BJ55 Strut/ Stuff Tube
#52
Why do you have the rudders tilted? The carb settings seem a little off to me. I would expect around 1 5/8 or greater on the L and around 1 on the high. This might explain why it seems to bog for you on glass surface. 8mm on the allen key sounds good, neutral or maybe 1 degree negative. Did WHH give you any guidance on the carb settins with the M5?
I found with my stock engine it performed great with the Zenoah factory settings of 1 5/8 and 1. With the CC promod I'm at 1 7/8 L and 15/16 H.
Are you measuring from the cylinder head on the pipe measurement? If so you may not be far enough out. See attached guidance from BH Hanson I believe.
#53
I have the rudders tilted alittle to help lift the bow and it does help. I have the 644 carb not the 257 and there is 3 of us that are running the same carb but took the choke out and we all are close to the same on our needle settings. Back in april in the cooler weather we were running our high speed needles at 2-2 1/8 the m-5 couldn't get enough gas. I have tried leaning out the needles during the summer and it hasn't worked. Whh didn't give any carb settings with the m-5. Yes my 12 3/4 measurements are from the cylinder head to the center of pipe and I don't have much pipe to pull out or I will be past the 2nd o ring.
#54
I had the 644 on my stock Zenoah as well. The difference between the two is the absence of choke plate and air purge bulb on the 257 otherwise the same so needle settings should be similar. If you are too lean on the low your RPM's won't go high enough for the H setting to make much difference. 2 Strokes charge up the crank case with fuel as they run. If you are too low on the L needle that depletes and you find your engine bogging.
When I got the CC pro mod it had been set up in a rigger, much lighter boat. The settings were very near the stock settings. The first time I ran it would bog badly. Turned the needles out to CC's recommended settings of 2 and 1 and all was good.
Now an engine is esentially a heat pump. The heat of the expanding gases puts pressure on the piston causing a pumping motion. If you think about it in order to have more force you need to create more heat therefore you need more fuel. So a modified engine should at it's least need the same settings as a stock engine if not more. I'd expect the factory settings are a tad rich for preservation. My point being if 1 5/8 L is needed for a stock engine how can less work with a modded engine?
You're right about the pipe now that I think about it. The header pipe length was the limiting factor on mine as well. That said I was able to get 13 5/16" out of mine, just measured it. That gave me a top RPM of 16360 and speed of 49.25 MPH. If you use a pipe stop it just needs to be on the pipe with maybe and 1/8†to spare. The pipe stop will keep it from moving around and leaking.
Why do you want to lift the bow? That would lead to blow overs in my mind. Keep her flat and let the prop lift here up.
#55
MO
ORIGINAL: hibby
Peerpsi bottom of tunnel to bottom of strut bracket is 1/2'' and bottom of tunnel to bottom of rudder bracket is 1'' and from the ride pads to where the ferule joins the prop shaft is 3/8'' and that is with the strut raised and prop tillted in a positive position. My boat has been running wet not loose and am trying to get it to run looser which will up my speed.
#56
MO
ORIGINAL: hibby
[img][/img]0307Here is my set-up I will be trying tomorrow at the lake I will try a more neurtal set-up and used the 8mm hex key under my ferule for my strut set-up. rudders are aeromarine, my pipe is the stock o band pipe distance is 12 3/4'' carb settings low speed-1 1/8 high speed-1 3/4. I have my clutch off now but had been running it with. I really think about 45-47 mph is going to be the max for my boat with m-5 which I am happy with.
#57
MO
If I set my low needle out more then 1 1/8 turn if will not even stay running. My settings are 7/8 - 1 on L and 1 1/2 on H . (This with stock motor)
#58
I think that's way too lean on the low. Next time try the factory stock settings of 1 5/8 L and 1 H.
So the boat loosened up for you good stuff.
#59
MO
ORIGINAL: PEERPSI
#60
MO
Here is a link for mt carb settings. Yes the boat loosened up nicely.
http://www.proboatmodels.com/ProdInf...ine_Manual.pdf
#62
ORIGINAL: Dockman
#63
ORIGINAL: Dockman
#64
Your starting point settings will depend on the carb you run, each type of carb has a different needle setting to start from. Here's a link to the baseline settings for each carb.
http://bonzisports.com/carbs.html
If you have swapped the carb out on your engine to a different type of carb, you will need to set the needles up for that specific carb, then fine tune to the engine/pipe/hull/prop/altitude you are running.
#65
My point is the carb settings after installing a mod cylinder intending to make more power can't possibly be less then stock. An engine will only make more power by burning more fuel, not less.
Also any carb setting chart I've seen always has the L higher then the H. If you look at the chart I posted they are about even for the lower rpm lighter load aircraft and then the L starts to go higher then the H as the load increases first marine engine and then helicopter being the highest.
Back in my sports car days when we built up for power the injectors were selected for the HP you were attempting to create. Always more flow for my power, never less.
#68
MO
Can't screw the idle screw in far enough without clutch so I use the gun and have it turned up to 50+ and then turn it back down alittle after take off. With the clutch I can use idle screw but no way will it start at 1 1/2 turns out and will not idle very well at 1 1/4 out. My runs at it's best 7/8 out but I try to run it at 1.
