Wrong carbs on your engines
#51
RE: Wrong carbs on your engines
Jack - I am not trying to proove or disproove anything
If I have upset your applecart
that's just too bad. I was just ramblin on about stuff about carbs I have worked with for a few years
You want numbers - go look em up I am going to go read the paper -
#52
OK
ORIGINAL: dick Hanson
#54
WY
!st statement, Yall got the wrong carbs on your 100-210cc engines.
Current statement, Yall got the wrong carb on your 100-210cc engine IF you can't adjust it rich at WOT..... duh really and you gotta to be a rocket scientist to figure this out??
Very BIG difference between those two statements.
edited to Correct displacement
#55
Well I did not learn much from this thread, except where to get a good carburator for $12-13 dollars!! Gee I wonder if that carb could have had a fuel restriction that I was working on? I will check it again. Capt,n[:-]
#56
OK
ORIGINAL: tkg
!st statement, Yall got the wrong carbs on your 100150cc engines.
Current statement, Yall got the wrong carb on your 100-150cc engine IF you can't adjust it rich at WOT..... duh really and you gotta to be a rocket scientist to figure this out??
#57
WY
Corrected displacement
Jack you started out with a blanket statement that the MFG's had put the wrong carbs on their 100-210 engines, you now are saying that if it doesn't run right the MFG put the wrong carb on their engine. Big difference between statements
Most of the MFG's have put the right carb on their engines for how we fly them (note fly not race) They adjust fine at WOT. There have been a FEW engine MFG who did not get right and soon the problem is noted on the net. Result no sales or fix the carb problem.
ORIGINAL: jack1933
Hi Terry, Thanks for the input, Just what exactly are you trying to say? where has anyone stated 100150cc engines and same on the 100-150cc engines? Am confused , please explain.
ORIGINAL: tkg
#58
OK
ORIGINAL: tkg
ORIGINAL: jack1933
ORIGINAL: tkg
#59
WY
ORIGINAL: jack1933
Would any of you be interested in the fact that your 100-210cc engines have the wrong carb. on them from the mfgs? IJack
#61
ORIGINAL: tkg
OK so lets ask
WHO HAS AN ENGINE THAT WON'T ADJUST RICH AT WOT??????
OK so lets ask
This is on an engine running tuned pipes so It probably is not relevant
Although-
The exhaust system affect the carb selection on ALL two strokers
I also should never have entered into this thread because frankly I don't understand what the f-is going on.
#62
OK
ORIGINAL: tkg
I'm complaining about your "the sky is falling" statement when you start this thread. The FACT is that over 95% of the MFG's have the RIGHT carb on their engines.
ORIGINAL: jack1933
#63
OK
A local friend who runs DA150's has swapped carbs n reed banks (different sizes) from DA100 - adjustments are just fine - midrange is better - top end power is down.
Although-
ORIGINAL: tkg
OK so lets ask
OK so lets ask
Although-
#64
Jack,
As an outsider to this discussion I suggest you re-read the posts and then tell me who it is whom has the "closed mind".
Yours is so closed it is unbelievable.
#65
To quote jack.....Actual case in point. I could not get the high speed needle to richen at wot, on a 150cc engine with a wga-7 walbro, this was before any mods to the carb. I installed a wb-25 and got the high needle to richen the engine at wot, was testing for air leaks around the intake system, however there was no noticible increase in rpm, and the wb-25 has a larger venturi than the wga-7/9 at that point I started enlarging jets in the carb, it is responding well enough, so its still on the engine. Then I called walbro and was informed the wga-7/9 was calibrated for a 100 cc engine. The wb-25 is going to be installed on the engine, and I know it will work, because its already been on the engine. .................................................. .............................My reply... Walbro told you the wga-7/9 was calibrated for a100 cc engine. But you said you enlarged the jets and got it to respond well. So there is no sense in buying a differant carb. Maybe the wga-7/9 was not made right in the first place. BAD on arrival! Anyway you cuould get it to run rich enough. Right??? Capt,n
#66
OK
ORIGINAL: captinjohn
#67
OK
ORIGINAL: onewasp
Jack,
Jack,
#68
My Feedback: (85)
ORIGINAL: Bass1
I think I bought the last 2 of them.
I believe the WT-76A is still available on *bay for $12.95 new
Kevin
#70
OK
ORIGINAL: oceansfiftyseven
Jack, your the only one making rude comments on this thread. You've made your point. Many times already.
#71
ORIGINAL: jack1933
Right, So there was no reference point to adjust the hi needle.5th wga-7/9 that has responded this way, recently.
#72
ORIGINAL: jack1933
Colsed to what exactly. All I am trying to do is inform other modelers about a serious situation, If you cannot understand what this thread is all about, then it is not for you. Negative comments are not what RCU is about. personal attacks are unacceptable on here.
ORIGINAL: onewasp
Jack,
Jack,
A statement of the obvious qualifies?
I think not.
Through what great act of benevolence did you grace us with your presence ?
That is surely what seems to be the attitude presented here.
#73
OK
Are you saying that is 5 five wga-7/9 carburators responded the exact same way? What do you call a reference point...is it like 1-1/2 turns open? Now if that was five carbs, how many others did you try before and did any of them adjust ok? I am trying to get the total picture here and maybe learn something! Thanks Capt,n
ORIGINAL: jack1933
Regards to all
Jack
#74
OK
ORIGINAL: onewasp
What personal attack???? Where ???
I think not.
ORIGINAL: jack1933
ORIGINAL: onewasp
Jack,
Jack,
I think not.
#75
Jack, are these engines you are talking about that will not go rich, is that on a test stand or in airplane? Just for data on this...what Prop...what is hi RPM (average will do)....what is the placement of fuel tank and how big of lines and or filters are you using? I caanot for the life of me figure out why five of the same carbs will not richen up. For every happening there is a cause...I would think! Thanks, Capt,n[X(]
