Old 07-25-2024, 06:44 AM
  #55251
Glowgeek
Originally Posted by Jesse Open
Don't they both mean the same thing?
(To men anyhow)
I was taught that green means go, yellow means go faster and red means haul a**!
Old 07-25-2024, 10:23 AM
  #55252
Jesse Open
Jesse Open's Avatar
I was relating to "Stop-Go / No- Yes" relation
Old 07-25-2024, 11:38 AM
  #55253
1200SportsterRider
1200SportsterRider's Avatar
I had very little rc time today, Geri's Pneumonia has left her washed out and listless. I took her to the Dr. Then had to wait for a prescription be ready, day shot. I didn't like that black prop nut sticking out there sort of by itself. (On the Spad)
I took a Tru-Turn .25" x 28 spinner adapter, cut the cone down to match a Saito prop lock nut, me thinks it looks better.
Old 07-25-2024, 12:43 PM
  #55254
FlyerInOKC
FlyerInOKC's Avatar
Looks good!
Old 07-25-2024, 02:28 PM
  #55255
1200SportsterRider
Thanks Mike, I didn't know if I could cut it down because of the slit which might catch the cutter but the blade cut it as if were not there.
Old 07-25-2024, 07:09 PM
  #55256
the Wasp
that black washer gives a great scale look.
Old 07-27-2024, 04:25 AM
  #55257
1200SportsterRider
I like this prop better. It's a Xoar 12x5.
A look from the front with the rudder covered. The red and blue are Oracover, the Pearl white is ?
Old 07-27-2024, 05:54 AM
  #55258
FlyerInOKC
FlyerInOKC's Avatar
I was lazy when Callie made my insignias I had her do a tricolor stripe for the rudder.
Old 07-27-2024, 07:05 AM
  #55259
1200SportsterRider
Yes sir, I receive that too but they were only 4" long and the rudder is 7" tall. I have 5" roundels for the wings and 2.5" for the fuse. If I can I'm going to cover the fuse this PM.
Old 07-27-2024, 07:38 AM
  #55260
FlyerInOKC
FlyerInOKC's Avatar
You should have told Callie she would have corrected the size and sent you a set.
Old 07-28-2024, 02:40 AM
  #55261
1200SportsterRider
I may do that, that is the third rudder I made for it, I have .25" balsa that is super light and yet not soft. The problem was that where the colors overlapped over an open space, the edges would curl back.
I am studying instrument panels this Spitfire panel is a pick and choose, roll your own I can customize to suit, I think. 15 bucks at Callie's.
Old 07-29-2024, 09:54 AM
  #55262
the Wasp
Hey Dave. what are you doing to do for wings? are you going to make corrugated plastic wings or use old wings off an older plane or make new ones with Balsa?
Jim
Old 07-29-2024, 04:54 PM
  #55263
1200SportsterRider
Thanks Jim, I already built them, they're part of the kit. The ailerons are bottom wing only.
Old 07-29-2024, 06:27 PM
  #55264
Jesse Open
Jesse Open's Avatar
What is the finished weight supposed to be?
Old 07-29-2024, 06:45 PM
  #55265
the Wasp
I got off topic somewhere, somehow. I don't remember you covering that one in white.
Old 07-30-2024, 01:55 AM
  #55266
1200SportsterRider
The covering is Oratex from Balsa USA.
3.5 to 4 lbs.
Not much is covered yet, it is going to be Olive drab.
It will match the grill. Some of the covered pieces are laying at the rear of the fuse.
Old 07-30-2024, 03:03 AM
  #55267
Jesse Open
Jesse Open's Avatar
A few more photos from the Old School Model Works site.
Very nicely done instrument panel.
Old 07-30-2024, 03:51 AM
  #55268
1200SportsterRider
Thanks Gary, Callie has my order, I'll see what I can create.
Old 08-01-2024, 07:40 AM
  #55269
1200SportsterRider
The Spad covering is being changed to Oratex, it's so easy to work with. Corners are not hateful. I just finished stripping the elevator. The fabric looks so much better, me thinks.
Old 08-01-2024, 08:23 AM
  #55270
FlyerInOKC
FlyerInOKC's Avatar
Are you going to have to repaint the front radiator?
Old 08-02-2024, 01:21 AM
  #55271
1200SportsterRider
No sir, I discovered in doing research that there are many shades of "Olive Drab", that little bottle in the back left has a four digit number for t's shade. I kinda like that contrast between the OD covering and the more grey like OD around the grill. The grill is painted from a small 4 oz.rattle can. I don't think I'd want a Saito in either color. I may be able to fly this thing in a War Bird event.
XF 74
TS 70
Old 08-02-2024, 03:29 AM
  #55272
Jesse Open
Jesse Open's Avatar
Dave, are those paints fuel proof?
Old 08-02-2024, 03:43 AM
  #55273
Glowgeek
If it's not lacquer based it's not fuel proof. Tamiya makes a fuel proof top coat (P-26) which is reported to work well over their acrylic paints.
Old 08-02-2024, 04:03 AM
  #55274
FlyerInOKC
FlyerInOKC's Avatar
A little contrast never hurts!
Old 08-02-2024, 04:47 AM
  #55275
Jesse Open
Jesse Open's Avatar
Yes, of course. That was the point. It may need a top coat.
BTW, some well cured Alkyd Enamels are highly fuel resistant.
