Stop landing "bunny hop"
#51
My Feedback: (46)
Ok you guys with a bounce problem this is what you need to do. You change the length and spring rate of the nose gear so under acceleration you have .5 deg of positive wing angle. When you land with a little brake pre applied you now have .5 deg of negative wing angle. So now the plane sticks to the runway. End of bounce.
#52
All this trim this, adjust that rubbish.
Using this flawed theory a taildragger will not land without bouncing at all. But they do!
learn to slow down & land at the correct speed.
John.
John.
