50cc Edge V2 has landed
#51
My Feedback: (17)
KY
RE: 50cc Edge V2 has landed
The gear that almost all online stores are offering is the gear for the old version extra and edge so we have to find a set of gears that are similar in size to the new version and hopefully lose an oz or 2.
#52
TNT Landing gear will make gear out of any thickness material you want, typically 3/16 " and 1/4". The stock gear is only 1/8" and while attractive and light, will not withstand much abuse. I suspect the 1/4" would be too heavy, so a 3/16" made from heat treated aluminum should be adequate. I had stock gear on a 29% Aeroworks Edge and it was too soft so got a 1/4" from TNT which was bullet proof. The AW Edge has a thin and untapered profile. Once TNT gets the pattern they will offer it on their website catalog.
#54
Were they the supplier of your previous CF gear? I recall some discussions about delamination. A friend here has a WH 100cc Extra and he was offerred a refund for his gear which seems to be very fair.
#55
I don't believe that W/H has to date marketed any C/F gear sets under the W/H label. Sometime back there were fiberglass sets that worked out pretty well, but obtaining the product was kind of hit or miss. For the 50cc class planes they were pretty light and worked out well, but for the larger planes, 35% say, they did not weigh any less than the stock gear.
Graphtec has always had a return policy when it came to delaminated gear, but as in anything else destructive abuse is not covered.
#57
Muchs gracias to both of you. I was unclear on what the composite gear issue was. I have to confess that I have an occasional landing that might be classified as "destructive" relative to the landing gear! Our grass field has a lot of bumps in it (that's my story and I'm sticking with it!)
#58
New subject, I found the rudder servo tray (pull/pull) to be a bit undersized for the JR 8611. It was just a little short in both length and width. Normally not a problem, but it is tough to enlarge with a hobby knife with the webbing in place. It took me some time, but I was able to enlarge it without breaking the webbing which is quite delicate. It was more of a scraping action than a cutting action. I didn't want to risk sticking my Dremel down there for fear of making it too large, especially on the length.
Also, I chose to use the lower rudder servo trays in the aft fuse for elevator (normally used for rudder push/pull). With the servo arm end of the servo facing aft and by mounting the servo arm upward I was able to get a perfectly aligned geometry using a 2 1/2" Hgr 9 Pro Link and Dubro HD horn set with a ball link on the servo arm. A nice short and tight linkage. Might have achieved the same effect using the upper servo trays and facing the servo arm downward.
#60
Hi,
In the manual there is notting abouth the CG.
Any sugestions ???
No I have make him level at 4,5 inch from the leading edge of the wing,bud the fueltank is in front of the CG and when I fil the tank he is verry nose havy.
Regards
Sapca
Any sugestions ???
Regards
Sapca
#62
SAPCA -
The CG (and other very useful info) was on page three of the Addendum. The CG should be 12.6 cm (5 inches) back from the extreme leading edge, measured anywhere along the span. This is the starting point, and you can move the CG aft another 1.3 cm (5.5 inches) if you prefer. If you didn't get the Addendum send me an email ([email protected]) and I can scan it to PDF and send it to you.
#63
Finally finished! I did not post a lot of the build because others have done an excellent job of that with the new Extra and this plane is very similar. I did try to post things that I thought needed to be mentioned. One thing I did differently was I mounted my fuel tank under the tray (see picture.) Anyway, I did not run into any problems. This plane goes together like it is supposed to.
I did take two evenings and programmed the Hitec servos with the programmer and protractor. I hope that pays off. I installed three 2600 mah lithium ion batteries with three regulators and pin switches. With the batteries up front it balanced at 5 and 3/8th inches. I also used a carbon fiber spinner. All up weight………..16 Pounds 8 ounces !!!!
I am dying to fly it, but the winds today were 20 mph with 30 mph gusts [:@]. Maybe tomorrow. If I can answer any questions let me know. As soon as I fly it, I’ll post a report and hopefully a video.
#65
Ben,
Sorry to be so long in getting back to this thread. I'm not using the Brison this time. Instead I installed a new Taurus 52. With the exception of the spark plug cap it fits entirely withing the cowl. The radial mounting plate is a little different to work with but spreads the torque load of the engine on the firewall pretty well. Only a 7/8" spacer plate required to bring the prop hub out the correct distance.
They're some distinct differences between the Brison and the Taurus, but the Taurus should work out very well if I do everything else right. I keep meaning to take some pic of the Taurus installation and post them but I keep getting side tracked.
#66
I have completed mine also, it came out 15.6 pounds with three 1650 mah 4.8V packs. I used JR 8611As on the ailerons and rudder, Hitec 5925MG on the elevators. Engine is DA50 with a Slimline Pitts (no smoke) muffler, MSC 22-8 prop with Dave Brown spinner. Fuel tank is Dubro 20 oz. Radio gear is Futaba 9C on PCM with ailerons and elevators mixed (no servo programming or reversal). It balanced at 5 1/2" with the ignition pack on the motor box and the radio packs on top of the fuel tank. No ballast.
