Eagle Aviation One Design Build
Old 03-16-2013, 02:44 PM
  #51
Tony Hallo
Default RE: Eagle Aviation One Design Build
The build is right where the last post left off.  Lost a little interest when we lost our field and I have a Godfrey One Design flying about the same size.  Still trying to get back http://www.rcuniverse.com/forum/m_11232686/tm.htm
I have a few mis-positioned copies that should work for you, let me clean the bench and check.
Old 03-17-2013, 05:05 AM
  #52
bmosinski
bmosinski's Avatar
Well I see you have.still been busy per your link. You are true craftsman like me not a lot of guys nuts enough like us to "redo" an entire ARF. Real bummer about your field, sorry to hear that news. No rush on the plans any help would be appreciated. Keep up the great work on your other builds keep the posts coming. Regards, Bob
Old 03-19-2013, 02:19 PM
  #53
Tony Hallo
Found 4 sheets that should have sufficient detail. Let's talk about about shipping.
Old 08-30-2014, 05:05 AM
  #54
gordon_mcln
Hi Tony - Hope you are doing well...I still have the One Design plans, but would like to use this foam method for a 33% Ulery Laser.
I have two questions...In the opening sequence, were the foam rib blanks glued to the board with poly glue?
I will need to build one of these foam cutting rigs....Did you develop yours on your own, or can you point me to a link that you worked from. Talk to you later.
Gordon
Old 08-30-2014, 05:26 AM
  #55
gordon_mcln
Gordon
Old 09-01-2014, 05:37 PM
  #56
Tony Hallo
The blanks are held to the jig by parting strips nailed on each side. I put a dab of wood glue to hold it in place. You can see these in the photo attached. I hope I answered your question. You digging deep into the old posts, two today?
Old 09-04-2014, 03:50 PM
  #57
Tony Hallo
I might add I recently purchased covering for this build from Hobby King, got http://www.hobbyking.com/hobbyking/s..._5mtr_113.html,
http://www.hobbyking.com/hobbyking/s..._5mtr_109.html,
and http://www.hobbyking.com/hobbyking/s...410_5mtr_.html.
Building season is just around the corner.
Old 09-15-2014, 04:58 AM
  #58
gordon_mcln
Tony- Thanks for the clarfication and the additional photo....I always learn from your threads....Sure can't beat the price on that covering !
Old 12-14-2014, 09:56 AM
  #59
Tony Hallo
Well I dusted off the build and just about ready for covering. Maybe later today. Will find out how the covering works out. Pictures to follow.
Old 12-18-2014, 07:02 PM
  #60
Tony Hallo
Here a few photos while covering.
ID:	2056117   Click image for larger version
ID:	2056118   Click image for larger version
Old 12-18-2014, 07:07 PM
  #61
Tony Hallo
And the final colors applied. I will write my thoughts about the Hobby King covering after I finish the airplane. So far it works better than I anticipated.
ID:	2056120   Click image for larger version
Old 12-22-2014, 05:00 PM
  #62
Tony Hallo
I had to go a little backward. I had forgot that I modified the center section of the fuselage so that it looked better. This resulted in the need for extensions at the root of the trailing edges. Should have installed before covering. I really don't want to start out on new build with a patch job so I decided to remove the covering, install the extensions, let recover, Since a 5 meter roll is only $10, cost was not a factor. I can report that the covering comes off well with little to no damage to substrate. It was stuck well and released by applying heat from a heat gun. The photo on the right displays the gap at the trailing edge.
ID:	2057078   Click image for larger version
Old 12-22-2014, 05:06 PM
  #63
Tony Hallo
The extensions were by gluing 3 pieces of 1/4" lite ply together and sanding to shape with the 12" disc sander.
ID:	2057081   Click image for larger version
Old 12-22-2014, 05:18 PM
  #64
Tony Hallo
Hobby King Covering Pro's and Con's
Pro
Low cost
Looks good, nice shine, not quite as shinny as Monokote
Shrinks good, like Ultrakote.
Sticks well, I did treat the balsa with hair spray during final sand.
