Old 06-10-2024, 02:20 AM
  #55026
1200SportsterRider
1200SportsterRider's Avatar
As my Dad was fond of saying, "this thing is as handy as a shirt pocket."
Old 06-10-2024, 03:39 AM
  #55027
Cougar429
Cougar429's Avatar
Yep, although for his generation, a pocket without a protector would likely get you thrown out of the "Smart Kids" class. Man, showing my age here.........
Even though grew up with mechanical versions that used many times a day, have one of these digitals down in the build room, one up here in my office and another in my tool box at work. A lot easier to read quickly. Just need to ensure accuracy as a few Pac Rim models are notoriously bad. Also, some eat batteries more than others, even when "OFF" in their cases.
Been a while since on this thread and some interesting info. Started off with the post on the plug and it brought up what I read recently on a CD given to me on how to fix a few faults on Quadra gas engines and how some of it could apply to pretty well all makes.
One in particular is a quick mod to the plug to improve spark and starting. That and an RMJ ring are intended for the DLE 30 that would replace the S150 if found to not have enough power. Really want to avoid that since much prefer the Saitos. Another consideration since nitro fuel is more difficult to get now and why I had been reading up on ignitions is to mod the 150 for nitro ignition to try and reduce consumption.
And again, for some reason cannot upload pics........
Old 06-10-2024, 04:44 AM
  #55028
Jesse Open
Jesse Open's Avatar
Yessir,
Very handy, We keep them around everyhere.
Fifty plus years in the trade and some tools begin to multiply. There was one place I worked however that would not allow measurements from the rotating dial calipers. They preferred we use linear vernier type calipers.
Old 06-10-2024, 09:11 AM
  #55029
Glowgeek
A Saito 180 would get you close to a DLE 30. The Saito 220 a little better than a DLE30.
Old 06-10-2024, 12:33 PM
  #55030
Jesse Open
Jesse Open's Avatar
The Saito 180 with CDI and methanol fuel would be close to the power of a glow Saito 220.
Old 06-10-2024, 01:21 PM
  #55031
Glowgeek
My 220 spins a 20x6 very close to the same rpm that my 180's can spin an 18x6W. The CDI will add approx 300 rpm to the top end of either engine however CDI won't really get the 180 close to the hp of a 220 on glow. At least not in my experience. The 220 is a beastly thing at 36cc. Just my thoughts.
Old 06-10-2024, 04:14 PM
  #55032
Jesse Open
Jesse Open's Avatar
Okay
The pair here were within 300 to 400 RPM.
Not close at all.
Old 06-12-2024, 03:33 AM
  #55033
Glowgeek
Okay
Not close at all.
In our scenario, the 220 GI puts out a little over .25 more horsepower than the 180 on CDI.......however all while spinning a 2" larger dia prop. Waaaay more thrust availalable with the 220 if that's what the OP is looking for.
Old 06-12-2024, 04:38 AM
  #55034
Jesse Open
Jesse Open's Avatar
"If" .....that is what the OP is looking for
Did I say or imply the 180 produced more thrust?
.25 HP sounds about right. "Close"
Old 06-12-2024, 04:41 AM
  #55035
Glowgeek
No, not at all, just clarifying.
Old 06-13-2024, 02:58 AM
  #55036
1200SportsterRider
New, Saito FG 50, turns big lumber.
行程容積 Displacement 50.2cc ボア Bore 43.6mm ストローク Stroke 33.6mm 重量 Weight 本体 Body: Approx. 約2,253g (マウント含 including mount) マフラー Muffler : Approx. 約62g イグニッション Ignition: Approx. 約125g 常用回転数 Practical rpm 1,500~7,000rpm プロペラ Prop 20″×12″~22″×8″
Old 06-13-2024, 04:20 AM
  #55037
FlyerInOKC
FlyerInOKC's Avatar
YUK! I hate the engine mount configuration! Your stuck using there mount and it carb sits behind it calling for a boxed firewall.