First flight was uneventful, required only three "beeps" of nose up trim. Up and down lines are straight, knife edge appears to be neutral (little if any tucking). Inverted requires only a breath of nose down stick force. The stall is a non-event, it mushes forward until the nose drops much like a trainer. The airplane is controllable up to and through the stall. Landing speed is very slow with no tip stall tendencies. No tendency to snap out of an abrupt elevator (wall) movement. I am not an extreme flight pilot so am probably not the best source of judging the flight characteristics. However, I will say that this aircraft is considerably better than the Aeroworks 29% Edge (old design builders kit) it replaces.
I remain concerned about the flexibility of the stock gear and have a 3/16" thick 6061 T6 gear coming from TNT Landing Gear. Tom from TNT has the pattern and the gear is now available from them. I am not a big fan of composite gear, so will pass on the upcoming opportunity to use the carbon fiber gear being developed by Graphtex. I also like to keep things simple, so I use a single receiver with dual batteries and switches, no power buss, no Lithium batteries and regulators. Anyone with a reliability engineering background understands the concept of simplicity.
No question about it, this aircraft is a real winner and far outdistances the competition on value. I have been comparing notes with a gentleman from Belgium and we totally agree on this.
#67
ORIGINAL: R.J. Rose Ocala FL
With the release of the new and lighter Version II of the Edge and the Extra there should be a lot of people at the fields with the expensive planes wishing they had gone with the Wild Hare instead. This should prove to be a very interesting flying season with respects to the kit comparisons that are bound to occur.
#68
My Feedback: (17)
KY
My gear has held up really well there was absolutely no probs on mine till i let a couple friends fly it. I let people fly my bird all the time if i believe they can fly. A couple of my close friend flew it and landed a little hard the gear spread a little bit each time i put my foot beside one wheel and they put one of their feet next to the other wheel and squeezed the gear back into the correct shape it was only a couple inches no biggie. The plane i flew my self about 5 times since that and the gear is the same as when i left it. I like The CF gear and when i find a gear thats the same shape as these new versions gear ill get one, that is if its not heavier, but until then i'm not worried about the gear maintaining its shape.
Edit opps i am talking about my 50cc Extra 300
#70
The trim is Fourmost U-Trim Large 1/4" (link below)
I got it from Tower Hobbies. I have always used it because it fits perfectly.
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXG853
#71
I got to fly it twice today..what a palne! Didn't have to trim anything. On low rates it felt like a big trainer. Knife edge did not pitch at all and while holding only rudder, it just wanted to slightly roll out. Inverted was no different than right side up. Wish I had something negative to say so I would sound objective and credible, but I could find nothing but oohs and aahs. No issues with the landing gear either. I could have flown it more, but with a new plane I always fly it a couple times, take it home and go over everything. Everything checked out "A OK" so next time I'll wring it out. The video was not worth posting, just some boring ordinary flying.
#72
Like Randy I flew mine and took it home to check it out - no problems. Relative to the gear issue, I don't know if it will become an issue or not. Flatland Mike, above, refers to his Extra which has the bowed (stiffer) gear. I have a 3/16" gear coming from TNT but will use the stock 1/8" until it becomes a problem. I don't like breaking props from a decent but imperfect landing on our grass field that has some bumps in it. I notice when I drag the airplane backward into the pits that the gear splays outward a lot. Not so pushing it forward. There is a bit of toe in on the wheels, don't know if that was intentional, but that also tends to keep the gear straight moving forward (also aggrevates the spreading problem when pulling it backward).
Some of the black trim on the wing bubbled in the sun, but otherwise the covering seemed to hold up well in the warm Florida sun. I went over it all before flying, but I suspect that this will be an ongoing issue.
#73
Good note R.J. When I initially went over the covering I noticed that the black was way more sensitive to heat than the other colors. In fact when I hit it with the heat gun it deformed its shape a bit. After that I was careful not to over heat the other black places.
The landing gear is much like that on the WH YAK.
In the YAK build thread Ken Bryant posted "gear hint: With my stock gear I was starting to have it flatten out on some rougher landings. So what I did was bow the gear slightly inward and now it's not flattening out at all."
I took his advice with my YAK and I never had an issue with the gear, even after some less than perfect landings. I may try this on the Edge if I notice it flattening out.
#74
That's because the black is not Ultracote. I noticed this on mine as well when the temperature used to set all the other edges was too much for the black. For some reason the maker used Chinacoat for the black. At least for the bottom stiping at the tail. I haven't looked real close at the bottom of the main wing. Probably because it does not bubble when applied at low temperatures. Unfortuantely it does not like to be re-shrunk.
Use a temp of 225 degrees of less on the black Chinacoat and make sure you use a sock on the iron.
