Old 07-06-2024, 12:34 PM
  #55126
FlyerInOKC
FlyerInOKC's Avatar
Originally Posted by Jesse Open
Good catch on the Twin. Hope you got a great deal. I had the 300 in a Smith Miniplane. Made a surprising amount of power. Ran very smoothly and hand starts were easy (back flip) .
Hope you are still young enough to fly the Globe Swift by the time it is done
I make no guarantees!
Nice Bipe by the way! I think Lonnie treated me right on the price, I'm tickled to get it. I figured with Lonnie being I didn't have to worry about actual condition or anything else with the sale.
Old 07-07-2024, 01:05 PM
  #55127
the Wasp
I took another look at this one today. it's hard to get good pic of the fuzzy valves and cam.
NOTE, after I uploaded the pic, they look better on the forum than my computer.
Old 07-07-2024, 04:17 PM
  #55128
FlyerInOKC
FlyerInOKC's Avatar
Cam time!
Old 07-08-2024, 02:47 AM
  #55129
1200SportsterRider
1200SportsterRider's Avatar
To me that cam looks good, teeth not worn lobes look good. It does appear that it was ran sans enough lash, the base circle looks as if it was being rubbed pretty hard.
Old 07-08-2024, 10:18 AM
  #55130
Jesse Open
Jesse Open's Avatar
I'm no where near as fussy as some, still that cam assembly would get dropped in the can here
Old 07-08-2024, 10:33 AM
  #55131
Glowgeek
+1 and no doubt the tappets as well.
Old 07-08-2024, 01:47 PM
  #55132
the Wasp
it needs a new cam, but that one lobe is not sO bad. one of the tappets was worn a good more than the other. so one lobe is worse than the other.
my my BTW, did you guys see that guy on RCG selling that NIB K&B 82 racing engine with 2 T-pipes for $65? what an engine. I wanted to buy it just to have and look at, but I won't.
Old 07-09-2024, 01:41 AM
  #55133
1200SportsterRider
The current replacement offering for the 100 has both lobes rounded like your exhaust lobe.
Old 07-09-2024, 05:04 AM
  #55134
easystar123
Location: Kilrea, County Derry, N.Ireland. United Kingdom
Default Saito 62 powered Piper Cherokee.
Last night flying the Great Planes Piper Cherokee.
Old 07-09-2024, 06:25 AM
  #55135
1200SportsterRider
Nice plane and nice flight, I had a Cherokee 40 years ago, an ? ARF, it was almost too heavy for a Saito 50 GK.
  #55136
Glowgeek
Nice flight, Aidan. Nice greasy landing too.
Old 07-09-2024, 06:31 AM
  #55137
1200SportsterRider
The SpadPort is coming along, I sure do have wrong pilot for this plane. I improved the exhaust, it now has pipes, the end stacks go into the fuse to fasten it, it's not fastened yet, nor are the upper wing mounts.
Old 07-09-2024, 07:06 AM
  #55138
FlyerInOKC
FlyerInOKC's Avatar
Looking good!
Old 07-09-2024, 07:14 AM
  #55139
easystar123
Thanks Lonnie. It's one of my favourite planes to fly.
Old 07-09-2024, 07:21 AM
  #55140
easystar123
Thanks Dave. The Saito 62 flys it nicely. Anything smaller and it would struggle as it is a fairly heavy plane.
Old 07-09-2024, 06:35 PM
  #55141
modeltronics
My Feedback: (27)
Dave
Do you use magnetic building fixtures for framing your plane?
Old 07-10-2024, 01:12 AM
  #55142
1200SportsterRider
Yes sir, I had the complete Eldon J. Lind magnetic building board system. Several of the plastic pieces have broken from aging and getting brittle. I have replaced some of the verticle pieces with aluminum bars. At 30 plus years old it has served me well. My building bench is topped with two .125" steel plates laminated and screwed down to .75" plywood.
Old 07-10-2024, 02:19 AM
  #55143
modeltronics
My Feedback: (27)
I am in the process of making a magnetic building system. I'll email you some pictures and questions since it is a little off subject here.
Old 07-10-2024, 12:46 PM
  #55144
Noahsarc5914
thanks guys!! Just bought a bfand new FG -61ts gas engine. Question: when putting in the 1oz of oil before initial break in start, do I lea e the gas line and screw on forever or just for the initial break in period?
thanks so much. Noah Schechtel
Old 07-10-2024, 01:37 PM
  #55145
Glowgeek
There is a translation problem in the instructions. It says the inject 1 oz/30cc of oil in through the crankcase breather nipple, that's fine, but the nipple should never be plugged. Inject the oil and then rotate the engine while holding it in your hand in different ways while rotating the prop, this will distribute the oil to all internal parts of the engine. Then flip the prop to eject excess oil from the crankcase nipple and attach a piece of fuel line to the crankcase breather nipple before starting the engine. The prelube oil is only used before the first startup of the engine.
Old 07-10-2024, 02:27 PM
  #55146
modeltronics
My Feedback: (27)
Hey Lonnie. I'm going flying in a bit. Care to join me? Its only 94 out. I'm not sure if I'm going to make it for more than one flight.
Old 07-10-2024, 02:32 PM
  #55147
Glowgeek
Yeah, sure. Be there in a minute.
Old 07-10-2024, 04:14 PM
  #55148
modeltronics
My Feedback: (27)
Lonnie, you missed out.
I only put in 1 flight on a trainer with a FA-45. It's been modified with a 50 cam and a few other parts. It runs sweet.
I did learn something when I was out flying. Never go out in the hot Texas sun flying wearing a black t-shirt. You probably already knew that since you lived in Texas at one time.
Old 07-10-2024, 05:21 PM
  #55149
Glowgeek
Gets hot here too, Pete, and usually with much higher humidity than Texas summers. I spent a lot of time outside when I lived there, racing mountain bikes and road bicycles. I learned real quick how to keep from heat stroking.......it was all about hydration and high tech riding gear. Cool max, Biotech and other special moisture wicking fabrics. Thing is, nothing helps when it's dead calm and you're standing still. Around here we just shed as many clothes as is legal and keep working.
Glad your pseudo 45 special turned out to be a runner.
Old 07-10-2024, 06:39 PM
  #55150
Jesse Open
Jesse Open's Avatar
That old 45 finally found a happy home.
I still have a 45/50 hybrid here.