Old 06-13-2024, 06:57 AM
  #55038
Jesse Open
Jesse Open's Avatar
Default Like it or not, you will be buying quite a few
Should be a good choice for that Calvin Cartoon Tiger's plane. As they like to say "That's why they make throttles"
The customers often drive designs. That front access to fasteners is probably perfect for service with drone installations.
Looks pretty good to the big customers. You will be buying a few but your grandchildren will spend their lives paying for them LOL!
Old 06-13-2024, 07:18 AM
  #55039
FlyerInOKC
FlyerInOKC's Avatar
I have a FA-56 already to go into the Tiger 2. I had to order a tank so I'm waiting for it to show up.
Old 06-13-2024, 09:15 AM
  #55040
Jesse Open
Jesse Open's Avatar
Lucky we have those little ones on hand already!
Hang on to them.
The war mongers have no use for them, but Saito has little interest in building them.
Drones are where the money is, at least for now.
Old 06-13-2024, 09:39 AM
  #55041
FlyerInOKC
FlyerInOKC's Avatar
Hang on to them.
No kidding! I love my little Saito engines and will keep them for life!
Old 06-13-2024, 04:24 PM
  #55042
Glowgeek
Anyone here notice the lever BEHIND the throttle lever on the new FG-50?
Possibly a choke or fuel enrichening device?
On another note, due to the apprehensiveness of many sceptics concerning proprietary Saito gas carbs, I feel Saito would have greater sales numbers and a higher return on investment had they marketed this and other FG's with Walbro carbs. Just seems they're trying to reinvent the wheel. That said, I'm not a skeptic, my FG's run quite nicely with the proprietary carb. How long the carb parts will be available is my primary concern ie I can get rebuild kits very cheap for 30+ yr old walbro, zama and tillotson carbs.
Old 06-14-2024, 10:33 AM
  #55043
the Wasp
hey Guys. I don't know if this is a big thing these days with the new radios, but how close can I mount my battery pack (NiCads) to the Rx and antennas? I ask because the people use-to say to keep them as far apart as you can.
I am trying to lighten up my 57" P-40 because I had to add 3/4 of an once to one side of the wing for balancing. and as of now to balance the length I have 1.1/2 OZ in the cowl right behind the prop. so if I move and mount the battery pack beside the RX, the Pack will be just about centered to the Main Spar. and I could take some weight off from the nose.
maybe I am making too much about this, because I don't see me lighting it up more than just 1 OZ. and 1 OZ is not much. what's yeeA think?
thanks guys!!
Old 06-14-2024, 11:22 AM
  #55044
Glowgeek
thanks guys!!
The size and density of the battery CAN shade the TX signal if too close to the RX. Does your RX have a remote/aux RX? If so you can put the batt very close to main RX and position the remote RX to get a good signal from all directions. Range check, range check, range check!
Old 06-14-2024, 06:40 PM
  #55045
the Wasp
""remote/aux RX?"" no I do not have one. I guess I could get one, but that would add weight LOL. they must weigh close to 1/4OZ or a bit more. I always range check. but I have to say, I have never had a range problem here in Vermont. not even with PCM.
thanks Lonnie!
Old 06-16-2024, 02:56 AM
  #55046
1200SportsterRider
https://oldschoolmodels.com/raven.htm New from osmw, I don't think a Saito will work here. It's called then Raven, it sure is a good looker.
Old 06-16-2024, 03:46 AM
  #55047
1200SportsterRider
Here is an "almost" explanation of the FG 40 choke.
Old 06-16-2024, 06:30 AM
  #55048
FlyerInOKC
FlyerInOKC's Avatar
Interesting!
Old 06-16-2024, 06:46 AM
  #55049
Glowgeek
It'll be interesting to see how Saito intends to choke the FG-50 too.
Old 06-17-2024, 03:19 AM
  #55050
1200SportsterRider
BTE - Flyin' King
It appears that Bruce Tharpe is shutting down, what a shame, I am lucky, I have a Flyin King ready to cover, one of the nicest flying planes I ever flew. I powered it with an early high compression Saito 80. This one will be powered by a Saito 100 with CHI, simply because I have a 100 that is sitting in it's box.
