JetCat P-90RXi details
#52
RE: JetCat P-90RXi details
<span style="font-family: Arial; font-size: small;">Yes this is defiantly good for as long as you can service it yourself if a solenoid valve or pump is not working.</span><div><font face="Arial" size="2">Has anyone bothered tothink about what I said previous about the filter. This is the only thing I don’t like.</font></div><div><font face="Arial" size="2">It would be good to heir what Jetcat have to say about this possible issue.</font></div>
#53
ORIGINAL: Justflying1
I never realized the filter is inside the turbine.<div>This is a big downer for this turbine.</div><div>What are you supposed to do pull the the turbine out to get to the rear cover every time you want to clean the filter.</div><div>Has anyone read the manual to see what the filter clean intervals should be. If its like all the other turbines this is a massive downer.</div><div>I guess one way around it is to install another filter on the outside to keep the one inside the cover as clean as possible which would mean less pulling apart.</div><div> </div>
Regards
Dave
#54
I agree with Dave, as far as I'm concerned the filter in the fuel line to the engine is there just in case my four filters (inc the UAT) happen to let something through, this has never happened. Also Wrens have fitted filters behind the cover for about 10 years now.
Jason
Jason
#55
Hello Dave,<div>I assure you that I don’t have any problems with my Fuel.</div><div>I only get JetA1 from my local airport store it in its own designated drum. I to clean my tanks before they go into the aircraft.</div><div>My fueling system before it goes into my plane has got a filter on the clunk and two filters on the main line. This would make my fuel filtered 3 times before it goes into my Jet tank.</div><div>I still however pull my Filter in my Jet every 20-25 flights and give it a rinse, bleed the system again and give it a go over.</div><div>Jetcat them selves on there P80SE manual state to clean the filter every 10 flights. Full stop this is what the factory is recommending.</div><div>It does not matter what you do or anyone else does which that includes me as well. If you are not following the recommendations you are not covered by warranty.</div><div>With all this said if Jetcat does not warrant if you remove the cover from the turbine, and want you to clean filter every 10 flights how is this going to be done and keep the warranty. </div><div>I assure you when something goes wrong all manufacturers will look to see if there recommendations have been followed. What happens if this does not happen. Guess what you loose your warranty.</div><div></div><div>Ivan</div><div></div>
#56
This is why I would like someone from Jetcat to clarify to everyone there recommendations on this engine regarding the filter and if we can change things like Valves and fuel pumps ourselves.<div>Unless its in writing for everyone and I to see from the manufacturer it will mean nothing.</div><div></div>
#57
Just put a filter between the UAT and Turbine, then you know the one under the cover is not going to get dirty and you wont have to remove the cover. Problem solved. I think this engine is great and Gives people the ease of switching the turbine from one plane to the other.
#58
I did mention this previously as something that could be done.<div>I would still like to heir Jetcat comment on this issue. When you look at the bigger picture you still have to wonder about Jetcat recommendations and how you are going to follow these recommendations otherwise, I can assure you that when something goes wrong this is one thing they can try and put the blame on.</div><div>I do like Jetcat engines and have a few including a P90 which is yet to be delivered but I never knew about the internal filter. </div><div></div>
#59
Banned
#60
My Feedback: (9)
Quote From Wilcox when I Ordered it," I don't know how they got so much power out if it". As far as the filter in 5 years of turbine flying I've never seen a single particle of dirt in the filter. I filter it before it goes in the jet. Something endorsed by my mentor Tom Cook. If the filter is an issue for you get one of 500 others available. For the rest of us. who believe in moving on, this is a Cool Turbine. Thanks Jetcat, Keep moving forward. My impression is how much larger it is than the P100-RX, Which is 100 N.
