Avonds F-15 Construction
Old 07-21-2003, 01:26 PM
  #51
seanreit
My Feedback: (60)
seanreit's Avatar
Default Avonds F-15 Construction
Nice work Mike. I especially liked the comment on the balsa for the intake. I didn't know about this. Thanks.
Old 07-21-2003, 01:34 PM
  #52
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
Thanks for the kind words Sean. I hope everything is getting back in order for you!
Old 07-21-2003, 01:52 PM
  #53
seanreit
My Feedback: (60)
seanreit's Avatar
YES!! My ISOBAR is sitting on my bench with wires hanging out of it. Engine is mounted, I'm a few days away from TAXI tests. If all goes well, I'll first flight it this weekend. I have another KANGAROO RTF. Got another third scale plane, but need a bigger engine than my G-62 so I won't be working on that for a couple of months till I can get a BME 102. It's been a rough few weeks in that I got that Turbine bug, burned 31 gallons of JETA and then whammo, I'm out of commision. Anyhow, I should be back in the air in the next few days. Thanks again! Sean
Old 08-18-2003, 02:14 AM
  #54
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
Default Nauwa Cockpit kit
As you can see here I have added some ply rails to the balsa cockpit sub-deck
Old 08-18-2003, 02:15 AM
  #55
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
The deck is then cut where the cockpit tub will go.
Oh yea Thanks JohnnyA for the cockpit kit!!!!!
Old 08-18-2003, 02:17 AM
  #56
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
mark the fuse and cut out where the ply rails will fit down into the fuse. I got too aggressive when trimming the fuse lip and made it too thin so I will add a crossmember behind the tub.
Old 08-18-2003, 02:20 AM
  #57
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
glue on tub
Old 08-18-2003, 02:21 AM
  #58
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
add some balsa to reinforce the front of the tub
Old 08-18-2003, 02:22 AM
  #59
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
Here is the cross member I installed right behind the tub. I will add some lightning holes in this part later.
  #60
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
finished deck
Old 08-18-2003, 02:26 AM
  #61
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
I shimmed the parts in the wing to ensure the wing was properly aligned with the fuse. I inserted T-pins at the end of each ply part to ensure they don't get pushed too far into the wing as I pushed the wing onto the fuse.
Old 08-18-2003, 02:27 AM
  #62
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
Default Jigging the wing
I then taped on the bottom wing shucks to ensure proper alignment to make it easier during wing jigging
Old 08-18-2003, 02:30 AM
  #63
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
When I was satisfied with the wing alignment, I glued in the spars, carbon pins and ply parts using 9462 and added the top wing skin shucks and added weights.
Old 08-18-2003, 02:32 AM
  #64
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
Default the rudder
Although not shown on the plans, I wanted to add hinge blocking into the rudder/fin.
Old 08-18-2003, 02:34 AM
  #65
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
I then added the Rudder leading edge and fin trailing edge and discovered I goofed....so I then decided to try a scale hinging job.
  #66
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
I then cut out additional material for the scale hinging.
Old 08-18-2003, 02:37 AM
  #67
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
I chose to make the hinge rod removable from the top of the fin so I clamped the rudder in place and pushed the hinge rod through the robart hinges I glued into the rudder and through the foam in the fin until it came out of the top
Old 08-18-2003, 02:41 AM
  #68
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
with the hinge pin still in place I sharpened one end of the outer sheath of a dubro throttle cable and worked it into the foam toward the rudder
Old 08-18-2003, 02:42 AM
  #69
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
the rudder is hinged awaiting the final fitting of the rounded leading edge and carbon laminate strips
Old 08-18-2003, 02:43 AM
  #70
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
I used a router and a 1/2 in cutter to cut out for the Robbe Rudder servo box.
Old 08-18-2003, 02:45 AM
  #71
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
When drilling near the end of a flying surface cut some balsa 1/2 x 1 stock to ensure the jig stays properly aligned
Old 08-18-2003, 02:47 AM
  #72
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
When drilling the fin I had to use an even thicker piece to get the jig almost straight across to be able to drill the holes at each end of the fin
Old 08-18-2003, 02:48 AM
  #73
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
I added the wing root and installed the wings in the airframe to ensure everything stays aligned.
Old 08-18-2003, 02:53 AM
  #74
Topgun2mo
My Feedback: (45)
Topgun2mo's Avatar
Default Taking Shape
I dare say that it is starting to look like an F-15
Old 08-18-2003, 11:10 AM
  #75
steve salmon
Hi
I have got my Avonds F15 complete, now putting scale detail on. Does anyone know where I can get a "killer Cockpit" for this Jet. I have tried Avonds but discontinued. Help, shame to do all that detailing without some where to sit!!
Steve
