of the wire harness, use the LGC to control the amount of nose gear travel.
All this assumes you have programmed and wired the LGC correctly. While the manual sucks, if you follow it closely you should have success. I always setup the gear, LGC and Rxer on the bench and have it working before installing it. It is a lot easier to figure things out that way. Then after installing it all, I fine tune it at the field.
Old 08-23-2024, 05:02 PM
  #543
RadialWacko
Having issues with the gear doors. For some reason when I attempt to adjust the servo end points they barely even move at all... One of them doesn't even move at all. Not sure what's going on? I have plugged the servos into a regular port on the receiver and they all move a normal amount with stick inputs. What am I doing wrong?
Old 08-31-2024, 06:43 AM
  #544
Slapnutz
I have one of these LG 15 that works perfect, I got another one and now for the life of me, I can't figure out why i have the main retracts and the nose gear going opposite directions no matter what I do. What am I missing or doing wrong?
Old 08-31-2024, 08:11 AM
  #545
Afterburners
Afterburners's Avatar
Even reversing the polarity of the main and nose gear retract wires at the controller causes them to go the wrong way?
Old 08-31-2024, 01:15 PM
  #546
Catmanrc
My touchscreen stopped working.
What have people been doing to fix it?
And/or what causes it internally?
Old 08-31-2024, 03:18 PM
  #547
Len Todd
Just reverse the connectors to the LGC