#62
Hello Dave,<div>I assure you that I don’t have any problems with my Fuel.</div><div>I only get JetA1 from my local airport store it in its own designated drum. I to clean my tanks before they go into the aircraft.</div><div>My fueling system before it goes into my plane has got a filter on the clunk and two filters on the main line. This would make my fuel filtered 3 times before it goes into my Jet tank.</div><div>I still however pull my Filter in my Jet every 20-25 flights and give it a rinse, bleed the system again and give it a go over.</div><div>Jetcat them selves on there P80SE manual state to clean the filter every 10 flights. Full stop this is what the factory is recommending. </div><div>It does not matter what you do or anyone else does which that includes me as well. If you are not following the recommendations you are not covered by warranty.</div><div>With all this said if Jetcat does not warrant if you remove the cover from the turbine, and want you to clean filter every 10 flights how is this going to be done and keep the warranty. </div><div>I assure you when something goes wrong all manufacturers will look to see if there recommendations have been followed. What happens if this does not happen. Guess what you loose your warranty.</div><div> </div><div>Ivan</div><div> </div>
I can assure you it does not affect the warrantee. I'll try and get some sense from JetCat, but the clean after 10 flights in 12 years old and so out of date. I would expect more issues from constantly breaking the joints! Anyway if you are not having issues and it works!
I can't remember what was said in the P-90 manual about filters, but I'm sure they don't expect it to need cleaning. Like Mr Matt says there has always been a "last chance" filter under the hood
Dave
#63
My Feedback: (9)
Something to be said for the fact: that the more places you cut the fuel line, the more places you could draw air. Just another thought... I think that Jetcat Both Germany and USA keep track of the common reoccurring problems that they could help with and are trying things to eliminate them. If it becomes a Bigger problem, you will see them disappear as fast as they came along...
#64
<span style="font-family: Arial; font-size: small;">Hello Everyone,</span><div></div><div><font face="Arial" size="2">I got an email from Jetcat in Germany about my concerns.</font></div><div><font face="Arial" size="2">For those who care here it is.</font></div><div></div><div></div><div><p class="MsoNormal"><span style="FONT-SIZE: 11pt; COLOR: #1f497d; FONT-FAMILY: 'Calibri','sans-serif'">Dear Ivan,<!?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice"/><o></o></span></p><p class="MsoNormal"><span style="FONT-SIZE: 11pt; COLOR: #1f497d; FONT-FAMILY: 'Calibri','sans-serif'"></span></p><p class="MsoNormal"><span lang="EN-US" style="FONT-SIZE: 11pt; COLOR: #1f497d; FONT-FAMILY: 'Calibri','sans-serif'">I assume you have one of the first manuals.<o></o></span></p><p class="MsoNormal"><span lang="EN-US" style="FONT-SIZE: 11pt; COLOR: #1f497d; FONT-FAMILY: 'Calibri','sans-serif'">Our experience shows that there is no need to clean this filter every 10 flights.<o></o></span></p><p class="MsoNormal"><span lang="EN-US" style="FONT-SIZE: 11pt; COLOR: #1f497d; FONT-FAMILY: 'Calibri','sans-serif'">This suffices at the 25 hour service.<o></o></span></p><p class="MsoNormal"><span lang="EN-US" style="FONT-SIZE: 11pt; COLOR: #1f497d; FONT-FAMILY: 'Calibri','sans-serif'">BTW the warranty wont avoid by remove the front cover, this is needed even in case the temperature sensor must be changed.<o></o></span></p><p class="MsoNormal"><span lang="EN-US" style="FONT-SIZE: 11pt; COLOR: #1f497d; FONT-FAMILY: 'Calibri','sans-serif'">I hope this can help you.<o></o></span></p><p class="MsoNormal"><span lang="EN-US" style="FONT-SIZE: 11pt; COLOR: #1f497d; FONT-FAMILY: 'Calibri','sans-serif'"></span></p><p class="MsoNormal"><span style="FONT-SIZE: 11pt; COLOR: #1f497d; FONT-FAMILY: 'Calibri','sans-serif'"></span></p><p class="MsoNormal"><span style="FONT-SIZE: 11pt; COLOR: #1f497d; FONT-FAMILY: 'Calibri','sans-serif'">Best regards<o></o></span></p><p class="MsoNormal"><span style="FONT-SIZE: 11pt; COLOR: #1f497d; FONT-FAMILY: 'Calibri','sans-serif'">
Udo Töpfer<o></o></span></p></div>
#65
<span style="font-family: Arial; font-size: small;">Don’t know why that Silly face next to my name came up it was not there in the Email</span><div><font face="Arial" size="2">My apologies for any inconvenience</font></div><div></div><div><font face="Arial" size="2">Ivan</font></div>
#66
My Feedback: (18)
I'm sure someone will correct me if I am wrong about this, but I was always told that the filter between the pump and the turbine was to catch any debris that may come from the pump (shavings, pump slowly degrading etc), not necessarily just for the possibility of dirty fuel (although it would work for that as well).
