Extremeflight 88.5" Extra - Build and Fly
#52
My Feedback: (40)
RE: Extremeflight 88.5" Extra - Build and Fly
I am using a KS pipe for it. This plane will probably be my IMAC plane for this year so I figured might as well do a pipe.
I can see myself buying a second one already. One for IMAC and one for 3D
#54
My Feedback: (40)
This year I am flying sportsman. I did 2 last year at basic to try it out and became addicted. I hope to hit 6-7 this year if not more
#55
My Feedback: (40)
welp.. I finally got some time to work on this baby again..
#1 The graphics are finalized and on the way... here they are.
#56
My Feedback: (40)
onto hinging the rudder..
once again some toothpicks, 3-in-1 oil and some gorilla glue. If you get your glue amount correct this way works like a charm.
#57
My Feedback: (40)
One of the most things I enjoy most about building is when you start putting the graphics on and the plane starts to look realy good
#58
BC, CANADA
Yes it does,good graphic and color placement.I did not care for the yellow at first,but your decals are working well with it.
#61
My Feedback: (40)
more progress..
* Note, if you want your canopy to actually fit back on the plane put the closing back piece of gray depron on the inside of the cockpit and not the back
#62
My Feedback: (40)
You can use foam safe CA or white glue for the depron, I guess you could use epoxy as well. I opt'd for foam safe CA
#63
WA
JAKE HAVE YOU FLOWN IT WITH CA HOLDING PILOT ON? I AM WONDERING HOW IT WILL HOLD UP?
I HAVE THE SAME SET UP WITH THE BRILLELLI, WHAT PROP YOU USING, WHAT RPM'S, WHAT ALTITUDE?
ALSO WHAT IS YOUR RADIO SET UP? WHAT IGN BATTERY DID YOU USE, AND HOW FAR IS MODULE FROM
RECEIVER? ONE MORE DID YOU USE CHOKE SERVO?
YOUR PLANE LOOK'S AWESOME!!!!
I HAVE MY GRAPHIC'S KIT IN THE WORKS AT BAD BRAD. LET ME KNOW ABOUT SOME OF THESE QUESTIONS
IF YOU HAVE TIME. I AM HEALING FROM FRACTURED SHOULDER SO AM TRYING TO GET ALL GOODIES HERE
AND READY. RIGHT NOW ALL I CAN DO IS LOOK AT IT AND WAIT!!!!!!!!!!!!!!!!!!
THANKX 3DAP
THANKX 3DAP
#64
My Feedback: (40)
3DAP... thats hard to read hahha ALL CAPS is generally considered yelling and hard on the eyes
I haven't flown the plane yet.. snow and sub 30 weather right now. I will be running a Mejzlik 23x8, will be using 9303 2.4 with an R921, remote receiever, Smart-Fly Sport Plus, and A123s. Ignition will be a 1 cell Lipo... no choke servo.
Sorry to hear about your shoulder! You will like yougraphics when you get them.. Brad is top notch!
#65
NJ
I got three flights on mine yesterday, best flying 50cc plane I've flown. Everything about it is good, quality construction, best looking 300 on the market, good service from E.F., etc.... This plane is locked in on rails, very solid performer and feels like it's much bigger than it is.
Lee
Lee
#68
WA
JAKE,
THANKX FOR INPUT, CAPS IS BECAUSE TYPING WITH LEFT HAND. TOO PAINFUL TO TRY BOTH HANDS.
I AM HATING LOOKING AT THIS BIRD AND NOT STARTING THE BUILD YET. THANKX FOR BUIDING TIPS
THOUGH. I WILL HAVE IT BUILT IN MY HEAD BEFORE I EVEN START IT. I AM GOING TO PUT A SMALL
SMOKE TANK IN ABOUT 12-16 OZ. HAVE YOU THOUGHT ABOUT IT YET?
3DAP
3DAP
#70
My Feedback: (40)
I forgot 3DAP!! That explains the caps... my bad sorry!
I will be doing some more on it this weekend. I have to mount the wheel pants and the engine as well as the final pieces related to that. I will continue to update the thread until it has several flights and some video here for yas.
#71
WA
Jake,
What is the name of blue and yellow color's of ultracoat on this bird? Working
on no cap's, much better eh?[sm=thumbup.gif]
3DAP
3DAP
#72
My Feedback: (51)
Jake
For what it's worth the CA won't be able to hold your Pilot in pace more then a handful of Flts..........
There is lot's of Vibration which U will see as soon as U start her up. Cut a 5 cent size hole in the Center and Glue a small piece of wood into the Pilot Base.
The use 2 screws to hold him down. This and in my Cases Shoe Goo has never failed while just CA has.
Ian
Ian
#73
My Feedback: (40)
3DAP I am not sure actually.... its true ultracoat so maybe could tell by looking at an ultracoat site. However it might be hard to tell that way depending on how good of a picture they show. Maybe Chris will chime in..
FlyJets, ya I have been wondering about that myself.. I think the dash will be ok but the pilot has a bit more mass. Maybe I will give that a go.. thanks for the tip!
I am hoping to clear off my bench today and get some work done on this baby. With it being in the 20s outside it's not very encouraging!