Con
No frill packaging, no instructions
The colors have white backing that makes a white line where shrunk excessively. My experience here is with light blue and neon green only. Other colors may not have the white backing
Very difficult to get backing off the light blue covering. Once you did the backing continued to follow me around the shop. Very high static charge. The white backing released very easy, neon green took a little more work and the light blue was just plain crazy.
Time in the sun will be the final judge, I don't this will happen before May however.
Old 12-23-2014, 01:13 PM
  #65
avinut
Reading your build log reminds me of the story about the guy going to see Chet Atkins in concert. Went home and threw his guitar in the trash. :-)
Old 12-27-2014, 12:24 PM
  #66
Tony Hallo
Thanks for the comment.
Attached is the final version I hope, who knows what else might be forgotten? That's what happens when you set them aside for a while.
ID:	2058137   Click image for larger version
Old 12-28-2014, 07:58 AM
  #67
Tony Hallo
Another thing I forgot about was wing retention. I could have done this with the wing covered but this is much better. I drilled a wood block in the drill press to act as a drill jig. This was used to drill through the spar, wing tube and socket. I turned a 4-40 stainless screw so that a 3/16" brass tube slip over the head and act as a guide. The sharpen brass tube was used to counter bore the hole to recess the screw heads.
There's no need to remove the hatch at the field, slip the wing on, plug in the servo, and install the screw.
The wings are now re-sanded and ready for covering again!
ID:	2058368   Click image for larger version
Old 12-28-2014, 08:10 AM
  #68
Tony Hallo
I'm using Aeroworks control horns. These take me back to the days when standard 2-56 hardware was doubled up since no Giant Scale hardware was available. The surfaces are 3/8" thick and I was having trouble coming up with a method the add a plywood plate. I decided to use heavy duty Sullivan Ny-Rods instead. This seems to work very well. 2-56 screws will hold the horns in place. Short pieces of the inner rod are CA'ed in place. The horns straddle the inner hinge.
Old 12-31-2014, 02:40 AM
  #69
Tony Hallo
Hobby King covering applied on top of itself, lessons learned. I covered the horizontal with white then laid out the spacing for the strips. We know that Monokote will stick to itself when wetted with window cleaner and Ultrakote does not work. Didn't what to expect here so it was a little trail and error. My first attempt was simply ironing the covering to itself starting with low heat then slowing increasing the temperature after each pass. This resulted in bubbles and an unacceptable finish so off it came. You see what happens when you remove the covering. The glue and the color stay behind. Quickly removed with acetone.
ID:	2059137   Click image for larger version
Old 12-31-2014, 03:01 AM
  #70
Tony Hallo
The second attempt was the Ultrakote method I recently viewed on Utube. Wet on the piece with glass cleaner, squeegee out the liquid, then heat. Of course produced unacceptable results.
Old 12-31-2014, 03:06 AM
  #71
Tony Hallo
Finally I tried wetting out the part, squeegee the liquid out, and then left the part dry for two hours. Starting at 170f iron, begin to attach the covering while slowing increasing the temperature. I found if bubble would I could eliminate by shrinking with a trim iron set on high. It's perfect but it is acceptable.
Old 12-31-2014, 03:11 AM
  #72
Tony Hallo
Getting closer
ID:	2059142   Click image for larger version
Old 01-01-2015, 11:46 AM
  #73
Tony Hallo
I was able to use the canopy from the Godfrey One design for this plane since they are the same size. When I bought the spare canopy some time ago Robert Godfrey told me I got the last one. Since I needed two, I had to made a plug to vacuum form additional copies. This was a new experience for me. I had to make an oven and vacuum equipment. I took about six tries before good canopies were made. I used the canopy from Godfrey as a form for the plug. This was made with plaster and concrete mix.
ID:	2059520   Click image for larger version
Old 01-01-2015, 11:51 AM
  #74
Tony Hallo
The canopy frame was painted with automotive trunk paint and I used Weldbond to glue the canopy on the frame. This glue is similar to the old RC 56 canopy glue.
ID:	2059522   Click image for larger version
Old 01-01-2015, 05:22 PM
  #75
dasquirrelisme
My Feedback: (81)
Cool plane! The One Design is a great looking plane and I am surprised its not modeled more. I have a Troy Built One Design siting on the "Get to eventually" table. Cant wait to see yours finished.
Contact Us - Manage Preferences - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service -