Isn't the filter even on the P-90 after the pump?
#68
ORIGINAL: Kenrico
<br type="_moz" />
#69
Thank you for sharing that advice.<div>I will run 6mm from the bubble trap to engine.</div><div>Was not going to run a filter on suction side for the reason Jetcat and yourself mentioned. I do run JetA1 and filters on the Fuel supply so this should be sufficient.</div><div>After all every time I check the filters they always seem clean to me.</div><div></div>
#70
regarding the thrust...
remember its 105N at ISA
use this and you should get it right: http://wahiduddin.net/calc/calc_da.htm
if you test your turbine at lower temp than 20 degrees, then you will get more thrust at sea level... but it still only performs 105N at 20 degrees at sealevel called ISA
#71
Funny thing so many engines in the same or similiar thrust class P80 P90 P100 . WHY. If I were to buy myself a P90 how much would that change my flying versus a P80Se. It is a question I have been battling with for sometime since I started eying the P90 which I really wanted to buy
Jetcat is fantastic in producing great engines , and I do enjoy them , The point in question here is if I have a p90 installed I would be longer at full power consuming a lot of fuel versus a larger engine . This is what I mean by choice . It would have been nice to see the P90 producing around 27 to 29lbs of thrust with the same specs. This is just my opinion and it came about because of this choice I need to make in buying my next engine. I got turned off when I could not get an honest answer as to what the the thrust of the P90 really is. 23 /25 or what .
#72
If I had a P80SE then I wouldn't upgrade it to a P90RXi, especially if it was Kerostart.
However, I am currently building a BVM Mig 15 and I have all the parts (bypass/pipe etc) to fit it with a P80/P120. I did buy a P100 for it before the P90RXi was released but space is at a premium and the benefit of the simpler installation by having the pump under the cover, and also having the same mounting dimensions as a P80, mean that I will be using a P90 instead. The fact that the P90 is cheaper than the P100 is an added bonus.
I think the Jetcat range is quite good with a lot of the market covered; P20, P60, P90, P100 and P140 are all different and all have their pros and cons. If you want to upgrade a P80SE and want significantly more power then you can always go for a P140RX.
#73
ORIGINAL: Squirrelboyblue
Mike
#74
hmm jetcat makes far to many turbines...
its funny with the jetcat engines..
p20rx, p60se, p80se, p90rxi, p100rx, 140rx, 180rx, 200sx, p300RX and the P400RX
those i have marked with red shouldent be in production today... WHY should you ever want a P140rx???
name one that really is needed?
#75
In my opinion the P60SE is overdue an upgrade. It needs to use the V10 ECU and, unless they squeeze some more power out of it, it needs a price drop. There would be a place in the market for this engine if it was updated to current standards.
Is the P80SE still available? I was under the impression that production of this engine had ceased and the P90RXi was the replacement.
I've explained in my post above a couple of reasons why you might want a P90RXi instead of a P100RX. There must be a market for this engine as I am going to buy one eventually
I agree if the price was the same as the P180RX but the P140RX is significantly cheaper. One solution might be for Jetcat to drop the price of the P180RX and stop production of the P140RX but that is never going to happen.
p.s. ISA standard temperature is 15 degrees C
